mattzz
MIDI Muppet - Another DIY Arduino based 2 button MIDI controller for the Helix HX Stomp
this is a little DIY project I built: It's a small Arduino based two button MIDI foot switch for the Helix HX Stomp. It is more flexible and more powerful than the "normal" foot switches connected via TRS cable and as a bonus you can still use an expression pedal hooked up to your HX Stomp.
The MIDI Muppet HX can
  • scroll through presets (normal mode)
  • scroll through snapshots (snapshot mode)
  • act as FS4/FS5 (fs mode)
  • bring up the tuner (in any mode)
To cycle through modes, press and hold the right (up) switch. To toggle the tuner, press and hold the left (dn) switch.
If this is something you are interested in building please check out more information at https://github.com/mattzzw/midi_muppet_hx_2btn
Other ideas are integrating tap tempo, looper control, ...
Feedback and ideas are welcome!
Cheers,
  /Matthias
  • Thanks 1
Great job on this project! It looks great, its compact, and its inexpensive. Thanks for sharing your plans. I'm not in need of something like this now, but for those who need a MIDI switch, a nice little DIY project like this one will make you feel smart and proud when you're finished.
Thank you @soundog, appreciate your feedback!
I made a couple of changes, the unit can now also control the looper as a 2 button controller (similar to well known 2 button loopers).
In general, my assumption is that most people are interested in either
  • switching back and forth between program up/dn and snapshot up/dn mode (plus bringing up the tuner).
  • using the unit as FS4/FS5 while being able to use an expression pedal plugged into EXP1/2
  • using the unit as LOOPER controller
built this but I cant get it to do anything on my stomp. all the lights work as should, just doesnt change anything on the stomp. Im completely new to ardurino so Im sure it user error.
Pin out is correct. I’m not getting 5v though. Only getting 3.28 before and after the 220R resistor.
I suspect you're using 3.3V version of Arduino. There are 5V and 3.3V ones.
In order to find out which Arduino version you are using, measure the Vcc pin. This is the supply voltage of the MCU created by the onboard voltage regulator.
But from what you are writing I'm pretty sure you are using the 3.3V version.
Luckily MIDI works with 3.3V, so if you are using the 3.3V version you have to change the resistors for the MIDI TX line (pin 5 of MIDI plug) to 10 ohms and for the MIDI voltage reference line (pin 4 of MIDI plug) to 33 ohms.
I will add that to the documentation.
Yes, I just checked. I did get the 3.3v. I am new to this but am enjoining the learning curve. I recently started building my own effect pedals just for fun and learning. This is a great project for learning a little more about midi. Thanks so much for taking the time to do this and share with everyone. I’m sure you have a lot of time and knowledge invested. Very kind of you. Thanks again.
Matt
Just to update. I did have the 3v version. I changed the resistors as described . All is good now. Works great. Thanks for taking the time to do this and share with everyone. Great little add on.
Hello, excellent work.
I want to ask you if it is possible to modify the code in looper mode so that after the first record it makes an OVERDUB directly and not a PLAY.
The current sequence is:
1 - Record (sw1)
2 - Play (sw1)
The expected sequence is:
1- Record (sw1)
2- Overdub (sw2)
Thank you.
Greetings from Argentina
Hm, I am not sure about this one for two reasons:
1. In my opinion the REC/PLAY/DUB workflow is the most generic one. However, I do realize that there are loopers out there that can be configured in a REC/DUB/PLAY workflow. I just think it is less common. Take a look at the Ditto X2 looper for example. And coming from the built-in one button looper the REC/PLAY/DUB workflow is pretty much what I am used to ;-)
2. I think it is less confusing if one button controls REC/DUB and the other button controls PLAY/STOP. Putting REC and DUB on different buttons seems very confusing to me.
You can overdub simply by pressing sw1 again in playback: stop --> sw1 --> record --> sw1 --> playback --> sw1 --> overdub.
On 18/8/2020 at 17:06, mattzz said:
Hm, no estoy seguro de este por dos razones:
1. En mi opinión, el flujo de trabajo REC / PLAY / DUB es el más genérico. Sin embargo, me doy cuenta de que existen loopers que se pueden configurar en un flujo de trabajo REC / DUB / PLAY. Creo que es menos común. Eche un vistazo al looper Ditto X2, por ejemplo. Y viniendo del looper de un botón incorporado, el flujo de trabajo REC / PLAY / DUB es bastante a lo que estoy acostumbrado ;-)
2. Creo que es menos confuso si un botón controlar REC / DUB y el otro botón controlar PLAY / STOP. Poner REC y DUB en diferentes botones me parece muy confuso.
Puede sobregrabar simplemente presionando sw1 nuevamente en la reproducción: detener -> sw1 -> grabar -> sw1 -> reproducción -> sw1 -> overdub.
Thanks for your answer.
I want to do is change the code so that sw1 is: Rec - Dud - Rec - Duc .... (no rec-PLAY-overdub)
And sw2 Play-Stop
Is this possible in your code? My knowledge of Arduino is basic.
Add a stereo jack for more possibilities
Thanks you!
Is it possible to use Arduino Uno instead of Arduino Pro Mini ?? Could you please provide wiring schema?
Thank you
Yes, as the Arduino mini pro is basically a shrunken down version of the Arduino Uno (same chip, same port names just minus the USB serial interface) this should just work fine on the Uno as well. Just powering the Uno is different but straight forward by using the plug instead of the "raw" pin.
The wiring diagram is on github and pretty much applies for Uno/Nano/Mini Pro.
OK, here is a small but quite handy update on the MIDI Muppet:
While being in footswitch mode (where midi muppet will emulate FS4/FS5) you can now quickly switch to snapshot mode and back by long pressing the up button.
(Same functionality applied to preset scroll mode already.)
So let's say you are in footswitch mode because you pretty much stay on the same preset most of the time and you need to access different snapshots within this preset - voilà.
Yay, with firmware 3.10 we can now enjoy the newly added Midi CC message 72 and step up/down through preset without using this nasty hack (switching modes and emulating footswitch). This will get rid of the flicker/delay the hack introduced. Check out the latest version at https://github.com/mattzzw/midi_muppet_hx_2btn
By the way: Would anybody be interested in being able to configure the Midi channel of the Midi Muppet?
Edit: This was a slow evening so I just added MIDI channel configuration to the MIDI Muppet :-)
did this and combined it with another project that counts the clock sync. In addition to the midi input and output I added a small relay board. Also an additional function to receive midi control change messages. So I have your functionality and the ability to send tap to my analog delay pedal and change the channel on my amp from dirty to clean.
  BSD 3-Clause License
  Copyright (c) 2020, Matthias Wientapper
  All rights reserved.
  Redistribution and use in source and binary forms, with or without
  modification, are permitted provided that the following conditions are met:
  1. Redistributions of source code must retain the above copyright notice, this
   list of conditions and the following disclaimer.
  2. Redistributions in binary form must reproduce the above copyright notice,
   this list of conditions and the following disclaimer in the documentation
   and/or other materials provided with the distribution.
  3. Neither the name of the copyright holder nor the names of its
   contributors may be used to endorse or promote products derived from
   this software without specific prior written permission.
  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  Midi Foot Switch for HX Stomp
  - Button Up/Down on pins D2, D3
  - LED green/red          D4, D5
  - requires OneButton lib https://github.com/mathertel/OneButton
  - requires JC_Button lib https://github.com/JChristensen/JC_Button
  We are using two different button libraries for different purposes:
    - OneButton to detect a long press without detecting a short press first.
      This means the action will be evaluated on releasing the button,
      which is ok for most cases but bad for timing critical actions
      like when we are in looper mode.
    - JC_Button to detect a short press as soon as the button is pressed down.
      This button library is used in looper mode only.
  SCROLL Mode:   up/dn switches prog patches
                 long press dn: TUNER
                 long press up: SNAPSHOT mode
                 up + dn: FS mode
  FS Mode:       up/dn emulate FS4/FS5
                 up + dn: SCROLL mode
  SNAPSHOT Mode: up/dn switches snapshot
                 long press up: FS mode
  TUNER Mode:    up or dn back to prev mode
  LOOPER Mode:   dn toggles record/overdub
                 up toggles play/stop
                 long press up toggles undo/redo
#include <Wire.h>
#include <OneButton.h>
#include <JC_Button.h>
#include <MIDI.h>  // Add Midi Library
#include <EEPROM.h>
#define BTN_UP 2
#define BTN_DN 3
#define LED_GRN 4
#define LED_RED 5
#define AMP_RELAY 6
#define TAP_RELAY 7
#define LED 13
// Adjust red LED brightness 0-255 (full on was way too bright for me)
#define LED_RED_BRIGHTNESS 25
MIDI_CREATE_DEFAULT_INSTANCE();
OneButton btnUp(BTN_UP, true);
OneButton btnDn(BTN_DN, true);
Button jc_btnUp(BTN_UP);
Button jc_btnDn(BTN_DN);
enum modes_t {SCROLL, SNAPSHOT, FS, LOOPER, TUNER};       // modes of operation
static modes_t MODE;       // current mode
static modes_t LAST_MODE;  // last mode
static modes_t MODE_BEFORE_SNAPSHOT; // last mode before snap shot mode
enum lmodes_t {PLAY, RECORD, OVERDUB, STOP};   // Looper modes
static lmodes_t LPR_MODE;
bool with_looper = true;
bool led = true;
void (*Reset)(void) = 0;
//MERGE SETUP START
#include <elapsedMillis.h>
elapsedMillis timeElapsed2;
elapsedMillis timeElapsed;
unsigned long prevInterval ;
unsigned long interval ;
int tapCount = 0;
byte midi_start = 0xfa;
byte midi_stop = 0xfc;
byte midi_clock = 0xf8;
byte midi_continue = 0xfb;
int play_flag = 0;
byte data;
byte counter;
byte clickCounter;
//int tapPin = 13;
//MERGE SETUP END
void setup() {
  uint8_t eeprom_val;
  uint8_t looper_val;
  // LEDs
  pinMode(LED_RED, OUTPUT);
  pinMode(LED_GRN, OUTPUT);
  // Buttons:
  btnUp.setClickTicks(50);
  btnUp.attachClick(upClick);
  btnUp.attachLongPressStart(upLongPressStart);
  btnDn.setClickTicks(50);
  btnDn.attachClick(dnClick);
  btnDn.attachLongPressStart(dnLongPressStart);
  // Set MIDI baud rate:
  Serial.begin(31250);
  // get last used mode from eeprom adr. 0
  eeprom_val = EEPROM.read(0);
  // restore last mode, if possible (= valid value)
  if (eeprom_val < 4)
    MODE = (modes_t)eeprom_val;
  else
    // no valid value in eeprom found. (Maybe this is the first power up ever?)
    MODE = SCROLL;
  // restore mode on HX Stomp as well
  if (MODE == SNAPSHOT)
    midiCtrlChange(71, 3); // set snapshot mode
  else if (MODE == FS)
    midiCtrlChange(71, 0); // set stomp mode
  else if (MODE == SCROLL)
  MODE_BEFORE_SNAPSHOT = MODE;
  // indicate mode via LEDs
  if (MODE == LOOPER) {
    flashRedGreen(10);
    // we are in looper mode, so we are using the jc_button class for action on button press
    // (OneButton acts on button release)
    jc_btnUp.begin();
    jc_btnDn.begin();
    flashLED(10, LED_RED);
    flashLED(10, LED_GRN);
  // Looper default state
  LPR_MODE = STOP;
  // check if btd_dn or btn_up is still pressed on power on
  // and enable disable looper mode availability
  // (buttons are low active)
  if (digitalRead(BTN_DN) == 0 && digitalRead(BTN_UP) == 1) {
    // btn dn pressed
    with_looper = false;
    EEPROM.update(1, with_looper);
    delay(500);
    flashLED(5, LED_RED);
  if (digitalRead(BTN_DN) == 1 && digitalRead(BTN_UP) == 0) {
    // btn up pressed
    with_looper = true;
    delay(500);
    flashLED(5, LED_GRN);
  // restore looper config from adr. 1
  looper_val = EEPROM.read(1);
  if (looper_val < 2)
    with_looper = looper_val;
  else
    with_looper = true;
  pinMode (AMP_RELAY, OUTPUT); // Set Arduino board pin 13 to output
  //pinMode (13, OUTPUT);
  pinMode (TAP_RELAY,OUTPUT);
  MIDI.begin(MIDI_CHANNEL_OMNI); // Initialize the Midi Library.
  MIDI.setHandleControlChange(MyCCFunction);
  MIDI.setHandleStart(countStart);
  MIDI.setHandleContinue(countContinue);
  MIDI.setHandleStop(countStop);
  MIDI.setHandleClock(clockHandler);
void loop() {
    jc_btnDn.read();                   // DN Button handled by JC_Button
    btnUp.tick();                   // Up Button handled by OneButton
    if (jc_btnDn.wasPressed() && digitalRead(BTN_UP) == 1)          // attach handler
      jc_dnClick();
  } else {
    btnUp.tick();                   // both buttons handled by OneButton
    btnDn.tick();
  handle_leds();
  MIDI.read();
/* ---       OneButton Callback Routines          ---*/
void dnClick() {
  switch (MODE)
    case SCROLL:
      patchDown();
      flashLED(2, LED_RED);
      break;
    case TUNER:
      midiCtrlChange(68, 0); // toggle tuner
      MODE = LAST_MODE;
      break;
    case SNAPSHOT:
      midiCtrlChange(69, 9);  // prev snapshot
      break;
    case FS:
      midiCtrlChange(52, 0); // emulate FS 4
      break;
    case LOOPER:
      switch (LPR_MODE) {
        case STOP:
          LPR_MODE = RECORD;
          midiCtrlChange(60, 127);  // Looper record
          break;
        case RECORD:
          LPR_MODE = PLAY;
          midiCtrlChange(61, 127); // Looper play
          break;
        case PLAY:
          LPR_MODE = OVERDUB;
          midiCtrlChange(60, 0);    // Looper overdub
          break;
        case OVERDUB:
          LPR_MODE = PLAY;
          break;
      break;
void upClick() {
  switch (MODE)
    case SCROLL:
      patchUp();
      break;
    case TUNER:
      MODE = LAST_MODE;
      break;
    case SNAPSHOT:
      midiCtrlChange(69, 8);  // next snapshot
      break;
    case FS:
      midiCtrlChange(53, 0); // emulate FS 5
      break;
    case LOOPER:
      switch (LPR_MODE) {
        case STOP:
          LPR_MODE = PLAY;
          break;
        case PLAY:
        case RECORD:
        case OVERDUB:
          LPR_MODE = STOP;
          midiCtrlChange(61, 0); // Looper stop
          break;
      break;
void dnLongPressStart() {
  if (digitalRead(BTN_UP) == 1) {
    switch (MODE)
      case TUNER:
        break;
      case SCROLL:
      case SNAPSHOT:
      case FS:
        LAST_MODE = MODE;
        MODE = TUNER;
        break;
      case LOOPER:
        break;
void upLongPressStart() {
  if (digitalRead(BTN_DN) == 0) {
    // yay, both buttons pressed!
    // Toggle through modes
    switch (MODE) {
      case SCROLL:
        MODE = FS;
        break;
      case FS:
        if (with_looper)
          MODE = LOOPER;
        else
          MODE = SCROLL;
        break;
      case LOOPER:
        // make sure to switch off looper
        MODE = SCROLL;
        break;
      case SNAPSHOT:
        if (with_looper)
          MODE = LOOPER;
        else
          MODE = SCROLL;
        break;
      case TUNER:
        break;
    EEPROM.update(0, MODE);
    // reset the device to reboot in new mode
    Reset();
  } else {
    // regular long press event:
    switch (MODE)
      case TUNER:
        break;
      case SCROLL:
        // save mode where we entered snapshot mode from
        MODE = SNAPSHOT;
        break;
      case SNAPSHOT:
        if (MODE_BEFORE_SNAPSHOT == FS) {
          MODE = FS;
        } else {
          if (MODE_BEFORE_SNAPSHOT == SCROLL) {
            MODE = SCROLL;
        break;
      case FS:
        MODE = SNAPSHOT;
        break;
      case LOOPER:
        switch (LPR_MODE) {
          case PLAY:
          case STOP:
            midiCtrlChange(63, 127); // looper undo/redo
            flashLED(3, LED_RED);
            break;
          case RECORD:
          case OVERDUB:
            break;
        break;
/* ---       JC_Button Callback Routines          ---*/
void jc_dnClick() {
  switch (LPR_MODE) {
    case STOP:
      LPR_MODE = RECORD;
      break;
    case RECORD:
      LPR_MODE = PLAY;
      break;
    case PLAY:
      LPR_MODE = OVERDUB;
      break;
    case OVERDUB:
      LPR_MODE = PLAY;
      break;
/* ---      Midi Routines                         ---*/
// HX stomp does not have a native patch up/dn midi command
// so we are switching to scroll mode and emulating a FS1/2
// button press.
void patchUp() {
  midiCtrlChange(71, 1); // HX scroll mode
  delay(30);
  midiCtrlChange(50, 127); // FS 2 (up)
  midiCtrlChange(71, 0);  // HX stomp mode
void patchDown() {
  delay(30);
  midiCtrlChange(49, 127); // FS 1 (down)
void midiProgChange(uint8_t p) {
  Serial.write(0xc0); // PC message
  Serial.write(p); // prog
void midiCtrlChange(uint8_t c, uint8_t v) {
  Serial.write(0xb0); // CC message
  Serial.write(c); // controller
  Serial.write(v); // value
/* ---      Misc Stuff                            ---*/
void flashLED(uint8_t i, uint8_t led)
  uint8_t last_state;
  last_state = digitalRead(led);
  for (uint8_t j = 0; j < i; j++) {
    digitalWrite(led, HIGH);
    delay(30);
    digitalWrite(led, LOW);
    delay(30);
  digitalWrite(led, last_state);
void flashRedGreen(uint8_t i) {
  uint8_t last_state_r;
  uint8_t last_state_g;
  last_state_r = digitalRead(LED_RED);
  last_state_g = digitalRead(LED_GRN);
    digitalWrite(LED_RED, LOW);
    digitalWrite(LED_GRN, HIGH);
    delay(75);
    analogWrite(LED_RED, LED_RED_BRIGHTNESS);
    digitalWrite(LED_GRN, LOW);
    delay(75);
  digitalWrite(LED_RED, last_state_r);
  digitalWrite(LED_GRN, last_state_g);
void handle_leds() {
  static unsigned long next = millis();
  switch (MODE) {
    case SCROLL:
      // solid red
      //digitalWrite(LED_RED, HIGH);
      break;
    case SNAPSHOT:
      // solid green
      break;
    case FS:
      // solid green
      break;
    case TUNER:
      // blink green
      if (millis() - next > 500) {
        next += 500;
        if(digitalRead(LED_GRN)){
        }else{
      break;
    case LOOPER:
      switch (LPR_MODE) {
        case STOP:
          break;
        case PLAY:
          break;
        case RECORD:
          break;
        case OVERDUB:
          // yellow
          break;
      break;
void MyCCFunction(byte channel, byte number, byte value) {
  if(channel == 1){
    //Serial.print("AMP SUB STARTED");
    if(number == 20){
      if(value == 127){
        digitalWrite(AMP_RELAY,HIGH);
      }else{
        digitalWrite(AMP_RELAY,LOW);
void countStart(){
  play_flag = 1;
void countContinue(){
  play_flag = 1;
void countStop(){
  play_flag = 0;
  digitalWrite(TAP_RELAY, LOW);
  tapCount = 0;
  counter = 0;
void clockHandler(){
  if(play_flag == 1){
    count();
    Sync();
//sync and count function from midi tap tempo
void Sync() {
 if(counter == 23) {
      counter = 0;
 if((counter == 0) && (tapCount<= 3)){
     digitalWrite(TAP_RELAY, HIGH);
     tapCount++;
 if(counter == 6){ // this will set the duration of the tap
 if (interval != prevInterval){
      tapCount = 0;
counter++;
prevInterval= interval;
void count(){
   if(clickCounter >= 71){  //72(#clicks counted= 3 quarter notes)
      interval = timeElapsed/72;
      timeElapsed = 0;
      clickCounter = 0;
   clickCounter++;
