Helix snapshots
Dwf2008
The 2 leftmost buttons on the helix floor default to bank up and down. Suppose I then select a preset that has at least 2 snapshots. If I then press the 2 leftmost buttons together they change to snapshot, but there is no change in the labels to show which snapshot is selected. What is the sequence of button presses to properly select and manage the snapshots?
Also, I thought each snapshot would save the individual settings for the controls in the preset. But it appears only their on/off status is saved. Is this correct or am I missing something?
Thanks
Q1: When you press the two leftmost switches together (the up/down switches) you are presented with a flashing display of all 8 snapshots. When you press one of them to select it, it becomes the active snapshot and the display reverts to its previous state. If that previous state happened to display the snapshot 'labels', the newly active snapshot is (or should be) highlighted. Of course if the previous display did not show the relevant snapshot label you won't notice any change in the display.
Q2: Yes, you are missing something very important. In order to change parameters using snapshots you must first assign the parameter to the Snapshot controller. To do this, press and turn the knob controlling the parameter. The value will appear in white brackets indicating that the assignment has been made. You will now be able to save and restore different values for the parameter in different snapshots.
Hi. I just gave myself a Helix floor unit as my Christmas gift! I have encountered a weird problem: It's impossible to go into snapshot mode:
1 - When I try to activate the snapshot mode pressing both "Bank" switches, the unit freezes. Nothing else work, switches, buttons, etc. It comes back after doing all the global reset, factory reset, etc.
2 - If I try to go to Global Settings and select Preset/Snap or anything that says "Snap" on it, the unit also freezes and nothing else works...
Is there any way that I can solve this problem or should I try to contact Line 6 and send it back? It has less then 3 days of life here..... I'm using the last firmware version, 3.11.
I would open a support ticket to work directly with Line 6 Tech Support. If it’s a brand new device they will help you sort it out, or replace it.
Or, if you bought it from a retailer it should still be within the warranty period. Get them to replace it before spending any more time on it.
Send it back and wait for a new unit.
If you contact L6, in the middle of holidays, I've the fear you'll be waiting for days without a solution, risking to miss the return window.
Just send it back ASAP, it's clear something is wrong on that unit.
Alex, this sounds like a malfunction to me. Have you tried accessing snapshots via the Helix Edit software? Also, I would redownload the firmware to make sure you have a good copy and then reinstall it. It’s possible something got corrupted when you upgraded. You didn’t tell us if this was a new unit or a used one. If it’s a used one, the previous owner may have messed something up.
I opened a support ticket with them and I already have followed all the steps they told me to do. It didn't solve the problem. It's a brand new device and I will probably return it since I see no solution to the issue. I have 1 year warranty on it so I'm returning as soon as possible so I won't waste my time trying to solve it... Thanks for replying.
On 12/28/2021 at 9:20 AM, theElevators said:
I personally never press up/down to go to snapshots.  I set up my presets to display 8 snapshots.  Maybe try that approach instead?
The weird thing is when I try to set up my presets in global setting to display the snapshots, it freezes completely. Nothing else work. It's like, every time it sees the word "snapshot" it freezes. Crazy!!!
It works fine via the Helix Edit software but when I try it on the unity, it freezes. I have to reset global settings, reset the whole thing, reinstall the latest version (3.11), etc.
