jaco_fourie Posted June 19, 2015 Share Posted June 19, 2015 Hi. My POD HD 500 X has a hiss noise and its hums to the tempo of the tap tempo. Why would it do this and how do I fix it ? Here is a video that shows what it does. https://youtu.be/mFg8CBlv940 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted June 19, 2015 Share Posted June 19, 2015 Well it sounds like you have a time based effect somewhere in your patch. The only other suggestion for now, would be a noise gate at the very beginning. It's hard to come up with any solutions until I know what your patch consists of. Quote Link to comment Share on other sites More sharing options...
jaco_fourie Posted June 19, 2015 Author Share Posted June 19, 2015 All the patches do that. Its not just one. In this case its an acoustic one. I just turned up the volume so you can hear it. Quote Link to comment Share on other sites More sharing options...
Rocco_Crocco Posted June 19, 2015 Share Posted June 19, 2015 Have you tried another guitar cable? Noise still there? What happens when you plug a cable into the input of the POD with no guitar connected? Noise still there? What happens when no cable is plugged into the input of the POD? Noise still there? Quote Link to comment Share on other sites More sharing options...
jaco_fourie Posted June 20, 2015 Author Share Posted June 20, 2015 Thanks hurghanico I removed the USB and now it is silent, but now my question is how do I use the POD for recording then? Do I just disconnect it from the PA system and use headphones ? Quote Link to comment Share on other sites More sharing options...
panaman Posted June 20, 2015 Share Posted June 20, 2015 try to use spdif, balanced outs, and/or the ground lift. try having everything on the same outlet. if mainsplugs in your country allow try turning them by 180° one by one. get a better psu for the pc Quote Link to comment Share on other sites More sharing options...
jaco_fourie Posted June 20, 2015 Author Share Posted June 20, 2015 The POD was connected to a Macbook Pro, removing the power cord did not change anything, but removing the usb did. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 20, 2015 Share Posted June 20, 2015 Now that we are that far, the big question is: is it associated with the time, with the switch, or with the light? Reboot your computer. Unplug the Pod. Try another usb cord. Change your ground settings. Change the placement of the usb/computer, as well as your guitar/pickups and cord. Quote Link to comment Share on other sites More sharing options...
jaco_fourie Posted June 23, 2015 Author Share Posted June 23, 2015 Nope. Using the headphones works 100%. also if I use a power conditioner then it is also silent. So it seems it is a ground loop. Strange that it hums with the tempo . Quote Link to comment Share on other sites More sharing options...
panaman Posted June 24, 2015 Share Posted June 24, 2015 used to happen quite frequently when i was building filters (vcf) with led strips. this is because the digital and analog ground is not separated properly, the current from the led finds a shortcut thru the ground loop. in devices with internal power supply its easy to keep grounds separate. looking at the rather thin pod power cable theres no room for separation. and the thinner, the higher ohms it gets. you could try to disconnect (cut) the shielding of the cable(s) between the pod and the amp. as long as it remains grounded on one side, the shielding will be fine and working. in case of different mains sockets not 100% recommended. and then there are the audio transformer ground insulator devices as used in cars. they may be not totally hifi, but should do for the guitar frequency range Quote Link to comment Share on other sites More sharing options...
