bclarke675 Posted April 22, 2020 Share Posted April 22, 2020 I try to charge my battery with the charger included with my Variax, but no light comes on (on the charger). I tested the charger with a multitester, and it appears to have voltage at the contacts. The battery also appears to have full voltage when testing with a multitester, but when I put it in the guitar, the lights flash, then it dies. If I get a light when I press the test button, it's only one and it goes out immediately. I'm considering getting the cable power kit, but if it's just the charger, I'd rather get that. Up until this issue, the battery had been charging properly and working in the guitar. I only discovered this after I had not used the guitar or battery for over 6 months. Our local VFW has jam sessions half the year, and that's the only time I use the modeling in my Variax Standard. Thanks in advance for any help! Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 23, 2020 Share Posted April 23, 2020 Battery box power manage circuit failure or loose connection. Quote Link to comment Share on other sites More sharing options...
bclarke675 Posted April 23, 2020 Author Share Posted April 23, 2020 What does your response mean? What do I need to do to fix? Thanks! Quote Link to comment Share on other sites More sharing options...
bclarke675 Posted April 23, 2020 Author Share Posted April 23, 2020 Now, I'm really confused. This morning, I got my battery and put it in the guitar, and it works!?! Not sure what was going on, but have been unable to get it to work for the last 3 months. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 26, 2020 Share Posted April 26, 2020 Either there is a loose connection inside, or the battery compartment on the guitar has failed. Log a support ticket from your account, sounds like it will need some servicing. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted June 18, 2020 Share Posted June 18, 2020 Don't waste your time with the battery, it's empty after 3 hours! Go for a VDI cable if you have a line 6 pedalboard with variax input (no battery needed) of go for this https://www.amazon.com/Line-Variax-Cabled-Power-Kit/dp/B006HKEMEW You save a lot of time and energy to reload your battery every time Quote Link to comment Share on other sites More sharing options...
