Oggyswain Posted March 12, 2020 Share Posted March 12, 2020 I have a problem with volume pedal and their settings. On some of my Patches the volume goes from 0-100. There is no gradual rise in the volume. On others 10% sounds like 10%. When I look at the setting they seem to be set the same way. Is there something I am missing? I just want to be able to increase my volume pedal and have the volume increase accordingly. Any help would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
themetallikid Posted March 12, 2020 Share Posted March 12, 2020 Where do you have the volume pedal in the presets your comparing? Pre-amp, post-amp? Could make a difference. Does the pedal travel fluidly from 0-100 and its just the sound that jumps to 100% at the 10% movement level? Quote Link to comment Share on other sites More sharing options...
Oggyswain Posted March 12, 2020 Author Share Posted March 12, 2020 Your second question is yes it justs seems to be just the sound that goes to 100% even if the the pedal is at 10% In regards to your first question. I prefer the volume to be pre amp it seems to work best that way but on a few of the patches it is post amp. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted March 12, 2020 Share Posted March 12, 2020 Hmm....I have a few presets as well that I have a pre/volume block set to imitate rolling the guitar volume back or to help facilitate a lower gain setting but keep the tonality of the amp differently than just rolling the gain back (helps with volume control between snapshots/presets). In my presets I do notice that I have to have the volume lower than what I anticipate to get the desired lowered gain setting. Often times I'm sub 40% but usually closer to 25% or lower, even some in the 10-15% range. Do you use EMG's? Do you have the input pad off? Maybe a combination of these things creates a hotter signal and essentially the 60%-100% is really not doing much signal > Amp wise. I don't think your experience is much different than mine. I try to not let the numbers mess with what I hear. I think I even have a preset/snapshot that is at like 5% cause that's just what sounds like I need. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 12, 2020 Share Posted March 12, 2020 27 minutes ago, Oggyswain said: On some of my Patches the volume goes from 0-100. There is no gradual rise in the volume. In "Bypass/Controller Assign" make sure that "Volume Bypass" is assigned to "Exp Pedal Toe" and "Volume Position" is assigned to "Exp Pedal 2". Quote Link to comment Share on other sites More sharing options...
themetallikid Posted March 12, 2020 Share Posted March 12, 2020 I don't have my helix in front of me either, but isn't there a way to change the slope of the 0-100%....linear I would think would be best, maybe that's set differently if it exists? Quote Link to comment Share on other sites More sharing options...
