Expression Help For The M13
10 replies to this topic
#1 kernow82
kernow82
  • 6 posts
  • Registered Products:1
Posted 01 October 2013 - 08:58 PM
Hi there, I am new to this forum and would like to say hello,
I have now shifted over from a large pedal board to the M13 and would like some advice on a expression pedal? The line6 EX-1 I think will break in next to no time with my heavy feet, but I have seen people use the Boss FV 500 pedal, which one should I get, the H or the L, I use passive pick ups
thank you
john from Adelaide, South Australia
  • 1
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9237 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 02 October 2013 - 05:56 AM
I don't think the EX-1 deserves the reputation it gets... I've had two that I've used for over 10 years, and they both still work fine. They are plastic, so that bothers some people. If you want something more heavy duty, I'd recommend the Mission Engineering EP1-L6. It's designed specifically for Line 6 products, and it's an all-metal housing.
I believe the Boss FV-500L will work. I think its polarity is reversed from the EX-1, though. That's not a big deal, really, because you can set the heel and toe values to be whatever you want them to be in the effects in your scenes. It's just that if you would hook up another expression pedal, they would be reversed from what you set them up as.
#3 scormier
scormier
  • 17 posts
  • Registered Products:3
Posted 09 November 2013 - 09:44 AM
Here is a supported and non supported list from the support archives:
Works:
Ernie Ball VP Jr 25k ohm (log pot)
Line 6 EX-1
Roland EV-5
Boss FV-500L
Boss FV-500H
unknow needs confirmation:
Kurzweil CC-1 (10K linear pot, 45 bucks, likely compatible)
TC Electronics X1 (25k ohm Logpot, $130 (!), likely compatible)
Pigtronix EP-1 Expression Pedal (20k pot unknown taper, metal construction, around 50 bucks, likely compatible)
Not Compatible:
Yamaha  FC-7
Ernie Ball VP JR Passive 250K & 6166
Any wah wah pedal
Morley volume Pedals
Behringer FCV100
M-Audio EXP
Rocktron Hex
Moog EP-2 (it is possible to swap the internal pot with a 16mm pot, though it might take some fabrication skills. This is not recommended for the inexperienced.)
  • 1
#4 rotten77
rotten77
  • 10 posts
  • LocationCzech Republic
Posted 30 May 2014 - 10:15 AM
I use Bespeco VM12L (which look like original EX-1) and I have update on it for switching on/off wah-wah by pressing toe (more info in this topic).
Line6 M13, Fulltone Fulldrive 2, MXR Doubleshot Distortion, Engl E320 combo and Tokai Silverstar from 1985
#5 WahWahWeeks
WahWahWeeks
  • 4 posts
Posted 28 February 2015 - 02:01 PM
I'm happy to report that the Ernie Ball VP Jr 25k ohm (log pot) (P0 6181 made in Malaysia)
does indeed work perfectly out of the box. It also looks extremely smart in my humble opinion.
It's well constructed and light in Aluminium and can be cabled to do other things
Like being a volume pedal, with a spur out to a tuner.
The tuner question is redundant in this discussion as you will have one built in to the M5!
#6 rockhound252
rockhound252
  • 2 posts
Posted 14 August 2015 - 01:02 AM
But i dont understand one thing. The Line 6 Ex-1 is mono Jack and Boss FV500L is sterop Jack. How its possible that both pedals work??
#7 Mincer
Mincer
    Iknowathingortwo
  • PipPip
  • 168 posts
Posted 15 August 2015 - 09:30 PM
The Dunlop volume x has an expression pedal output, and it works perfectly with the M series. The ex-1 gets a bad reputation because it is lightweight plastic...and expensive. It is too light for constant use (it slides around) and should cost less than half of what L6 charges. Buy an expression pedal that will last.
#8 rockhound252
rockhound252
  • 2 posts
Posted 17 August 2015 - 05:45 AM
#9 rwinking
rwinking
  • 31 posts
  • Registered Products:4
Posted 26 August 2015 - 12:59 PM
I got the Mission pedal and it is the best for me. Built like a tank and cool looking plus designed for this stuff.
#10 rumbl
rumbl
  • 3 posts
Posted 30 December 2015 - 07:53 PM
I've been using the Mission pedal for a while and it is excellent. Now I want to use the other control jack with a switch rather than a pedal and be able to A/B between 2 settings. I bought a Nose pedal that was supposed to be compatible with the M13. I was able to set it as with the pedal controller but after one or two cycles, the M13 stopped responding to the switch. I could reset it but it would only work one or two cycles. Then I made a footswitch with a momentary SPDT footswitch, one side direct and the other side through a 10k resistor. Same response: works, then doesn't.
Am I missing something here? I sure would like to get this kind of functionality.....
  • -1
#11 thomas4d
thomas4d
  • 12 posts
Posted 02 October 2016 - 12:45 AM
you can also use a Morley volume Pedal passive model CVO Compact
plug in to amp out on the pedal
the range was a little off so I opened it up and adjusted the spring holding the nylon wire ( fishing line this is a Passive pedal)  a little so the range fix the M9 perfectly
before in far the toe position it would go back down a little so I  pushed the string a little so it didn't go as far into the heel value and it's worked perfectly
basically of adjust the CVO range to match the m9
done and i got the Morley CVO pedal for $22 on ebay
