jbutler Posted August 27, 2014 Share Posted August 27, 2014 I recently lost the power supply for my variax battery charger. Nowhere in the manual or searching this forum can I find where to get a replacement without buying the entire variax battery charger, which comes to almost $70 with shipping and tax. I think it is 12V and 1Amp with negative center terminal, but not sure, and not sure if it needs to be those exact specs. Also it appears to be standard stomp box sized jack, but the hole is actually slightly smaller so the wall warts I have laying around will only fit if I shave some plastic off the jack, which I will do if I know it is the correct power. Does everybody just automatically order a new battery charger when the wall wart dies or goes missing? Thanks Quote Link to comment Share on other sites More sharing options...
stevekc Posted August 27, 2014 Share Posted August 27, 2014 $52.80 here http://www.fullcompass.com/product/443390.html Quote Link to comment Share on other sites More sharing options...
jbutler Posted August 27, 2014 Author Share Posted August 27, 2014 Thanks, but I only need the wall wart part, I have the battery charging cradle Anybody know the specs on the power supply so I can get one at Radio Shack? thx Quote Link to comment Share on other sites More sharing options...
stevekc Posted August 27, 2014 Share Posted August 27, 2014 http://www.thomann.de/gb/line6_james_tyler_jtv_ba12_battery_charger.htm 12VDC @ 1000mA - Coax DC plug (Center Positive) This is the "Euro" version - but it has the same DC Output as the USA version. Quote Link to comment Share on other sites More sharing options...
mdmayfield Posted August 27, 2014 Share Posted August 27, 2014 Usually, the adapters (wall warts) say somewhere on their bodies. They will say something like Input 110-240V AC, Output 12v DC 1000mA (just an example - I don't have mine in front of me) and if output is DC they should show a polarity: http://en.wikipedia.org/wiki/Polarity_symbols In my experience I've seen 4 important output attributes in a power adapter, and as long as the first 3 match exactly and the amperage is equal or greater, it should work fine (as long as the physical connection is correct): 1. AC or DC output - this has to match or damage to the equipment can result 2. Polarity (if DC) - this has to match. It's also easy to switch (flip the wire connections to the small output plug) 3. Voltage - This needs to match since the adapter will "push" its voltage on the equipment. Too high voltage = damage to equipment, too low = possible damage, won't work right 4. Amperage - The piece of equipment will "pull" the needed amperage from the adapter. Too little amperage in the adapter = overheating, damage, melting/fire hazard of the adapter. Sufficient or extra amperage in the adapter = no problem. Quote Link to comment Share on other sites More sharing options...
jbutler Posted August 28, 2014 Author Share Posted August 28, 2014 Thanks guys, all good now. Line 6 tech support came through with the specs and even offered to ship me one at no charge! In case anyone is needing to get a backup for themselves, he said the correct wall wart is: 12V DC and 1Amp with positive center terminal So it is a good thing I did not plug in the negative center terminal one I had on hand! 1 Quote Link to comment Share on other sites More sharing options...
AlienSexGod Posted July 3, 2022 Share Posted July 3, 2022 What are the charging light meanings... even with a new battery and the correct PSU it's red flashing after 8 hours charging. This charger doesn't go green? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 4, 2022 Share Posted July 4, 2022 On 7/3/2022 at 7:45 AM, AlienSexGod said: What are the charging light meanings... even with a new battery and the correct PSU it's red flashing after 8 hours charging. This charger doesn't go green? Not sure if this will help, but… https://www.vguitarforums.com/smf/index.php?topic=21957.0 Quote Link to comment Share on other sites More sharing options...
poortomsacold Posted April 30, 2023 Share Posted April 30, 2023 On 8/27/2014 at 6:33 PM, mdmayfield said: Usually, the adapters (wall warts) say somewhere on their bodies. They will say something like Input 110-240V AC, Output 12v DC 1000mA (just an example - I don't have mine in front of me) and if output is DC they should show a polarity: http://en.wikipedia.org/wiki/Polarity_symbols In my experience I've seen 4 important output attributes in a power adapter, and as long as the first 3 match exactly and the amperage is equal or greater, it should work fine (as long as the physical connection is correct): 1. AC or DC output - this has to match or damage to the equipment can result 2. Polarity (if DC) - this has to match. It's also easy to switch (flip the wire connections to the small output plug) 3. Voltage - This needs to match since the adapter will "push" its voltage on the equipment. Too high voltage = damage to equipment, too low = possible damage, won't work right 4. Amperage - The piece of equipment will "pull" the needed amperage from the adapter. Too little amperage in the adapter = overheating, damage, melting/fire hazard of the adapter. Sufficient or extra amperage in the adapter = no problem. Hi all. Sorry to resurrect an old thread. I've just picked up a JTV Variax. The charger does not have the original charger plug and when I try charging the battery it will show red for a second or so and then cut out. Sometimes it will flash red for a bit but the battery is totally dead - not showing any lights at all in the Variax when plugged in. I have tried using a 12v 1.5A charger which has the correct polarity but no joy. I know the amoage is a little higher than the Line 6 one but can't think that will stop it from charging. Anyone got any ideas if the battery is toast or if the charger or wall charger is knackered? I have a Helix LT so can run the guitar off that luckily but I don't think that will charge the battery sadly. Thanks Quote Link to comment Share on other sites More sharing options...
