johnsc2988 Posted December 3, 2021 Share Posted December 3, 2021 Hello! I have an HX effects unit that I love dearly. Recently the power switch has been acting up. I have to turn the switch on and off multiple times for the unit to power up. Sometimes it's once, sometimes 12. There doesn't seem to be any rhyme or reason to what turns it on. Once on the unit works great. I'm wondering if anyone also has this issue with their unit? If so are there any solutions? Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 3, 2021 Share Posted December 3, 2021 Sounds like the switch is just going bad. Personally, I never turn mine on or off with the switch, but it probably would be a pretty easy thing to repair otherwise. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted December 3, 2021 Share Posted December 3, 2021 13 hours ago, johnsc2988 said: Once on the unit works great. I'm wondering if anyone also has this issue with their unit? If so are there any solutions? The switch is on its way out... eventually it'll $hit the bed altogether. Replacing it is the only solution. Quote Link to comment Share on other sites More sharing options...
stwoods Posted October 21, 2023 Share Posted October 21, 2023 Hi. I have the same issue and have confirmed that the rocker switch on my HX Effects is flaky. Anyone have a source for the part to replace? Or a keyword to search on. There are thousands of rocker switches. It's a simple fix that I can do myself if I can source a part that fits. Quote Link to comment Share on other sites More sharing options...
robboman Posted November 8 Share Posted November 8 Same issue here. Bump? Anyone have a link for the correct replacement part? 1 Quote Link to comment Share on other sites More sharing options...
robboman Posted November 8 Share Posted November 8 Until I can find the part, in the meantime I’ve taped it into the ON position and I just disconnect/reconnect AC plug to power cycle. Not elegant but it works so far. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 8 Share Posted November 8 On 11/8/2025 at 5:56 PM, robboman said: Same issue here. Bump? Anyone have a link for the correct replacement part? You can contact support. I asked for the specifics of a different part which they provided. 1 Quote Link to comment Share on other sites More sharing options...
C4TH Posted Tuesday at 10:35 PM Share Posted Tuesday at 10:35 PM I had this problem a while back. I used a couple of sprays of Deoxit. Switched back and fourth a few times, and now it works no problem. Quote Link to comment Share on other sites More sharing options...
C4TH Posted Tuesday at 10:36 PM Share Posted Tuesday at 10:36 PM On 11/8/2025 at 4:56 PM, robboman said: Same issue here. Bump? Anyone have a link for the correct replacement part? I had this problem a while back. I used a couple of sprays of Deoxit. Switched back and fourth a few times, and now it works no problem. Quote Link to comment Share on other sites More sharing options...
