Regarding running the Stomp thru monitors
BrettinMS
On 2/16/2024 at 8:56 AM, BrettinMS said:
My setup: HX Stomp run directly through JBL 305s
I'm curious as to why overdriven tones thru just an amp block sound more open than when adding a cab block.  It's like throwing a blanket over the sound after the cab is engaged.
How am I erring?
You don't mention anything about what cabs you're pairing with a given amp, or more importantly your choice of mic sims and their position. Just grabbing a cabinet and dropping it in the chain after the amp block is only half the battle. The mic choice and where you put it have a HUGE impact on the final result... just as it does in a studio mic-ing a real cabinet. There are a bunch of mics to choose from... try different ones and move them around.
I assure you that the cab/mic sims in Helix can produce anything from the "wet blanket" effect you mention to "screeching like a f*cked cat during a bird calling contest". Your job is to find a happy medium...
How am I erring?
 It's not a question of your "erring", but more a result of your "hearing".
Your JBL305s are 5" powered studio monitors with a given frequency response of somewhere around 49 - 20,000Hz
An average guitar speaker will only reproduce approximately 75 Hz — 5 kHz, or for electric bass speakers, down to 41 Hz for regular four-string basses or down to about 30 Hz for five-string instruments.
Your HX Stomp is attempting to model exactly what would be the real world sound of a guitar cabinet with a microphone on it.
It's a science thing. Your monitors are able to reproduce a lot more higher frequencies than the modelled cabinets.
Play around with the various settings, but there are no rules with this stuff - go with what you like the sound of.
Hope this helps makes sense.
