Szlartibartfast Posted May 28, 2024 Share Posted May 28, 2024 Hi, when making snapshots and changing amp parameters, for a standard amp, there might be 10-15 different things you can change (gain, bass etc). Is there a way to enable all parameters to snapshot mode rather than having to assign each one individually? I.e click gain, choose drop down to select 'snapshots', go back to top, choose treble, drop down to select snapshots etc. Can this be done? Quote Link to comment Share on other sites More sharing options...
Szlartibartfast Posted May 28, 2024 Author Share Posted May 28, 2024 Edit...this is being done in hx edit. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 28, 2024 Share Posted May 28, 2024 No way to make Snapshots the default. This is actually a good feature, since you always know which parameters snapshots are controlling in a specific block, and you can easily see which parameters in ALL blocks are being controlled by looking at the BYPASS/CONTROLLER ASSIGN screen (sort with the column headers). Quote Link to comment Share on other sites More sharing options...
Szlartibartfast Posted May 28, 2024 Author Share Posted May 28, 2024 Sorry I may have confused....what I am asking is, do I have to assign every parameter to snapshot one by one, or si there a way to select all of them at once. See image for ref erence Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 28, 2024 Share Posted May 28, 2024 You need to assign each parameter separately. There is no group as assignment feature. 1 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 28, 2024 Share Posted May 28, 2024 On 5/27/2024 at 10:02 PM, Szlartibartfast said: Hi, when making snapshots and changing amp parameters, for a standard amp, there might be 10-15 different things you can change (gain, bass etc). Is there a way to enable all parameters to snapshot mode rather than having to assign each one individually? I.e click gain, choose drop down to select 'snapshots', go back to top, choose treble, drop down to select snapshots etc. Can this be done? You can't select everything at once, but you don't have to fumble with the drop down menu either... at least not if you're on a Mac. Just hold down the function (Fn) key, and then click on the parameter value you want to assign. That'll toggle the snapshot assign function on or off. 2 Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 28, 2024 Share Posted May 28, 2024 … and using the device itself, not HX Edit, just push down and simultaneously rotate the parameter knob to assign the parameter to the Snapshot controller. 1 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 28, 2024 Share Posted May 28, 2024 On 5/28/2024 at 2:55 PM, silverhead said: … and using the device itself, not HX Edit, just push down and simultaneously rotate the parameter knob to assign the parameter to the Snapshot controller. ...and erase that assignment again by pressing ACTION and said parameter knob. 1 Quote Link to comment Share on other sites More sharing options...
Szlartibartfast Posted May 29, 2024 Author Share Posted May 29, 2024 Thanks all. Quote Link to comment Share on other sites More sharing options...
