JTV 59 3 way switch is not switching models but is switching magnetic pickups.
Hi, one of my 3 JTV 59s I have been using for my job has what appears to be a broken 3 way switch.
As I said in the title the switch does change the magnetic pickups but not the variax models.  The model selector knob does cycle b/t different guitars and the detune knob works as it should.
I know the guitars are discontinued and I dont see the switch for sale anywhere on line (that is in stock).
Does L6 still make (or have in inventory) this switch so if I send my guitar to a L6 partnered repair shop it can be replaced?
The board on my switch says "13 Jan 2011"
Im not sure if thats the old switch or the new one.
Here are some imgur pics
Thanks
Thanks
Thanks
I would open a support ticket. They’re the ones who would know.
It might not be the switch itself. Since it’s working for the mags it may be sending the right signals to the modeling electronics. There could be a fault at that point, either hardware or firmware. It might be worth reinstalling the Variax firmware to see if that corrects some corruption. If not the support ticket is your best option.
Typically, a solder point or two. Early 2012 build, so a couple of solder points on the 3-way switch
may be oxidizing after 12 years. Recommend an authorized service center in your area or log a support ticket like silverhead suggested.
Still available, don't know what the stock level is. Best to have an authorized service center check it out,
maybe it's just solder points or maybe it needs replacing. Best let the service center deal with it. It can be
a finicky switch if you don't know how to deal with it.
Having 3 is a good place to start for critical performance work. I’ve been in similar situation dating back to the 10’s - present.
Our good man psarkissian can work miracles in CA.  Well worth the shipment if local help is not available.  Reverb can help with guitar shipping, btw.
  • 7 months later...
I have a 5-way switch issue on one of my two JTV-69S. The Switch works on the magnetic pickups but only positions 1 and 5 on all models are working. Model 3 is selected for positions 2, 3, and 4 on all of the models. I am thinking that it may be the contacts. I don't want to use DeoxIT D5 on my Variax as I am not sure that it is safe to do so. Any suggestions. I can ship to CA from AR. I used to live in CA but moved cuz' of the wild fires (and poly - ticks).
  • 9 months later...
I have an extremely similar problem on my JTV-69S Variax guitar. When it is "on" and in modelling mode, the pickup selector locations for mid-neck and mid-bridge (so 2 and 4) do not change the modelled guitar. It just stays at whatever guitar model it was last on. This is easily confirmed by connecting the guitar to my HELIX, and then connecting my HELIX to my computer running Workbench HD (the model doesn't change). If I press the pickup selector "into" the guitar body for a moment, the model changes until I remove the pressure. The pickup selector works as expected when the guitar is not in modelling mode.
I'm a little odd, so I own basically two of the same guitar. My older, JTV-69 (note: no "S" in the model name) still works great, as of now.
