How can I use the Tap/Tuner footswitch only for tuner?
claudeu
HX stomp XL
For me the red blinking footswitch ring is disturbing.
I never use the TAP function.
I am looking for a solution to switch off the blinking and want to use this footswitch only for switching on the tuner.
easy.  by not using tap-tempo in your delays.  Instead use actual BPM values.  It's easiest to do this in HX edit -- simply type in the beats per minute or whatever values.  And disable the tap tempo light ^^.
I don't tap in my tempo because we play to a click.  But some delay tempos were originally created with a tap button. I disabled the light and have it set up where the delays are on a per-snapshot basis and the changes are discarded.  So I can press the snapshot button again and all my tempos will be back to their saved values.
