Line6Drew
    17
Everything posted by Line6Drew
  1. Full List and Descriptions of FIREHAWK FX Amps, Cabs, and Effects FIREHAWK FX Specs · 29 HD Amp Models · 25 HD Effects Models · 78 POD Farm Amp Models · 95 POD Farm Effects Models · 8 simultaneous effects · 128 Onboard Presets · 5 FX on/off, channel and bank footswitches with colored LED rings · 1/4" 1M-Ohm guitar input, VDI (Variax), Expression Pedal · Onboard tone controls, plus Volume, Wah, and FX Knob · USB connection to use Firehawk as an audio interface with your recording programs · Balanced XLR Main Outs, 1/4" stereo full-range balanced outputs, 1/4" Amp Out, 1/4" TRS Headphone Output · 1/4" Send, with Stereo 1/4" Returns, switchable · Bluetooth Audio Streaming and Control for playing along with your music library (compatible with iOS, Android, Mac and PC) · Detailed editing via Bluetooth® Remote app for Android and iOS · Tone Searching · Tap tempo/tuner · Power Switch · Rugged construction with bent metal chassis · Weight: 14 lbs · Dimensions: H: 3 1/4" W: 20" D: 10 1/4" FIREHAWK FX Remote app · Remotely control amp parameters to dial in your sound · Search a cloud-based library of thousands of tones · Create, save and recall unlimited presets in the cloud · Share tones via Twitter and Facebook · Automatic tone matching instantly provides the perfect tones for jamming with songs in your music library · Compatible with iOS 8.0+. Made for iPhone® 6 Plus, iPhone 6, iPhone 5s, iPhone 5c, iPhone 5, iPhone 4s, iPhone 4, iPad® (3rd and 4th generation), iPad 2, iPad mini and iPod touch® (5th generation) · Compatible Android devices running OS v4.2 or better: Samsung® Galaxy S®5, Samsung Galaxy S4, Samsung Galaxy S III, Samsung Galaxy Note® Pro, Samsung Galaxy Note II, HTC® One M8, HTC One M7, Motorola® Moto® X, Google® Nexus® 7, Amazon Kindle Fire HDX, ASUS® MeMo Pad 8, ASUS Fonepad, ASUS PadFone, LG® G2, LG Optimus, LG F7, LG Nexus 4. Generally speaking, although not qualified, any Android phone, tablet or phablet will work, provided it is able to run the required Android OS version. Q: What type of devices can FIREHAWK FX stream Bluetooth audio from? A: Firehawk FX can stream Bluetooth audio from any Android device, iOS device, and Mac® or PC equipped with Bluetooth. Q: What Apple® iOS devices is Firehawk Remote compatible with? A: Firehawk Remote requires iOS 8.0 and is compatible with the following iOS devices: iPhone 6s/6s Plus iPhone 6/6 Plus iPhone 5S iPhone 5C iPhone 5 iPhone 4S iPad Pro iPad Air/Air2 iPad 4 iPad 3 iPad 2 iPad mini/mini 2/mini 3/mini 4 iPod 5 Q: How do I pair my Bluetooth device with FIREHAWK FX? A: To pair the Firehawk FX with your Bluetooth device: · Enable Bluetooth on the device you would like to stream audio from. · Put the FIREHAWK FX into ˜Pairing Mode™ by pressing and holding the Bluetooth button located to the left of the FIREHAWK FX logo- it will begin to flash to indicate it is in Pairing Mode™. · Within the Bluetooth options of your device an entry for FIREHAWK FX™ will appear. · Select the FIREHAWK FX™ entry and pair with it - the Bluetooth LED will stop flashing and become solidly lit blue. Q: How do I update the FIREHAWK FX's firmware? A: We always recommend that you run the latest firmware on your FIREHAWK FX. Your FIREHAWK FX Remote application will inform you whenever a firmware update is available, so you'll always know you have the latest version! Q: What Bluetooth version is used in FIREHAWK FX? What Bluetooth codecs are supported? A: We use a Bluetooth solution that supports Bluetooth 2.1. We only support the SBC codec at this time. Q: How can I reset the FIREHAWK FX to its default settings? A: To perform a factory reset and restore the FIREHAWK FX to factory settings, press and hold the Master Volume knob and the Tap button as you power up the unit. Unfortunately, any patches not backed up to My Tones prior to the reset will be lost Q: What can I do if I am experiencing Bluetooth connectivity issues between my Bluetooth device and the FIREHAWK FX? A: For troubleshooting steps about Bluetooth connectivity and usage, check out our Bluetooth Connectivity FAQ HERE. Q: What should I do If I am experiencing connection issues with the FIREHAWK FX Remote app when I switch back and forth between apps on my iOS device? A: An important thing to note about the FIREHAWK FX Remote app functionality is that in addition to the iOS Bluetooth connection between your FIREHAWK FX and your iOS device, there is a secondary 'sync' connection between the amp and the app. Each time you minimize/close the app, the connection between the FIREHAWK FX Remote app and the FIREHAWK FX will need to be re-established, even if your iOS device is reporting that the FIREHAWK FX is connected via 'Bluetooth'. In this case, re-opening the FIREHAWK FX Remote app will automatically re-establish the connection within a few seconds. Make sure to look at the main menu of the FIREHAWK FX Remote app and wait for it to indicate that your FIREHAWK FX is 'connected' before moving forward using the app. If it does not automatically re-connect, close the FIREHAWK FX Remote app by double-tapping your iOS home key, then sliding the FIREHAWK FX Remote app window up and off the screen. Relaunch the FIREHAWK FX Remote app and it should re-sync itself with the FIREHAWK FX. Android devices usually have a function that lists all open programs where you can slide the app left or right to close it. Relaunch the FIREHAWK FX Remote app and it should re-sync itself with the hardware. Q: Can the FIREHAWK FX Remote App stream songs that are stored in the cloud and not on my mobile device? A: No. The FIREHAWK FX Remote App can only play back songs that are stored on your mobile device. Within the FIREHAWK FX Remote App settings, you can enable 'Hide Songs Not On Device' so that you only see songs that are stored on your mobile device when playing music from your Library. The Android app does not have this setting, but still only plays back songs stored on the device. Q: How can I search for a specific tone if I don't have the song or artist in my Library? A: To search for a specific tone, go to your Library within FIREHAWK FX Remote and pick any artist, then one of their albums, and then any song. This will begin to play the song and present you with a list of tones that match the song that is playing. You can then swipe down from the top of the tone list to unveil a "Search Tone Cloud™" field where you can search for an artist or song name to find tones without having the song or artist in your library. Q: Can I use the FIREHAWK FX Remote app to load or edit tone files from my other existing Line 6 products? A: The FIREHAWK FX Remote app is only compatible with tone files created with the AMPLIFi family of products. Q: Can I use the FIREHAWK FX Remote app with a Line 6 Mobile In or Sonic Port? A: No. The FIREHAWK FX Remote app is only compatible with the FIREHAWK FX pedal board. Q: What is the USB input on the back panel of FIREHAWK FX for? A: It's used to update the unit with a Windows computer, and to record to your DAW. Q: What is the Firehawk's bit rate and sample rate when used as an audio interface? A: MacOS: 24bit / 48kHz Windows : 24 bit / 44.1-96kHz Q: Where can I register my FIREHAWK FX? A: After logging into or creating a Line 6 user account HERE, you can go HERE and enter in your serial number that is found on the bottom of your FIREHAWK FX, it begins with '(21)PTM', simply fill in the remaining digits. Q: Is there a forum where I can discuss FIREHAWK FX with other FIREHAWK FX users? A: We have a forum dedicated specifically to Firehawk FX available HERE. Q: Where can I find information on the warranty that is included with the FIREHAWK FX? A: You can find all of the available information on the Firehawk FX's warranty HERE. Q: What do I if my FIREHAWK FX is in need of repair? A: You can find all of the available information on how to arrange a repair HERE.
  2. Hello! If anyone is still having trouble completing the update on an FX100, I have created a troubleshooting guide to help get you through it. Check it out here: http://line6.com/support/page/kb/_/effects-controllers/fx100/fx100-update-troubleshooting-r675
  3. Version française Deutsche Version AMPLIFi FX100 Users Manual AMPLIFi FX100 Factory Preset Chart Full List and Descriptions of AMPLIFi series Amps, Cabs, and Effects Your AMPLIFi device has a killer selection of presets to get you started on your journey to great guitar tone. The presets are organized into banks that each deliver to you a unique aspect of the AMPLIFi experience. AMPLIFi Greatest Hits: The first bank of 4 presets is designed to deliver a variety of sounds that will get you by in a pinch if you can't connect to a mobile device or footpedal. Song Based Banks: These banks are tones that match a variety of iconic guitar songs, organized by genre. Acoustic: This bank delivers a variety of sounds when using an acoustic guitar with a built-in piezo pickup system. Model Showcase: The Model Showcase banks are designed to feature particular individual amps and effects. Performance Banks: These banks each deliver a "Ready to Rock" bank tailored to specific genres. Each bank contains a basic rhythm, clean, solo boost and effected sound dialed in to work together as a bank. FX Heavy: This bank shows off some of the more esoteric and wacky capabilities of AMPLIFi. User Bank: While any patch location can be customized and overwritten, this bank offers you a blank canvas to create your own sound, or just to store some of your favorite online tonematches without disturbing the rest of the presets. AMPLIFi Factory Presets AMPLIFi: Greatest Hits 1A: Fidelity Rhythm 1B: Lead the Way 1C: American Clean 1D: Ambient Delays SONG: Classic Rock 1 2A: Heartbreaker 2B: Back in Black 2C: Life in The Fast Lane 2D: Wind Cries Mary SONG: Modern 1 3A: Everlong 3B: Locked Out of Heaven 3C: American Idiot 3D: Moves Like Jagger SONG: Pop Rock 4A: Streets Have No Name 4B: Do I Wanna Know 4C: Day Tripper 4D: Steady As She Goes SONG: Modern Metal 5A: Symphony of Destruction 5B: Woman 5C: Man in the Box 5D: The Pot SONG: Classic Rock 2 6A: Another Brick 6B: Smokin' 6C: Aint Talkin Bout Love 6D: Still Of The Night SONG: Blues 7A: Everyday I Have the Blues 7B: Right Next Door 7C: Slow Trem Blues 7D: Cold Shot SONG: Modern 2 8A: In Bloom 8B: Hysteria Octave Synth 8C: Seven Nation Army 8D: Creep SONG: Classic Metal 9A: Crazy Train 9B: Iron Man 9C: Number of the Beast 9D: Master of Puppets SONG: Clean 10A: Heartbreak Hotel 10B: Bayou Tremolo 10C: Every Breath You Take 10D: Falling Away From Me ACOUSTIC 11A: Acoustic: Rhythm 11B: Acoustic: Rhythm Chorus 11C: Acoustic: Finger Style 11D: Acoustic: Bright MODEL SHOWCASE: Hi Gain 12A: Brit J-800 12B: Tread Dual 12C: ANGEL P-Ball 12D: Line 6 Insane MODEL SHOWCASE: Effected 13A: So What Octave Synth 13B: P-Haze Octave Solo 13C: Spacy Flange 13D: Let's Go Crazy Fuzz MODEL SHOWCASE: Clean 14A: Jazz Clean w Chorus 14B: Blackface Lux 14C: Double Verb 14D: Class A-30 Top Boost MODEL SHOWCASE: Mods 15A: Machine Gun U-Vibe 15B: Layla Rotary 15C: Auto Wah 15D: Breathe In The Air MODEL SHOWCASE: Crunch 16A: Citrus D-30 16B: Super O Breakdown 16C: Bomber Uber 16D: Solo 100 Head PERFORMANCE: Rock 17A: Rock: Rhythm 17B: Rock: Clean 17C: Rock: Crunch 17D: Rock: Solo PERFORMANCE: Metal 18A: Metal: Rhythm 18B: Metal: Clean 18C: Metal: Flange 18D: Metal: Solo PERFORMANCE: Indie 19A: Indie: Rhythm 19B: Indie: Clean 19C: Indie: Lead 19D: Indie: Solo PERFORMANCE: Blues 20A: Blues: Rhythm 20B: Blues: Clean 20C: Blues: Lead 20D: Blues: Rotary PERFORMANCE: Modern 21A: Modern: Class A-30 Clean 21B: Modern: Class A-30 DDL 21C: Modern: Class A-30 Rhythm 21D: Modern: Class A-30 Push PERFORMANCE: Country 22A: Country: Clean Trem 22B: Country: Slap 22C: Country: Lead 22D: Country: Lead Boost PERFORMANCE: Jazz 23A: Jazz: Solid State 23B: Jazz: Full and Clear 23C: Jazz: Set & Match 23D: Jazz: Dirty FX HEAVY 24A: Shoeglaze Lead 24B: The Bees 24C: Seismik Synth 24D: Sample & Hold USER BANK 25A: User 1 25B: User 2 25C: User 3 25D: User 4 AMPLIFi Benutzerhandbuch Vollständige Liste der AMPLIFi FX100 Verstärker, Boxen und Effekte und deren Beschreibungen. Ihr AMPLIFi hat eine fantastische Auswahl Presets als Start für Ihre Reise zum perfekten Gitarrenton. Die Presets sind in verschiedene Banken eingeteilt welche jeweils einzigartige Aspekte des AMPLIFi darstellen. AMPLIFi Greatest Hits: Die erste Bank hat 4 Presets welche dazu entworfen wurden Ihnen auszuhelfen wenn Sie mal kein Mobilgerät oder Pedal bei sich tragen. Song Based Banks: Diese Banken sind Töne welche verschiedener einwigartiger Gitarrensongs entsprechen und organisiert sind nach Genre. Acoustic: Diese Bank liefert eine Vielzahl Sounds wenn Sie eine akustosche Gitarre mit Piezo Tonabnehmer verwenden. Model Showcase: Die Model Showcase Banken bringen bestimmte individuelle Verstärker und Effekte mit sich. Performance Banks: Diese Banken bringen Ihnen ein Ready To Rock Erlebnis. Die Banken sind auf spezifische Genres zugeschnitten. Jede Bank enthält einen standart Rythmus, einen Solo Boost und einen Effektsound. Zusammen bilden diese eine Bank. FX Heavy: Die eher esoterischen und verrückten Tonmöglichkeiten des AMPLIFi sind Kennzeichen dier Bank. User Bank: Alle vorherigen Banken können sowohl verändert als auch vollständig überschrieben werden. Die User Banken jedoch sind leer. Hier können Sie sich autoben, erstellen Sie Ihren eigenen einzigartigen Sound oder speichern Sie Ideen hier ab ohne die Presets zu beeinträchtigen. AMPLIFi’s Presets: AMPLIFi: Greatest Hits 1A: Fidelity Rhythm 1B: Lead the Way 1C: American Clean 1D: Ambient Delays SONG: Classic Rock 1 2A: Heartbreaker 2B: Back in Black 2C: Life in The Fast Lane 2D: Wind Cries Mary SONG: Modern 1 3A: Everlong 3B: Locked Out of Heaven 3C: American Idiot 3D: Moves Like Jagger SONG: Pop Rock 4A: Streets Have No Name 4B: Do I Wanna Know 4C: Day Tripper 4D: Steady As She Goes SONG: Modern Metal 5A: Symphony of Destruction 5B: Woman 5C: Man in the Box 5D: The Pot SONG: Classic Rock 2 6A: Another Brick 6B: Smokin' 6C: Aint Talkin Bout Love 6D: Still Of The Night SONG: Blues 7A: Everyday I Have the Blues 7B: Right Next Door 7C: Slow Trem Blues 7D: Cold Shot SONG: Modern 2 8A: In Bloom 8B: Hysteria Octave Synth 8C: Seven Nation Army 8D: Creep SONG: Classic Metal 9A: Crazy Train 9B: Iron Man 9C: Number of the Beast 9D: Master of Puppets SONG: Clean 10A: Heartbreak Hotel 10B: Bayou Tremolo 10C: Every Breath You Take 10D: Falling Away From Me ACOUSTIC 11A: Acoustic: Rhythm 11B: Acoustic: Rhythm Chorus 11C: Acoustic: Finger Style 11D: Acoustic: Bright MODEL SHOWCASE: Hi Gain 12A: Brit J-800 12B: Tread Dual 12C: ANGEL P-Ball 12D: Line 6 Insane MODEL SHOWCASE: Effected 13A: So What Octave Synth 13B: P-Haze Octave Solo 13C: Spacy Flange 13D: Let's Go Crazy Fuzz MODEL SHOWCASE: Clean 14A: Jazz Clean w Chorus 14B: Blackface Lux 14C: Double Verb 14D: Class A-30 Top Boost MODEL SHOWCASE: Mods 15A: Machine Gun U-Vibe 15B: Layla Rotary 15C: Auto Wah 15D: Breathe In The Air MODEL SHOWCASE: Crunch 16A: Citrus D-30 16B: Super O Breakdown 16C: Bomber Uber 16D: Solo 100 Head PERFORMANCE: Rock 17A: Rock: Rhythm 17B: Rock: Clean 17C: Rock: Crunch 17D: Rock: Solo PERFORMANCE: Metal 18A: Metal: Rhythm 18B: Metal: Clean 18C: Metal: Flange 18D: Metal: Solo PERFORMANCE: Indie 19A: Indie: Rhythm 19B: Indie: Clean 19C: Indie: Lead 19D: Indie: Solo PERFORMANCE: Blues 20A: Blues: Rhythm 20B: Blues: Clean 20C: Blues: Lead 20D: Blues: Rotary PERFORMANCE: Modern 21A: Modern: Class A-30 Clean 21B: Modern: Class A-30 DDL 21C: Modern: Class A-30 Rhythm 21D: Modern: Class A-30 Push PERFORMANCE: Country 22A: Country: Clean Trem 22B: Country: Slap 22C: Country: Lead 22D: Country: Lead Boost PERFORMANCE: Jazz 23A: Jazz: Solid State 23B: Jazz: Full and Clear 23C: Jazz: Set & Match 23D: Jazz: Dirty FX HEAVY 24A: Shoeglaze Lead 24B: The Bees 24C: Seismik Synth 24D: Sample & Hold USER BANK 25A: User 1 25B: User 2 25C: User 3 25D: User 4 AMPLIFi: Mode d’emploi Liste complète des amplificateurs, baffles et effets de l’AMPLIFi Votre appareil AMPLIFi a une fantastique sélection de presets pour vous lancer sur votre chemin pour trouver un grand son de guitare. Les presets sont organisés en banques qui vous chaque délivre un aspect unique de l’expérience AMPLIFi. AMPLIFi Greatest Hits : Cette première banque de 4 presets est conçue pour apporter une variété de sons sans avoir besoin de connecter un appareil mobile ou une pédale. Song Based Banks : Ces banques sont des tons qui correspondent à une variété de chansons de guitare célèbres. Organisé par genre. Acoustic : Ces banques sont une variété de sons si vous voulez utiliser une guitare acoustique avec un système piezo. Model Showcase : Ces banques sont destinés comme amplificateurs et effets individuels. Performance Banks : Ces banques sont prêt pour le rock et adapté à des genres spécifiques. Chaque banque contient un rythme fondamental, un propre boost solo et des sons effectués comme banque. FX Heavy : Cette banque exhibe les capacités ésotériques et farfelues de l’AMPLIFi. User Bank : Tous les banques peuvent être remplacés et personnalisés mais cette banque est prévu a cet effet. Ici vous pouvez créer vos propres sons. Vous pouvez aussi enregistrer ici sans déranger le reste de presets. List des presets: AMPLIFi: Greatest Hits 1A: Fidelity Rhythm 1B: Lead the Way 1C: American Clean 1D: Ambient Delays SONG: Classic Rock 1 2A: Heartbreaker 2B: Back in Black 2C: Life in The Fast Lane 2D: Wind Cries Mary SONG: Modern 1 3A: Everlong 3B: Locked Out of Heaven 3C: American Idiot 3D: Moves Like Jagger SONG: Pop Rock 4A: Streets Have No Name 4B: Do I Wanna Know 4C: Day Tripper 4D: Steady As She Goes SONG: Modern Metal 5A: Symphony of Destruction 5B: Woman 5C: Man in the Box 5D: The Pot SONG: Classic Rock 2 6A: Another Brick 6B: Smokin' 6C: Aint Talkin Bout Love 6D: Still Of The Night SONG: Blues 7A: Everyday I Have the Blues 7B: Right Next Door 7C: Slow Trem Blues 7D: Cold Shot SONG: Modern 2 8A: In Bloom 8B: Hysteria Octave Synth 8C: Seven Nation Army 8D: Creep SONG: Classic Metal 9A: Crazy Train 9B: Iron Man 9C: Number of the Beast 9D: Master of Puppets SONG: Clean 10A: Heartbreak Hotel 10B: Bayou Tremolo 10C: Every Breath You Take 10D: Falling Away From Me ACOUSTIC 11A: Acoustic: Rhythm 11B: Acoustic: Rhythm Chorus 11C: Acoustic: Finger Style 11D: Acoustic: Bright MODEL SHOWCASE: Hi Gain 12A: Brit J-800 12B: Tread Dual 12C: ANGEL P-Ball 12D: Line 6 Insane MODEL SHOWCASE: Effected 13A: So What Octave Synth 13B: P-Haze Octave Solo 13C: Spacy Flange 13D: Let's Go Crazy Fuzz MODEL SHOWCASE: Clean 14A: Jazz Clean w Chorus 14B: Blackface Lux 14C: Double Verb 14D: Class A-30 Top Boost MODEL SHOWCASE: Mods 15A: Machine Gun U-Vibe 15B: Layla Rotary 15C: Auto Wah 15D: Breathe In The Air MODEL SHOWCASE: Crunch 16A: Citrus D-30 16B: Super O Breakdown 16C: Bomber Uber 16D: Solo 100 Head PERFORMANCE: Rock 17A: Rock: Rhythm 17B: Rock: Clean 17C: Rock: Crunch 17D: Rock: Solo PERFORMANCE: Metal 18A: Metal: Rhythm 18B: Metal: Clean 18C: Metal: Flange 18D: Metal: Solo PERFORMANCE: Indie 19A: Indie: Rhythm 19B: Indie: Clean 19C: Indie: Lead 19D: Indie: Solo PERFORMANCE: Blues 20A: Blues: Rhythm 20B: Blues: Clean 20C: Blues: Lead 20D: Blues: Rotary PERFORMANCE: Modern 21A: Modern: Class A-30 Clean 21B: Modern: Class A-30 DDL 21C: Modern: Class A-30 Rhythm 21D: Modern: Class A-30 Push PERFORMANCE: Country 22A: Country: Clean Trem 22B: Country: Slap 22C: Country: Lead 22D: Country: Lead Boost PERFORMANCE: Jazz 23A: Jazz: Solid State 23B: Jazz: Full and Clear 23C: Jazz: Set & Match 23D: Jazz: Dirty FX HEAVY 24A: Shoeglaze Lead 24B: The Bees 24C: Seismik Synth 24D: Sample & Hold USER BANK 25A: User 1 25B: User 2 25C: User 3 25D: User 4
  4. Deutsch Français Q: How can I factory reset the AMPLIFi FX100 to its default settings? A: To perform a factory reset and restore the AMPLIFi FX100 to factory settings press and hold the Master Volume knob and the TAP switch as you power up the unit. AMPLIFi FX100 Pedal Calibration Hold down footswitch A while powering on the unit At startup the display will show "00" and footswitch D LED will be lit Press footswitch D to begin The display will change to "01" and footswitch D LED will turn off Click the pedal foot switch The display will change to "02" and footswitch D LED will be lit Move the pedal to the heel position Press footswitch D The display will change to "03" and footswitch D LED will be lit Move the pedal to the toe position (DO NOT CLICK THE SWITCH) Press footswitch D Move the foot pedal and watch the values change on the display Values will scroll from a min of 0 to a max of 99 Press the footswitch D to save the calibration values The display will change to "05" Power cycle the AMPLIFi FX100 AMPLIFi FX100 Users Manual Comment puis-je réinitialiser l’AMPLIFi FX100? Maintenez enfoncé les boutons Master Switch et TAP lors du démarrage de l’AMPLIFi. AMPLIFi FX100 : La calibration de la pédale : Maintenez enfoncé le commutateur au pied A pendant le démarrage. Sur l’écran vous pouvez voir « 00 » après le démarrage et le commutateur D est allumé. Poussez le commutateur au pied D. L’écran change, vous pouvez voir « 01 » et le commutateur D s’éteint. Poussez le bouton de la pédale. L’écran change à « 02 » et D s’allume. Mettez la pédale on position talon. Poussez le commutateur au pied D. L’écran change à « 03 » et D est allumé. Mettez la pédale en position orteil (MAIS N’APPUYEZ PAS LE BOUTON) Appuyez le commutateur au pied D et l’écran change à « 04 ». Bougez la pédale et observez le nombre qui change sur l’écran. De 0 à 99. Appuyez le commutateur D pour enregistrer la calibration. L’écran change le numéro une dernière fois. À « 05 ». Redémarrez l’AMPLIFi FX100. Mode d’emploi AMPLIFi FX100 Wie kann ich mein AMPLIFI FX100 auf Werkseinstellungen zurücksetzen? Halten Sie dazu die Master Volume und TAP Knöpfe während des Startens des Gerätes gedrückt. AMPLIFi FX100 Pedalkalibrierung: Halten Sie Fußschalter A gedrückt während Sie das Gerät einschalten. Wenn es gestartet ist sollte Ihnen „00“ auf dem Bildschirm angezeigt werden und Fußschalter D sollte leuchten. Drücken Sie den Fußschalter D. Der Bildschirm wird nun „01“ anzeigen und Fußschalter nicht mehr leuchten. Drücken Sie den Pedalknopf. Der Bildschirm wird dann nach „02“ schalten und der Fußschalter D wird wieder leuchten. Bewegen Sie das Pedal auf die Fersenposition. Drücken Sie de n Fußschalter D. Ihnen wird nun „03“ angezeigt und Fußschalter D leuchtet. Bewegen Sie das Pedal in die Zehenposition. (DRÜCKEN SIE ABER NICHT DEN KNOPF) Drücken Sie dann Fußschalter D und der Bildschirm wird auf „04“ umschalten. Bewegen Sie dann das Pedal hin und her um die Veränderung des Wertes auf dem Bildschirm zu beobachten. Diese Werte werden sich im Bereich von 0 bis 99 bewegen. Drücken Sie Fußschalter D um die Kalibrierung abzuspeichern. Der Bildschirm schaltet nun auf „05“ um. Starten Sie das Gerät jetzt neu. AMPLIFi Benutzerhandbuch
  5. Deutsche Version. Version française. AMPLIFi FX100 Setup Options Practice and jam through headphones Route AMPLIFi FX100 through your guitar amp Play through your home stereo Split the guitar and jam tracks between your amp and stereo AMPLIFi FX100 Users Manual Q: Is there a forum where I can discuss AMPLIFi FX100 setup options with other AMPLIFi FX100 users? A:We have a forum dedicated specifically to AMPLIFi FX100 available HERE. AMPLIFi FX100 Users Manual Aufstellungsbeispiele für das FX100: Üben mit einem einfachen Kopfhörer Aufbau: Mit einem Gitarrenverstärker: Angeschlossen an Lautsprecher: Teilen Sie die Songs auf in Verstärker und Lautsprecher: AMPLIFi FX100 Benutzerhandbuch Gibt es ein Forum in dem ich mich mit anderen AMPLIFi FX100 Nutzern unterhalten kann? Wir haben ein spezielles Forum nur für das FX100. HIER. Exemples de configurations FX100: Exercice et jam avec les écouteurs. AMPLIFi avec un baffle guitare. Écoute le son avec des haut-parleurs. Divise les chansons entre amplificateur et haut-parleurs. Mode d’emploi AMPLIFi FX100 Y’a t-il un forum où je peux discuter AMPLIFi FX100 ? Nous avons un seulement pour l’AMPLIFi FX100. ICI.
  6. Version française Deutsche Version AMPLIFi FX100 Users Manual Full List and Descriptions of AMPLIFi FX100 Amps, Cabs, and Effects AMPLIFi FX100 Specs 8 simultaneous effects Over 200 amps, effects, and speaker cabinets Access 100 onboard presets - and unlimited presets via AMPLIFi app Change presets and switch banks using 4 pro-quality, backlit footswitches Blootooth steaming audio for playing along with your music library (compatible with iOS, Android, Mac and PC) Rugged construction with bent metal chasis Weight: 7 lbs 6 oz Dimensions: H: 3" W: 17 3/4" D: 9 1/4" 1/4" Guitar input 1/4" Headphone output, 1/4" stereo full-range balanced outputs and 1/4" Amp output Tap tempo/tuner AMPLIFi Remote app Specs Compatible with iOS 7.0+ 70+ amps, 100+ effects and 20+ speaker cabinets 8 simultaneous effects Remotely control amp parameters to dial in your sound Automatic tone matching instantly provides the perfect tones for jamming with songs in your music library Access thousands of tones online Share and rate tones in the cloud Backup and store unlimited presets in the cloud Q: What type of devices can AMPLIFi FX100 stream Bluetooth audio from? A: AMPLIFi's high performance 5 speaker stereo design can stream Bluetooth audio from any Androidâ„¢ device, iOS device, and Mac® or PC equipped with Bluetooth. Q: How do I pair my Bluetooth device with AMPLIFi FX100? A: To pair the AMPLIFi FX100 with your Bluetooth device: Enable Bluetooth on the device you would like to stream audio from. Put the AMPLIFi FX100 into 'Pairing Mode' by pressing and holding the Bluetooth button located to the left of the AMPLIFi FX100 logo- it will begin to flash to indicate it is in 'Pairing Mode'. Within the Bluetooth options of your device an entry for 'AMPLIFi FX100' will appear. Select the 'AMPLIFi FX100' entry and pair with it - the Bluetooth LED will stop flashing and become solidly lit blue. Your AMPLIFi FX100 is now ready stream audio from your device wirelessly. Q: What Apple® iOS devices is AMPLIFi Remote compatible with? A: AMPLIFi Remote requires iOS 7.0 and is compatible with the following iOS devices: iPhone 5S iPhone 5C iPhone 5 iPhone 4S iPhone 4 iPad 4 iPad 3 iPad 2 iPad mini iPod 5 Q: Which specific Android devices are supported by AMPLIFi Remote? A: After updating the AMPLIFi FX100 firmware to 2.0 or better, AMPLIFi Remote is compatible with the following Androidâ„¢ devices: Samsung Galaxy S5 Samsung Galaxy S4 Samsung Galaxy S III Samsung Galaxy Note Pro Samsung Galaxy Note II HTC One M8 HTC One M7 Motorola Moto X Google Nexus 7 Amazon Kindle Fire HDX ASUS MeMo Pad ME176CX Asus Fonepad ASUS PadFone LG G2 LG Optimus LG F7 LG Nexus 4 Generally speaking, although not qualified, any Android phone, tablet or phablet will work, provided it is able to run the required Android OS version. Q: How do I update the AMPLIFi FX100's firmware? A: We always recommend that you run the latest firmware on your AMPLIFi FX100. Your AMPLIFi Remote application will inform you whenever a firmware update is available, so you'll always know you have the latest version! Follow the instructions HERE to update the firmware of your AMPLIFi FX100. Q: What Bluetooth version is used in AMPLIFi FX100? What Bluetooth codecs are supported? A: We use a Bluetooth solution that supports Bluetooth 2.1. We only support the SBC codec at this time. Q: How can I reset the AMPLIFi FX100 to its default settings? A: To perform a factory reset and restore the AMPLIFi FX100 to factory settings press and hold the Master Volume knob and the TAP button as you power up the unit. Q: What can I do if I am experiencing Bluetooth connectivity issues between my Bluetooth device and the AMPLIFi FX100? A: For troubleshooting steps about Bluetooth connectivity and usage check out our Bluetooth Connectivity FAQ HERE. Q:What should I do If I am experiencing connection issues with the AMPLIFi Remote app when I switch back and forth between apps on my iOS device? A: An important thing to note about the AMPLIFi Remote app functionality is that in addition to the iOS Bluetooth connection between your AMPLIFi FX100 and your iOS device, there is a secondary 'sync' connection between the amp and the app. Each time you minimize/close the app, the connection between the AMPLIFi Remote app and the AMPLIFi FX100 will need to be re-established, even if your iOS device is reporting that the AMPLIFi FX100 is connected via 'Bluetooth'. In this case, re-opening the AMPLIFi Remote app, will automatically re-establish the connection within a few seconds. Make sure to look at the main menu of the AMPLIFi Remote app and wait for it to indicate that your AMPLIFi FX100 is 'connected' before moving forward using the app. If it does not automatically re-connect, close the AMPLIFi Remote app by double-tapping your iOS home key and then sliding the AMPLIFi Remote app window up and off the screen to fully close the app. Then relaunch the AMPLIFi Remote app and it should re-sync itself with the AMPLIFi FX100. Android devices usually have a button that lists all open programs where you can slide the app left or right to close it. Then relaunch the AMPLIFi Remote app and it should re-sync itself with the amp. Q:Can the AMPLIFi Remote App stream songs that are stored in iCloud and not on my iOS device? A:The AMPLIFi Remote App can only play back songs that are stored on your iOS device. Within the AMPLIFi Remote App settings, you can enable 'Hide Songs Not On Device' so that you only see songs that are stored on your iOS device when playing music from your Library. The Android app does not have this setting, but still only plays back songs stored on the device. Q:How can I search for a specific tone if I don't have the song or artist in my Library? A: To search for a specific tone, go to your Library within AMPLIFi Remote and pick any artist, then one of their albums, and then any song. This will begin to play the song and present you with a list of tones that match the song that is playing. You can then swipe down from the top of the tone list to unveil a ‘Search Tone Cloud’ field where you can search for an artist or song name to find tones without having the song or artist in your library. Q: Can I use the AMPLIFi Remote app to load or edit tone files from my other existing Line 6 products? A: The AMPLIFi Remote app is only compatible with tone files created from the AMPLIFi FX100, AMPLIFi 75 or 150 amplifiers. Q: Can I use the AMPLIFi Remote app with a Line 6 Mobile In or Sonic Port? A: The AMPLIFi Remote app is only compatible with the AMPLIFi FX100, AMPLIFi 75 and AMPLIFi 150 amplifiers. Q: What is the USB input on the back panel of AMPLIFi FX100 for? A: At the moment, it has no function. It’s been put there for future use. Q: Where can I register my AMPLIFi FX100? A: After logging into or creating a Line 6 user account HERE, you can go HERE and enter in your serial number that is found on the bottom of your AMPLIFi FX100, it begins with '(21)PTM', simply fill in the remaining digits. Q: Is there a forum where I can discuss AMPLIFi FX100 with other AMPLIFi FX100 users? A:We have a forum dedicated specifically to AMPLIFi FX100 available HERE. Q: Where can I find information on the warranty that is included with the AMPLIFi FX100? A: You can find all of the available information on the AMPLIFi FX100's warranty HERE. Q: What do I if my AMPLIFi FX100 is in need of repair? A: You can find all of the available information on how to arrange a repair HERE. AMPLIFi FX100 Benutzerhandbuch Vollständige Liste aller AMPLIFi FX100 Verstärker, Boxen und Effekte AMPLIFi FX100 Angaben: 8 Effekte simultan. Über 200 Verstärker, Effekte und Boxen. Zugriff auf 100 Presets, welche schon enthalten sind. Zusätzlicher Zugriff auf unendlich Presets via AMPLIFi App. Presets und Banken können anhand der 4 professionellen, beleuchteten Fußschalter gewechselt werden. Bluetooth Audio Stream damit Sie mit Ihrer eigenen Musik mitspielen können. (Kompatibel mit iOS, Android, Mac und PC) Robuste Konstruktion mit gebogenem Metallchassis. Gewicht: 3.3kg Abmessungen: 7.6cm x 45.1cm x 23.5cm 6.35mm Gitarreneingang. 6.35mm Kopfhörerausgang, 6.35mm symmetrische stereo Ausgänge und ein 6.35mm Verstärker Ausgang. Tap Tempo/Tuner AMPLIFi Remote Angaben: Kompatibel mit iOS 7.0+ 70+ Verstärker, 100+ Effekte, 20+ Boxen 8 Effekte gleichzeitig. Ferngesteuerte AMPLIFi Geräte um so den Sound zu modifizieren. Automatische Klanganpassung versorgt Sie sofort mit dem perfekten Ton. Zugriff auf tausende Töne aus der Cloud. Teilen und bewerten Sie selbst Töne in der Cloud. Sichern Sie unendlich viele Presets in der Cloud. Von welcher Art Gerät kann das AMPLIFi FX100 Bluetooth Audio empfangen? Ihr AMPLIFi FX100 kann Bluetooth Audio von allen Android, iOS, Mac oder PC, die Bluetooth haben empfangen. Wie kopple ich mein AMPLIFi mit meinem Bluetooth Gerät? Schalten Sie Bluetooth auf dem Gerät an von welchem Sie Musik auf Ihr AMPLIFi übertragen wollen. Drücken und halten Sie nun den Bluetooth Knopf oben auf dem AMPLIFi, dieser sollte dann anfangen zu blinken. Jetzt sollte Ihr AMPLIFi als Gerät auftauchen. Wählen Sie nun hier das AMPILIFi aus um die Geräte zu koppeln. Der Bluetooth Knopf auf dem AMPLIFi leuchtet nun durchgehend blau. Ihr AMPLIFi kann nun Bluetooth Audio empfangen. Mit welchen Apple Produkten ist Remote kompatibel? iPhone 5S iPhone 5S iPhone 5C iPhone 5 iPhone 4S iPhone 4 iPad 4 iPad 3 iPad 2 iPad mini iPod 5 Wie kann ich die AMPLIFi FX100 Firmware aktualisieren? Wir empfehlen, die Firmware ihres AMPLIFi Verstärkers immer auf dem neuesten Stand zu haben. Ihre AMPLIFi Remote App wird Sie immer davon informieren wenn ein neues Firmware Update zur Verfügung steht. So können Sie immer sicher sein, dass Sie die neueste Firmware auf Ihrem AMPLIFi läuft. Folgen Sie dieser Anleitung zur Aktualisierung Ihres FX100. Welche Bluetooth Version verwendet das AMPLIFi FX100? Welche Bluetooth codecs werden unterstützt? Das FX100 verwendet Bluetooth 2.1 und unterstützt ausschließlich den SBC Codec. Wie kann ich das AMPLIFi FX100 auf Werkseinstellungen zurücksetzen? Um das FX100 aus Werkseinstellungen zurück zu setzen brauchen Sie nur den Master Volume Knopf und den TAP Knopf während des Startens gedrückt halten. Was kann ich tun wenn ich Bluetooth Verbingsprobleme habe? Hier geht’s zur Bluetooth Fehlerbehebung. Was kann ich tun wenn ich Verbindungsprobleme mit der AMPLIFi Remote App habe sobqld ich die App mehrmals öffne und wieder schließe? Es ist wichtig zu verstehen wie die App funktioniert in diesem Falle. Die App baut zwar eine Bluetooth Verbindung zwischen den beiden Geräten auf, hat aber auch noch eine Sync Funktion, die jedes Mal wenn Sie die App neu öffnen wieder von Neuem synchronisiert. Die Verbindung wird also auch jedes Mal wenn Sie die App minimieren und neu öffnen die BluetoothVerbindung neu aufbauen auch dann, wenn Ihr iOS Gerät anzeigt, dass es gekoppelt und verbunden ist. Im Hauptmenu der App können Sie sehen wann die Synchronisation vollständig ist.“Connected“. Sollte die App sich nicht automatisch neu verbinden sollten Sie dei App einmal volsltändig schließen, starten Sie diese dann neu und verbinden Sie erneut. Kann die AMPLIFi Remote App auch Musik aus der iCloud abspielen? Nein, die App kann nur Töne abspielen, die sich auf dem Gerät selbst befinden. In den AMPLIFi App Einstellungen können Sie die Option „Hide Songs Not On Device“ anschalten um ausschließlich Musik anzuzeigen, die sich auf dem Gerät befindet. Wie kann ich nach bestimmten Tönen suchen wenn ich den Artisten oder Song nicht in meiner Musiksammlung habe? Gehen Sie zur Library innerhalb der Remote App, wählen Sie irgend einen Artisten, Album und Song aus. Dies wird den gewählten Song abspielen und Ihnen eine Liste von Tönen anzeigen, die zum Lied passen. Gehen Sie ans Ende der Liste. Dort können Sie „Search Tone Cloud“ antippen. Hier können Sie nun nach Tönen suchen ohne Artist oder Song in der Sammlung zu haben. Kann ich mit der AMPLIFi Remote App auch andere Töne von anderen Line 6 Produkten laden und abändern? Die AMPLIFi Remote App ist ausschließlich kompatibel mit Dateien des AMPLIFi FX100, AMPLIFi 150 und AMPLIFi 75. Kann ich die AMPLIFi Remote App auch mit dem Sonic Port oder Mobile In verwenden? Nein, die AMPLIFi Remote App ist ausschließlich kompatibel mit Dateien des AMPLIFi FX100, AMPLIFi 150 und AMPLIFi 75. Wofür ist der USB Anschluss auf der Rückseite des FX100? Dieser hat momentan keine Funktion. In der Zukunft soll dieser jedoch eine Funktion zugewiesen bekommen. Wo kann ich mein FX100 registrieren? Nachdem Sie sich bei Line 6 angemeldet haben. (Benutzerkontoerstellung.) können Sie auf diese Seite klicken: Registrierung. Und dort die Seriennummer des FX100 eingeben. Die Seriennummer fängt mit (21)PTM an. Geben Sie hier einfach die fehlenden Zahlen ein. Gibt es ein Forum auf dem ich mich mit anderen AMPLIFi Nutzern unterhalten kann? Wir haben ein Forum speziell für das AMPLIFi FX100. Wo kann ich Informationen über die Garantie meines Produktes finden? Alle Informationen über Garantien können Sie HIER finden. Was kann ich tun wenn mein FX100 repariert werden muss? Alle Informationen über Raparturen können Sie HIER finden. AMPLIFi: Mode d’emploi Liste complète des amplificateurs, baffles et effets de l’AMPLIFi AMPLIFi FX100 : Spécifications : 8 effets simultanément Plus que 200 amplificateurs, effets et baffles 100 presets à bord et presets illimités avec l’application AMPLIFi Changez les Presets et changez les banques avec 4 commutateurs au pied de qualité professionnelle. Diffusion Bluetooth pour jouer en même temps que votre musique. (Compatible avec iOS, Android, Mac et PC) Construction robuste avec châssis métallique pliée. Poids : 3.3 kg Dimensions : 7.6cm x 45.1cm x 23.5cm Entrée 6.35mm (1/4 pouces) Sortie 6.35mm pour les écouteurs, des sorties symétriques stéréos et une 6.35mm sortie d’amplificateur. Tap tempo/tuner Application AMPLIFi Remote : Spécifications : Compatible avec iOS 7.0+ Plus que 70 Amplificateurs, 100 effets et 20 baffles. 8 effets simultanément. Contrôlez l’AMPLIFi à distance. La tonalité s’adapte automatiquement pour les sons parfaits pour jouer en même temps avec votre musique. Accédez milliers de tons en ligne. Partagez des tons dans le cloud. Sauvegardez et enregistrez des tons illimités dans le cloud. De quels appareils est-ce que l’AMPLIFi peut diffuser du audio Bluetooth ? AMPLIFi peut diffuser de l’audio Bluetooth de tous les appareils Android, IOS, Mac et PC qui ont des connexions Bluetooth. Comment est-ce que je peux coupler mon AMPLIFi FX100 avec un autre appareil Bluetooth ? Mettez l’AMPLIFi en mode „Pairing‘ en appuyant sur le bouton Bluetooth sur le dessus de l’AMPLIFi. Le bouton commence de clignoter que veut dire que l’AMPLIFi est en mode de couplage. Dans les options de Bluetooth de votre appareil, une entrée « AMPLIFi FX100 » s’affichera. Sélectez l’entrée « AMPLIFi FX100 » et couplez les appareils. Le LED s’arrête de clignoter et s’allume continué. Quels sont les appareils Apple iOS compatibles avec l’AMPLIFi Remote ? iPhone 5S iPhone 5C iPhone 5 iPhone 4S iPhone 4 iPad 4 iPad 3 iPad 2 iPad mini iPod 5 Comment est-ce que je peux faire une mise à jour pour le firmware de l’AMPLIFi ? Nous recommandons toujours que vous avez la version dernière du firmware de votre amplificateur AMPLIFi. Notre application AMPLIFi Remote vous informe chaque fois qu’une mise à jour de firmware est disponible. Comme ça vous savez toujours si vous avez la dernière version. Suivez les instructions ICI. Quelle version Bluetooth est-ce que l’AMPLIFi utilise ? Quels codecs sont soutenus ? L’AMPLIFi soutien Bluetooth 2.1 et uniquement le codec SBC. Comment est-ce que je peux réinitialiser l’AMPLIFi FX100 ? Maintenez le bouton Master Volume et le commutateur TAP pendant vous mettez l’appareil sous tension. Qu’est-ce que je peux faire si j’ai des problèmes de connexion Bluetooth avec mon AMPLIFi FX100? Vous pouvez trouver le dépannage Bluetooth ICI. Qu’est-ce que je peux faire si j’ai des problèmes de de connexion avec l’application AMPLIFi Remote si je bascule beaucoup entre des applications sur mon appareil iOS ? C’est important de savoir que l’application AMPLIFi Remote en plus d’établir une connexion Bluetooth avec l’AMPLIFi, il a une fonction « Sync » secondaire. À chaque fois vous minimisez ou fermez l’application, l’application doit rétablir la connexion avec l’AMPLIFi même si l’appareil rapporte que l’AMPLIFi est connecté via Bluetooth. Rouvrir l’application rétablira la connexion. Regardez à l’application AMPLIFi Remote si l’application rapporte que l’AMPLIFi FX100 est « connected », vous pouvez utiliser l’application. Si l’application ne reconnecte pas automatiquement, vous devez la fermer et rouvrir. Est-ce que l’application peut diffuser de la musique d’iCloud ? Non, l’application peut seulement jouer de la musique enregistrée sur votre appareil iOS. Dans les réglages de l’application vous pouvez activer la fonction « Hide Songs Not On Device », comme ça vous pouvez voir seulement la musique enregistré sur l’appareil iOS. Comment est-ce que je peux chercher pour on ton si je n’ai pas la chanson ou l’artiste dans ma bibliothèque ? Pour chercher un ton spécifique, cliquez la bibliothèque dans l’application Remote, choisissez un n’importe quel artiste, album et chanson. Cliquez la chanson. L’application joue la chanson et vous offre une liste de tons qui correspondent avec cette chanson. À la fin de la liste vous pouvez trouver « Search Tone Cloud » pour chercher des tons sans avoir la chanson ou l'artiste dans votre bibliothèque. Est-ce que je peux utiliser AMPLIFi Remote pour charger ou modifier des fichiers des autres produits Line6 ? L’application est uniquement compatible avec les ficher de sons créé avec l’AMPLIFi FX100, AMPLIFi 150 et AMPLIFi 75. Est-ce que ce peux utiliser l’AMPLIFi Remote avec Line 6 Mobile In ou Sonic Port ? L’application est uniquement compatible avec les ficher de sons créé avec l’AMPLIFi FX100, AMPLIFi 150 et AMPLIFi 75. Pourquoi est-ce que mon FX100 a une connexion USB ? Au moment, la connexion n’est pas utilisée. Il a été mis là pour une utilisation future. Ou est-ce que je peux registrer mon AMPLIFi FX100 ? Après vous aves créez un compte Line 6 ICI, vous pouvez cliquez ICI pour registrer votre FX100. Entrez le numéro de série que vous pouvez trouver sur le fond. La numéro commence par (21)PTM, remplissez les nombres absents. Est-ce qu’il-y en a un forum ou je peux discuter l’AMPLIFi FX100 avec autres utilisateurs de l’AMPLIFi FX100 ? Nous avons on forum en particulier pour l’AMPLIFi FX100 ICI. Où puis-je trouver des informations sur la garantie qui est inclus avec l’AMPLIFi FX100 ? Vous pouvez trouver tous les informations sur les garanties ICI. Qu’est-ce que je peux faire si mon FX100 a besoin d’une réparation ? Vous pouvez trouver tous les informations sur les réparations ICI.
  7. Nice sweeps and I really dig where you placed your Amplifi Thanks for the video!
  8. Hello, Yes, the original shortboard works with the newer Spider Valve MKII amps. Connect it as usual with the Cat5 cable and it will allow you to control preset changes and other features. Regards, Line6Drew Product Support Line 6
  9. Sounds great with the 8 string 27" scale guitar I play now and then with a Spider IV 75 or a Spider Valve MKII HD100. I play with scooped mid settings, the bass is rolled off much more since there is already so much low end from the guitar.
  10. The Spider Valve has the power to unleash fury when turning the Master knob. This is definitely true, but it can be tamed. What I do on mine is save the channel volumes of my presets to about 3-10%. This allows me to crank the master volume up over half way without blowing my ears out or upsetting neighbors. It is best to manually adjust channel volumes on all of the presets you use to prevent bursts of volume. Just take the time to go through each of them lowering the channel volume and saving the preset. If you do not save your adjustments, they will revert back to ear exploding levels when you change presets. I hope this helps, Line6Drew Product Support Line 6
  11. Hello! Winja52, I highly recommend taking the amp to a service center. +1 cgtrox and SSstormtrooper with not fiddling with it, as it is very dangerous. Here is the link to our service center finder: http://line6.com/service_centers/ have an authorized technician swap the tubes for you. Regards, Line6Drew Product Support Line 6
  12. The Spider Valve has the power to unleash fury when turning the Master knob. This is definitely true, but it can be tamed. What I do on mine is save the channel volume of my presets to about 3-10%. This allows me to crank the master volume up over half way without blowing my ears out or upsetting neighbors. It is best to manually adjust channel volumes on all of the presets you use to prevent bursts of volume. 2kewl, It sounds like your amp needs servicing. Use the link below to have an authorized technician diagnose the issue with your master knob. http://line6.com/service_centers/
