bverdon Posted January 25 Share Posted January 25 I am not sure if this was occurring prior to the 1.2.1 update, but now things are a bit more stable and I find myself paying more attention to other things. Now when I have the Stadium app open and NOT changing anything, it looks like after a few minutes of playing, the Stadium app thinks I have modified something. The preset name changes to what appears to be in script mode which signifies something has been modified. I have created a new preset from scratch and it still happens. Not sure if I am the only one and I haven't tried backing things up and performing a factory reset yet. It's really cosmetic ... at least seems that way unless there is some sort of memory leak occurring that is actually changing something. Anyone else notices this? Quote Link to comment Share on other sites More sharing options...
lwilliams Posted January 26 Share Posted January 26 Since 1.2.1, I have noticed the Save button illuinates when I've done nothing. That seems really strange. Quote Link to comment Share on other sites More sharing options...
Wynlina Posted January 26 Share Posted January 26 You are not alone;) I also noticed this issue in version 1.2.1. Quote Link to comment Share on other sites More sharing options...
jpdennis Posted January 27 Share Posted January 27 On 1/25/2026 at 11:48 AM, bverdon said: I am not sure if this was occurring prior to the 1.2.1 update, but now things are a bit more stable and I find myself paying more attention to other things. Now when I have the Stadium app open and NOT changing anything, it looks like after a few minutes of playing, the Stadium app thinks I have modified something. The preset name changes to what appears to be in script mode which signifies something has been modified. I have created a new preset from scratch and it still happens. Not sure if I am the only one and I haven't tried backing things up and performing a factory reset yet. It's really cosmetic ... at least seems that way unless there is some sort of memory leak occurring that is actually changing something. Anyone else notices this? bverdon, This would happen even in my OG Helix Floor if I switch snapshots while playing, used the expression pedal by switching or adjusting the % of incline, as well as turning on and off blocks with the footswitches. The app as well as the Stadium will see that as a change of some sort. The app will just see it a few moments after the change. jpd Quote Link to comment Share on other sites More sharing options...
goviline6 Posted January 27 Share Posted January 27 Same with Helix LT .. firmware version 3.71 .0 I created my preset with 3 snapshots, when I switch between snapshots, the preset goes into 'E' mode though I'm not modifying anything. Quote Link to comment Share on other sites More sharing options...
jpdennis Posted January 27 Share Posted January 27 On 1/26/2026 at 5:37 PM, goviline6 said: Same with Helix LT .. firmware version 3.71 .0 I created my preset with 3 snapshots, when I switch between snapshots, the preset goes into 'E' mode though I'm not modifying anything. goviline6, It is the "norm" from what I have experienced. Any change triggers the "you've made a change so do you need to save it" alert by either italics or e. I treat it like the Microsoft "are you sure" pop-up. It is a nice built-in for those you don't know if they want to exit or not from the Windoze app or OS. Personally, I made a mistake back in 1992 with DOS OS and I now know if I want to save or not or exit or not. Normally with the Helix family, I do a final save on a specific snapshot for each preset as my "initial" start when triggering a specific preset when at a performance venue so I won't be saving at the venue unless it is a leveling issue during sound check anyway. However, when creating and testing I always double check myself and what setting change or preset or snapshot within a preset I want to trigger a final save. At first it was a little annoying but after some time I learned to just accept it. It has saved me a couple of times so ... jpd Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 27 Share Posted January 27 On 1/26/2026 at 8:37 PM, goviline6 said: Same with Helix LT .. firmware version 3.71 .0 I created my preset with 3 snapshots, when I switch between snapshots, the preset goes into 'E' mode though I'm not modifying anything. But you have modified something - the active Snapshot. If you Save the preset now it will load with a different snapshot (the current one) next time. That’s a change. Quote Link to comment Share on other sites More sharing options...
bverdon Posted January 31 Author Share Posted January 31 On 1/27/2026 at 5:26 PM, silverhead said: But you have modified something - the active Snapshot. If you Save the preset now it will load with a different snapshot (the current one) next time. That’s a change. In my case... nothing... nothing pressed or changed. It's strange... It hasn't happened again though. Maybe because the stadium was on for over 6 or 8 hours? Will keep an eye on it. Again... not biggie... thought it was strange. I mean... I would select a new preset play for about 10 minutes... not change ANYTHING... and the stadium app would look like I changed something. This happened on several different presets. After a reboot... no longer an issue. Quote Link to comment Share on other sites More sharing options...
theElevators Posted Monday at 01:15 PM Share Posted Monday at 01:15 PM Changing snapshots = making a change to your preset. That's the correct behavior. Because you may want to change your starting snapshot. On the Helix Floor it works the same way. Quote Link to comment Share on other sites More sharing options...
bbehrens Posted Monday at 09:01 PM Share Posted Monday at 09:01 PM A change will occur to a Preset if the volume pedal has changed position as well. My Volume pedal is pretty stable on the Stadium but the Volume Pedl on my OG Helix would not always be at exact 0%. And it is now impossible to tell on the Stadium since there is nothing to indicate that the Volume/Wah Pedal is at 100% or 0% or whatever (an annoyance I hope that they will correct in the future. Quote Link to comment Share on other sites More sharing options...
