Auto Swell: Rel Offset
fizbin
Clearly, the Internet doesn't know what this does. Can someone from Line 6 chime in? Do they ever chime in?
It was released with no explanation, nothing in any manual, the name doesn't explain it, and it appears to do nothing.
-Jay
Nobody from L6 hangs out here. Try asking this question over on TGP in the Digital and Modeling Forum.
A quick search turned up some references to the Legacy Auto Swell. Apparently it requires some technique to use, and very few find it satisfactory.
There's also a couple of YT vids on the subject.
ROffset does affect (offset) the amount of dBs needed to attack and release the swell. It helps A LOT to quick shape the swell for different guitars with different output, as well to shape the swell for slow or fast playing.
I'm using it A LOT, and as soon as you know how it works it's very efficient. In this video, apart the first glitches to create the loop, I'm using it almost all the time.
  • Upvote 2
Unrelated to your question, but I struggled with the auto-swell block.  It's quite awful in my experience.  I needed to have loud volume swells on long notes without using a volume pedal, or volume knob.  Auto-swell just was too finicky and unreliable.
The main issue is that no matter what I did it just would not release the note properly, and it would get sort-of stuck, unless I made sure to really mute the first note with my hand before playing the second one.  I tried every single combination of the settings, and nothing worked as I needed it to.
What I found works extremely well instead is delay/Legacy/Auto-volume Echo.  Somebody from this forum suggested that actually.  Here are the settings that I use.  I place this block after the the amp/cab.
907979939_ScreenShot2022-08-19at9_30_06AM.thumb.png.fa948e4e67015a8525751b5898e97545.png
Excellent demo! Also,  the brief debut of the cat significantly added to the enjoyment factor.
