jealousblues Posted June 5, 2024 Share Posted June 5, 2024 Hi, one of my 3 JTV 59s I have been using for my job has what appears to be a broken 3 way switch. As I said in the title the switch does change the magnetic pickups but not the variax models. The model selector knob does cycle b/t different guitars and the detune knob works as it should. I know the guitars are discontinued and I dont see the switch for sale anywhere on line (that is in stock). Does L6 still make (or have in inventory) this switch so if I send my guitar to a L6 partnered repair shop it can be replaced? The board on my switch says "13 Jan 2011" Im not sure if thats the old switch or the new one. Here are some imgur pics Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 5, 2024 Share Posted June 5, 2024 I would open a support ticket. They’re the ones who would know. It might not be the switch itself. Since it’s working for the mags it may be sending the right signals to the modeling electronics. There could be a fault at that point, either hardware or firmware. It might be worth reinstalling the Variax firmware to see if that corrects some corruption. If not the support ticket is your best option. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 5, 2024 Share Posted June 5, 2024 Typically, a solder point or two. Early 2012 build, so a couple of solder points on the 3-way switch may be oxidizing after 12 years. Recommend an authorized service center in your area or log a support ticket like silverhead suggested. Quote Link to comment Share on other sites More sharing options...
jealousblues Posted June 5, 2024 Author Share Posted June 5, 2024 Thanks for your replies so far. One question I have is does line 6 still make (or have stock) of the 3 way toggle? in case that is the issue. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 5, 2024 Share Posted June 5, 2024 Still available, don't know what the stock level is. Best to have an authorized service center check it out, maybe it's just solder points or maybe it needs replacing. Best let the service center deal with it. It can be a finicky switch if you don't know how to deal with it. Quote Link to comment Share on other sites More sharing options...
jealousblues Posted June 6, 2024 Author Share Posted June 6, 2024 Thank you, im not planning on doing it myself. Just thinking ahead towards the future. I use these for work and love them but I know parts wont be around forever. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 6, 2024 Share Posted June 6, 2024 Very good. Quote Link to comment Share on other sites More sharing options...
jerseyboy Posted June 11, 2024 Share Posted June 11, 2024 Having 3 is a good place to start for critical performance work. I’ve been in similar situation dating back to the 10’s - present. Our good man psarkissian can work miracles in CA. Well worth the shipment if local help is not available. Reverb can help with guitar shipping, btw. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 11, 2024 Share Posted June 11, 2024 Thank you jerseyboy. A 12 year old 59P,... I can deal with it for you. For that, log a Support ticket in your account to contact Line 6 for a return authorization. They will contact you with options. 1 Quote Link to comment Share on other sites More sharing options...
bbehrens Posted February 1 Share Posted February 1 I have a 5-way switch issue on one of my two JTV-69S. The Switch works on the magnetic pickups but only positions 1 and 5 on all models are working. Model 3 is selected for positions 2, 3, and 4 on all of the models. I am thinking that it may be the contacts. I don't want to use DeoxIT D5 on my Variax as I am not sure that it is safe to do so. Any suggestions. I can ship to CA from AR. I used to live in CA but moved cuz' of the wild fires (and poly - ticks). Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 3 Share Posted February 3 Intermittent solder points. A Line 6 authorized service center in your area can deal with it. They will have the experience with these and access to service info. https://line6.com/find/service_center/ Quote Link to comment Share on other sites More sharing options...
dschauer12 Posted November 18 Share Posted November 18 I have an extremely similar problem on my JTV-69S Variax guitar. When it is "on" and in modelling mode, the pickup selector locations for mid-neck and mid-bridge (so 2 and 4) do not change the modelled guitar. It just stays at whatever guitar model it was last on. This is easily confirmed by connecting the guitar to my HELIX, and then connecting my HELIX to my computer running Workbench HD (the model doesn't change). If I press the pickup selector "into" the guitar body for a moment, the model changes until I remove the pressure. The pickup selector works as expected when the guitar is not in modelling mode. I'm a little odd, so I own basically two of the same guitar. My older, JTV-69 (note: no "S" in the model name) still works great, as of now. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 20 Share Posted November 20 Intermittent solder point on the 5-way switch. Have a Line 6 authorized service center check it out. Quote Link to comment Share on other sites More sharing options...
