raveydavies Posted October 24, 2021 Share Posted October 24, 2021 Hi. I am using my HX effects unit to switch channels and FX loop on my Marshall DSL20 head. It has a TRS cable foot switch. The tip switches the channel and the ring switches the FX loop. I’ve successfully got it to do all the switching, however I’ve found the amp is expecting the reverse of the signal from the HX effects. Meaning that when the ring is NOT shorted to the sleeve, the FX loop is on, and when the tip is NOT shorted to the sleeve the ultra gain channel is on. This means the lights and logic on the HX effects are doing the reverse of what you’d expect based on the amp. Is there any way to reverse the logic of the ext amp outputs so that when I activate the switch the TRS cable is “un-shorted”, or alternatively to have an LED change colour instead of dimming when a switch is bypassed. Currently I’ve got it set up as snapshots to avoid the problem, but that’s a bit of a pain because I need 4 switches instead of 2 to cover all the combinations. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 25, 2021 Share Posted October 25, 2021 In Global Settings/Pedals, try reversing the polarity. The way it's worded in the manual it would seen to only affect the Exp Pedals, but as the jacks are dual function, maybe it'll work. Quote Link to comment Share on other sites More sharing options...
raveydavies Posted October 25, 2021 Author Share Posted October 25, 2021 13 hours ago, rd2rk said: In Global Settings/Pedals, try reversing the polarity. The way it's worded in the manual it would seen to only affect the Exp Pedals, but as the jacks are dual function, maybe it'll work. Thanks for the suggestion. I tried it and it doesn't work unfortunately. I did also find a suggestion on the forum to have a simple gain block set at 0dB on the same footswitch. Might try that, although it's addressing the symptoms rather than the cause of the problem. Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 26, 2021 Share Posted October 26, 2021 On 10/24/2021 at 8:28 PM, raveydavies said: however I’ve found the amp is expecting the reverse of the signal from the HX effects. Hi, Not sure if this helps, but… https://beatbars.com/en/trs-extension-reversed.html 1 Quote Link to comment Share on other sites More sharing options...
raveydavies Posted October 26, 2021 Author Share Posted October 26, 2021 4 hours ago, datacommando said: Hi, Not sure if this helps, but… https://beatbars.com/en/trs-extension-reversed.html Thanks, but no, that doesn't help, it is just swapping Tip and Ring. I need something makes the T-S (or R-S) connection "open" when the HX effects sets it to "closed". A kind of TRS connector NOT logic gate :-). In fact, that might be a good thing to search for...... 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 26, 2021 Share Posted October 26, 2021 58 minutes ago, raveydavies said: Thanks, but no, that doesn't help, it is just swapping Tip and Ring. I need something makes the T-S (or R-S) connection "open" when the HX effects sets it to "closed". A kind of TRS connector NOT logic gate :-). In fact, that might be a good thing to search for...... Ah, I see that now. O.K. Quote Link to comment Share on other sites More sharing options...
drobidoux Posted December 31, 2025 Share Posted December 31, 2025 I'm having the same problem with my Laney IRT Studio. I setup a footswitch for the boost and it's reversed: Boost On=light off, Boost off=light on. Any firmware update that addressed the problem? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted December 31, 2025 Share Posted December 31, 2025 On 12/31/2025 at 3:14 AM, drobidoux said: I'm having the same problem with my Laney IRT Studio. I setup a footswitch for the boost and it's reversed: Boost On=light off, Boost off=light on. Any firmware update that addressed the problem? No. It should be very easy to fix this for Line6 though. Open a support ticket , tell them that you can't accomplish this right now and hope that they add this in a future update. 1 Quote Link to comment Share on other sites More sharing options...
