pat2gtrs Posted April 20, 2014 Share Posted April 20, 2014 Hi everyone, I'd like to know if anyone of you could help me : I've created patches that are - to my opinion - cool, but I need extra volume to play during solos. I've used by the past other stuff that used to feature a solo switch (without changing from one patch to another). HD500X doesn't have it. Any suggestion ? Thanx \m/ Quote Link to comment Share on other sites More sharing options...
Metalchef Posted April 20, 2014 Share Posted April 20, 2014 Tube comp first in chain or at least before distortion with Threshold at 100 and Level below about 13. Also can use the Boost Comp that models an MXR Micro amp I believe. I have also been using the Tube and tape echoes in the pre position. Always the trusty and every tweaking eq pedal. I run an MXR 6 band in the effects loop with a Fulltone OCD v4. Many many options and none of them involving changing patches. 1 Quote Link to comment Share on other sites More sharing options...
pat2gtrs Posted April 21, 2014 Author Share Posted April 21, 2014 Thank you Metalchef, I thought there was a more direct way to get a booster, but that doesn't matter, I'm going to try all this, thanks a lot. Quote Link to comment Share on other sites More sharing options...
jandrio Posted April 22, 2014 Share Posted April 22, 2014 Try one of foll: a. Insert an FX loop in ur chain (place it at the end of the chain if u want a plain clean boost, or in front of an amp or dist pedal to drive them harder if u want more gain). Use short jumper cable 2 connect the FX loop out to the FX loop in. Set the FX loop return at taste (eg +4dB). Assign the FX loop to a switch as (clean) boost 4 solos. . If stereo is a must, use appropriate jumper. b. Use a Studio eq in ur chain (c abv regarding placing). Set gain at taste (eg +4db). c. Assign EXP-1/2 to amp CH VOL (min = rythm, max=solo). 2 Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted April 22, 2014 Share Posted April 22, 2014 The Studio EQ gain is a clean boost - no coloration at all. You can get quite a bit of gain out of it. Quote Link to comment Share on other sites More sharing options...
bvaladez74 Posted May 2, 2014 Share Posted May 2, 2014 If you're asking if there's a "global" boost that spans all presets, then no. Otherwise...I'd agree that jandrio's idea is the best solution. It's what I use and it works perfectly...but yes you have to set this up on each preset...as do you with every effect. 1 Quote Link to comment Share on other sites More sharing options...
pat2gtrs Posted May 7, 2014 Author Share Posted May 7, 2014 Hi there, Jandrio : Studio Eq in a chain works perfectly. I get the extra amount of volume I need (and more),and I can set it for every patch, then choose to color it differently with the EQ (or not). Thanks again everyone \m/ 1 Quote Link to comment Share on other sites More sharing options...
jandrio Posted May 8, 2014 Share Posted May 8, 2014 u r welcome pat2gtrs. glad 2 hear u got the extra amount of volume u need... keep on ...tweaking... Quote Link to comment Share on other sites More sharing options...
Metalchef Posted May 10, 2014 Share Posted May 10, 2014 Give the Q Filter a shot as well. It will allow u to boost specific frequencies Quote Link to comment Share on other sites More sharing options...
guilhordas Posted May 10, 2014 Share Posted May 10, 2014 i use eq studio with no parameter changed, I just set gain, and I control in expression pedal Quote Link to comment Share on other sites More sharing options...
guilhordas Posted May 10, 2014 Share Posted May 10, 2014 i put studio eq on chain, dont change any parameters, then I set the expression pedal to control its gain, min in 50%(that dont add any volume) and max in 70%, it works very weel for me Quote Link to comment Share on other sites More sharing options...
DistortionHoe Posted November 20, 2020 Share Posted November 20, 2020 Gonna try the studio EQ So simply for solos I'll press 3 switches , Boost , Delay and Reverb , unless there is a way to set 1 switch for all the 3 of them that im not aware of Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted November 20, 2020 Share Posted November 20, 2020 1 hour ago, DistortionHoe said: So simply for solos I'll press 3 switches , Boost , Delay and Reverb , unless there is a way to set 1 switch for all the 3 of them that im not aware of Yes, there is a way to set all 3 on one button. You can also set them in reverse order, turning some on and some off with one click. But, also, if you are adding those other things, do you need to add the eq/boost? Shouldn't those other things give you the needed change to stand out for a solo. Here are my "old school" thoughts: 1. let the sound man control volumes. any "stage volume" change that you make will be exponentially changed for the audience. instead, a simple tone change can do wonders without hurting the crowd's ears. 2. volume knob on the guitar - for rock/metal players, create patches your guitar set to 8 or 9. That way you always have that little extra boost for a solo. If done right (primarily how it relates to distortion), it won't give an excessively noticeable volume change, but it will give a bit of high end boost (unless you added a treble bleed) that a solo needs. 3. wah pedal - on these electronic devices, you don't even need to use the exp pedal. you can create the wah setting you need and simply on/off it. Quote Link to comment Share on other sites More sharing options...
