ice9mike
    133
Profile Information
  • Registered Products
    6
Recent Profile Visitors
1,347 profile views
ice9mike's Achievements
Enthusiast
Enthusiast (6/14)
  • Week One Done
  • One Month Later
  • One Year In
  • Reacting Well Rare
  • First Post Rare
Recent Badges
28
Reputation
2
Community Answers
  1. psarkissian has just posted a reply to a topic that you have subscribed to titled "Do You Have The Same Problem With 6th String?". "What you will get is a 4-6 week turnaround time for them to say "no problem found"--- Our records show the last time the guitar was here, was more like a 6-day turn around time, not 4-6 weeks. Not sure which service center did 4-6 weeks. And you did some mods to your guitar which complicated things,... but just smidge, ... and part of the reason for a couple of the failures. Someone deleted your post, but I have it in my email. I thought you were done with this thread. You are not considering the time it spent at the dealer and yes it amounts to 4-6 weeks of my time without a guitar that I payed over $1k for. The plink was present on that guitar from day 1 fresh out of the box. None of the mods (pickups and locking tuners) made any difference. Even when the guitar was returned to completely stock, the plink remained strong as ever. I even spent $200 for a professional setup to level several high frets that I thought might be the cause of the issue. It did not help with the plink, although as a regular guitar I liked it. That guitar is gone now. It gave me a sick feeling every time I turned on the modeling . It should have never made it out of your QC department. The JTVs and the lack of support are a constant source of frustration to me and many others on this thread. I recommend you go over to the gear page for the helix and see how those customers are treated. Their problems are given priority and handled with professionalism. They have a direct connection to Frank Ritchotte and Digital Igloo at Line 6 who are incredibly helpful and solve problems. I love my Helix and they are a large part of why I enjoy it. Here is the link: http://www.thegearpage.net/board/index.php?threads/line6-helix.1586637/ With over 2 million views and 27,500 replies they must be doing something right.
  2. Here's the problem Tony, the support ticket method of fixing this issue has not worked for anyone on this thread. My JTV-89F was sent in twice to headquarters with no resolution (I finally got rid of it). For anyone reading this thread. My advice, play the guitar before you buy it if possible. Listen carefully, if there is any sign of plink or weird noises, send it back. Don't screw around with the support ticket, you won't get it fixed that way. What you will get is a 4-6 week turnaround time for them to say "no problem found". Very disappointing.
  3. I'd like to know the topologies for the Mesa mk IV models.
  4. Thank you x 1000. I knew there were some caps on that board. I wonder what values they are and how many decibels Line 6 is trying to lower the signal. I am working on an experiment with my JTV-69. It is working fine with no plink, but I intend to replace the pickups with graph techs to see how they affect the tone and if they add any plink. If they cause plinking, I can add different capacitor values to see if it removes the plink. I am frustrated at the lack of progress with this issue and intend to try this little experiment to see if I can learn something. Your photos go a long way to helping me understand the issue. My hypothesis is that many (not all) of the plink issues are due to clipping that comes from the input signal amplitude. I think lowering the amplitude before it gets to the main PCB may help or eliminate the plink. I could be totally wrong here, but with no input from Line 6, we are forced to use our own methods to find solutions to the issue.
  5. I need a big favor from the JTV-89F owners. I have been trying to get a picture of the adapter PCB that converts the graph tech ghost pickups to the main PCB header interface. I have searched and searched the internets without success. Can someone with a JTV-89F please send me a picture of the adapter PCB? Please post here or DM. I want to see if there are capacitors on this PCB and what the values are. I'm trying to understand how the graph tech ghost saddles from the JTV-89F compare to the LR Baggs saddles of the 69 and 59. Ghost saddles have a much higher volume output that could contribute to this issue. Adding a capacitor in parallel for each pickup will lower the overall volume.
  6. I had my first gig with the Helix, DT25 combo, and Variax today. They all worked great together. Switching amp voicings worked perfectly through Midi commands. I will admit that setting up has been trial and error, and somewhat more involved than your average user would like it to be. But it does work and sounds fantastic. It really helps to have a midi cable interface for the DT amps to your computer. This also you to use DT Edit and change the voicings to remove any internal preamp models. This also allows customization of class, pentode/triode, and other settings. This saves you the hassle of programming these things into separate midi commands later in your Helix. You can then change voicing with one midi command. Again, this is more work than it should be for the average user. I don't mind it because I'm a guitar geek and enjoy this stuff, but at very least Line 6 should have some detailed instructions or a video to show everyone how to accomplish this. I'm really hoping for a firmware update soon that makes this much easier. It's got to be coming soon. FYI, I am the ideascale creator for the Helix/DT amp integration request. It is currently ranked 25th with 212 votes. Please vote it up if you haven't already: http://line6.ideascale.com/a/dtd/DT-amp-compatibility-for-Helix/726817-23508
  7. Mine buzzed as expected from a standard single coil. I replaced them with DiMarzio Cruisers. Very quite now.
  8. Thanks, I have checked full compass for the part, but I did not see it. It would help to have the PCB part number. Can someone with a JTV89F check the PCB part number of this part? Thanks.
  9. Does anyone know where I can get the adapter PCB that converts the graphtech piezo wire connections to the main PCB connection? This is used on a JTV89F.
  10. Just a clarification. CC#122 controls the DT amp voicing which includes topology, class A/AB, reverb, cabinet type (for direct out), etc. I too sold my HD500 once I realized how easy it was to implement the voicing selection in my Helix presets. It still would be very nice to have only one cable and automatic DT amp control. Hopefully we still get this functionality in the next firmware.
  11. Your observation was the first thing I tried when I had this problem on my 89F. The issue is not mechanical, or setup. It is PCB, or firmware related. No one at line 6 has confirmed this test or the fact that the plink is even an issue. I'm still not sure why that is. Can you imagine what would happen if the Helix introduced a similar issue? It would be fixed in a New York minute because the level of support there is fantastic. For JTV's we get the run-around, no solutions, no firmware updates, and no enhancements.
  12. I had JJ's in my DT25 for about 6 months before they blew and took one of the fuses with them. They sound great, but I don't think they work reliably in these amps. My suggestion is to keep a set of EH's on hand just in case. Also, if you have a problem with the amp hopefully there is an authorized Line 6 service center near by. We have two in Portland, Or which are both excellent.
  13. This thread is what I have been waiting for. Thanks for starting it. Great pictures too. I have been contemplating the move to Graphtechs for my JTV-69 as well. Could you filter the low band out with a low cut filter/eq in the Helix or other pedal? That should at least tell you what the crossover point and Q value need to be.
  14. I am glad it worked for you too. I think lubrication to those surfaces is critical and I don't understand why Line 6 is shipping units without it. Pedal feel is one of those things that doesn't seem important till it becomes unpleasant. It's a first world problem to be sure, but we can complain about these issues when we pay $1500.
  15. If you want smooth actuation you will have to open the bottom of the Helix, disassemble the pedal from the rest of the board and lubricate all the parts and surfaces that move. This made a world of difference for me and got rid of the annoying squeaking I had. I would caution that taking the pedal apart is best left to those that are mechanically inclined. Otherwise I'm sure a service center can do it for you easily. Digital Igloo, Have you changed you assembly instructions to add lube to this area during manufacturing? I really recommend Line 6 implement this. I could write an idealscale but it's more of a quality problem than a feature request.
