mattwalkerncl Posted April 29, 2020 Share Posted April 29, 2020 Hello, I've been trying to a while to get my HX Stomp to load a few IR's but it will not allow me to load anything other than one IR and it MUST be into slot one. It allows me to import them they show up in the IR panel and the bar at the bottom of the panel progresses but then they disappear. I CANNOT figure this one out or find anything online about this problem. Does anyone have a clue? I've tried with different IR's but no joy. I'm on an iMac and running the latest version of HX Firmware. Thanks! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 29, 2020 Share Posted April 29, 2020 Assuming that by "the latest FW" you mean 2.91, do a factory reset (don't forget to back up your presets!), then restore your presets. If you're still having the problem, contact support. Quote Link to comment Share on other sites More sharing options...
mattwalkerncl Posted April 29, 2020 Author Share Posted April 29, 2020 Cheers rd2rk - I've just done that and still no use. I'll give support a shout. :-) Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted April 29, 2020 Share Posted April 29, 2020 This is probably a dumb question, but I like to ask dumb questions when troubleshooting. Is it letting you load ANY IR into slot 1 and only slot 1, or a specific IR? Are all of the IRs you're loading WAV format? Quote Link to comment Share on other sites More sharing options...
mattwalkerncl Posted April 29, 2020 Author Share Posted April 29, 2020 Not a dumb question at all mate! Thats correct - from what I’ve tried, it seems to be letting me put any IR into slot one - they’re all WAV format that I’ve got so far. It’s mad! Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 30, 2020 Share Posted April 30, 2020 Have you tried to drag/drop the IRs rather than using the Import command? Quote Link to comment Share on other sites More sharing options...
mattwalkerncl Posted April 30, 2020 Author Share Posted April 30, 2020 I have indeed. It goes through the process of importing them as it does via the ‘import’ sequence and as soon as that’s done they grey out and disappear. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 30, 2020 Share Posted April 30, 2020 Check to make sure you are running HX Edit v2.90 Quote Link to comment Share on other sites More sharing options...
pcholat Posted May 4, 2020 Share Posted May 4, 2020 Hello, I have the same problem, since I made the update 2.90. All installed IRs have been erased (except the first) and cannot be recharged. Thank you ! Quote Link to comment Share on other sites More sharing options...
Laurent_Schijns Posted May 4, 2020 Share Posted May 4, 2020 I can't even go back to factory settings. Pushing the button on the windows application doesn't do anything. I also wanted to load IR's but i get an -2- out of memory condition? Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 4, 2020 Share Posted May 4, 2020 3 hours ago, Laurent_Schijns said: I can't even go back to factory settings. Pushing the button on the windows application doesn't do anything. I also wanted to load IR's but i get an -2- out of memory condition? What button are you referring to? Quote Link to comment Share on other sites More sharing options...
bensjamin Posted May 27, 2020 Share Posted May 27, 2020 Hi, im having the same exact problem as mattwalkerncl Im kind of guessing if the USB ports on the computer have anything to do with it? but i can do anything else with any other preset without loading IRs. When loading more than 1 IR, it says it loads, but then disappears. i saved my presets and i did factory reset, but still not working, please let me know too. thanks. Quote Link to comment Share on other sites More sharing options...
marty989 Posted May 30, 2020 Share Posted May 30, 2020 Hi I had the same problem. Downgraded firmware back to 2.82 from 2.90 and all those IR's which I had dragged and dropped and then watched in disbelief as they disappeared from the editor, all of a sudden were there again under 2.82. I did not need to re-import them, they were there all of the time, just that the "new" firmware wasn't recognising them. YMMV. Hope this helps. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 30, 2020 Share Posted May 30, 2020 2 hours ago, marty989 said: Hi I had the same problem. Downgraded firmware back to 2.82 from 2.90 and all those IR's which I had dragged and dropped and then watched in disbelief as they disappeared from the editor, all of a sudden were there again under 2.82. I did not need to re-import them, they were there all of the time, just that the "new" firmware wasn't recognising them. YMMV. Hope this helps. You need to update HX Edit to the latest version as well as the firmware. You were using the old editor. That’s why the IRS weren’t showing up. 1 Quote Link to comment Share on other sites More sharing options...
neube Posted July 13, 2020 Share Posted July 13, 2020 I have the latest version of the editor and I'm still having the same problem. Just one IR :-( Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted July 16, 2020 Share Posted July 16, 2020 On 5/30/2020 at 9:28 AM, phil_m said: You need to update HX Edit to the latest version as well as the firmware. You were using the old editor. That’s why the IRS weren’t showing up. On 7/13/2020 at 2:21 PM, neube said: I have the latest version of the editor and I'm still having the same problem. Just one IR :-( The key is matching the firmware and HX Edit versions. Look under 'Help --> About' in the HX Edit menu and make sure both firmware and editor have the same version. The firmware version will be displayed across the top(as long as your device is connected properly) and the HX Edit version across the bottom. Quote Link to comment Share on other sites More sharing options...
