matonanjin Posted May 29, 2020 Share Posted May 29, 2020 There was a thread recently for using the POD for classical guitar. But that's not what I am looking for. I am looking to use my POD HD 500X as an amp for my acoustic steel string guitar. Anyone else do this? I did try and find some presets in the CustomTone section but couldn't find any. Actually, I found one and it was terrible. Any suggestion or point to a download or two would be appreciated. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted May 29, 2020 Share Posted May 29, 2020 There are several patches for acoustic in the "Bass-Aco-Voc" factory setlist, and also in the "Variax" factory (which works also with normal guitars) setlist, all made by Line6. So before downloading other patches try what you have already in your device. You might like some of them, or find useful as a starting point. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 29, 2020 Share Posted May 29, 2020 my primary use of the device is 6 string electric. but i have used it for other stuff - specifically, acoustic guitar, otherwise it isn't relevant to the conversation. lol and i have recorded (without the device) acoustic guitar many times over the decades. the truth is, exactly what i said in the 'nylon string' post you mentioned - anything more than some eq or reverb, and you really are getting away from enhancing the natural acoustic tone. doesn't mean you can't use stuff. just that most people play acoustic for a reason, and adding a reverse ping pong tron up just isn't it. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted May 29, 2020 Share Posted May 29, 2020 Just add the acoustic amp with a reverb ,and a little touch of delay maybe a EQ Or try to adjust this one :https://line6.com/customtone/tone/2008005/ This is a nice one with a Variax guitar, maybe it can sounds good or not for you with a classical guitar Or need to be adjust Quote Link to comment Share on other sites More sharing options...
matonanjin Posted May 30, 2020 Author Share Posted May 30, 2020 @hurghanico, @pianogayy and @Punkyboy, thanks for those suggestions. I didn't know there are patches in the " "Bass-Aco-Voc" factory setlist, that's how ignorant I am about my machine. So I'll look at those. And I'm not wanting to add a reverse ping pong, just a little amplification, maybe a little reverb? And I didn't see that 2008005, so I'll try that. Thanks you guys. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted June 2, 2020 Share Posted June 2, 2020 Acoustic instruments is my primary use case now. I use it to set different EQs and gains for the various instruments I play (guitar, mandolin, banjo, dulcimer, uke, etc) and then feed a single line to the PA. It works great! There are no tricks really. I don't use an amp sim block. Just a bunch of studio EQs. As far as suggestions, try it first with no blocks at. Crank the gain up and notice the frequency where the feedback starts. Insert a Studio EQ and notch that frequency out. Repeat 2-3 times to get a robust live-friendly setup. Quote Link to comment Share on other sites More sharing options...
ReepkuAlupa Posted July 8, 2022 Share Posted July 8, 2022 Line6 DT25 or DT50 do its best Quote Link to comment Share on other sites More sharing options...
