clay-man Posted March 7, 2014 Share Posted March 7, 2014 Is using a VDI a digital signal? As in it doesn't go through and D/A converter and just sends the audio data over to a POD? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 7, 2014 Share Posted March 7, 2014 pretty certain it does send digitally and the pod does the conversion. Quote Link to comment Share on other sites More sharing options...
jandrio Posted March 7, 2014 Share Posted March 7, 2014 VDI is pure digital. AD takes place @the piezos & DA @POD's output. Check the diagram @14:07 on the foll: Quote Link to comment Share on other sites More sharing options...
joebutterfield Posted March 7, 2014 Share Posted March 7, 2014 Uber Guru you are correct. The signal is digital and remains digital until it is routed through a analog output. Quote Link to comment Share on other sites More sharing options...
Crusty_Old_Rocker Posted March 7, 2014 Share Posted March 7, 2014 The control data is MIDI and the audio is digital (AES). Cheers, Crusty Quote Link to comment Share on other sites More sharing options...
clay-man Posted March 8, 2014 Author Share Posted March 8, 2014 Thank you. That means the Variax VDI output is completely pure and doesn't degrade. Pretty neat and smart. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted March 8, 2014 Share Posted March 8, 2014 I would not call digital signals "Completely Pure" from an audio standpoint. I agree that reducing the number of conversion steps is a good thing though. I like the VDI input because it powers the Variax and I don't have to charge the battery. I don't think it sounds any better than the Analog output though. 1 Quote Link to comment Share on other sites More sharing options...
clay-man Posted March 8, 2014 Author Share Posted March 8, 2014 I would not call digital signals "Completely Pure" from an audio standpoint. I agree that reducing the number of conversion steps is a good thing though. I like the VDI input because it powers the Variax and I don't have to charge the battery. I don't think it sounds any better than the Analog output though. Perhaps, but another good thing is that it reduces some latency by skipping a D/A A/D stage. 1 Quote Link to comment Share on other sites More sharing options...
jandrio Posted March 10, 2014 Share Posted March 10, 2014 Audio-wise the signal is digital (ie the sound is represented by 0's and 1's). By skipping a D/A A/D stage, by definition the "quality" is better. Of course, the human ear can not "sense" this tiny deterioration in sound quality, this is why u think it does not sound any better than the analogue output. Quote Link to comment Share on other sites More sharing options...
lasvideo Posted March 10, 2014 Share Posted March 10, 2014 I use the 59 primary for recording in Logic. Its been a wonderful experience due to the fact the is no detectable latency when playing the guitar. That is a big plus! Quote Link to comment Share on other sites More sharing options...
toasterdude Posted March 17, 2014 Share Posted March 17, 2014 I would love a VDI splitter to send both signals to both PODS at once. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 17, 2014 Share Posted March 17, 2014 I would love a VDI splitter to send both signals to both PODS at once.Have you tried an RJ-45 splitter? The VDI protocol is proprietary but the cable is standard. The splitter won't know or care what the protocol is, and the receiving POD (hopefully) won't know or care that the signal was split. Long term you will need to work around the protective housing of the VDI cable end, but short term you could just use standard RJ45 cabling from the Variax to the splitter. Worth a try? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted March 17, 2014 Share Posted March 17, 2014 some of the pairs carry power... so splitting them could be a disaster... you may end up feeding power into something that shouldn't get it. Have you tried an RJ-45 splitter? The VDI protocol is proprietary but the cable is standard. The splitter won't know or care what the protocol is, and the receiving POD (hopefully) won't know or care that the signal was split.Long term you will need to work around the protective housing of the VDI cable end, but short term you could just use standard RJ45 cabling from the Variax to the splitter. Worth a try? 1 Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted March 17, 2014 Share Posted March 17, 2014 RJ-45 Splitter????? An Ethernet switch won't work and you should not try it. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 18, 2014 Share Posted March 18, 2014 OK - I didn't consider the power implications. Dumb-lollipop suggestion that was! Wish it were either the first or the last.......... Quote Link to comment Share on other sites More sharing options...
taoubt Posted September 3, 2017 Share Posted September 3, 2017 OK - I didn't consider the power implications. Dumb-lollipop suggestion that was! Wish it were either the first or the last.......... Not sure if I followed exactly what you're trying to connect to and from, but if anyone is wondering whether or not you can use an RJ45 switch with the Variax, the answer is yes. I have a single JTV Variax plugged into a PASSIVE, very simple RJ45 A/B switch. It works perfectly to switch between my POD X3 Live and my POD HD 500 X. It provides power without any problems. The only quirk is when switching to the X3 Live, it will deactivate the tuning, if you have anything set. You just need to quickly roll the knob to anything else and then back. The other great thing about a digital connection is the lack of inference. That's one of the best things for my set up which is near tons of other equipment where unbalanced connections and magnetic pickups are prone to annoying inference. The main thing I'd love to be able to do is use both pods simultaneously, but I'm scared to try a straight up RJ45 splitter on the guitar. Switching the connection between 2 pods is straight forward, but I have no idea what would happen if you tried to connect a single guitar to 2 Pods, especially if they were both trying to power it! I've used the FX loop send as an analog output to the input of the other Pod, but I run into noise issues with that set up. I really wish either of the Pods had a digital input. Quote Link to comment Share on other sites More sharing options...
