SirRis Posted June 23, 2015 Share Posted June 23, 2015 Hi guys!So far, I have no problems with my POD HD500X and I actually found my desired tone.. but I only noticed that as I lower the volume through my expression pedal, the gain seems to decrease too. Is that normal? I just don't find it hurting the tone especially when doing swells. Is there any way to fix it? I hope you could help, guys. TIA! Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted June 23, 2015 Share Posted June 23, 2015 (edited) It is if the VOLUME pedal is at the front of the chain before the amp. Added: Sorry I didn't answer your second question. Assuming the VOLUME pedal is only controlling volume and is not assigned as a controller to adjust the DRIVE of the amp model, then you can simply place the VOLUME pedal after the amp to control overall volume level without effecting gain/drive into the amp. Edited June 24, 2015 by edstar1960 1 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 23, 2015 Share Posted June 23, 2015 There are a lot of things that go into the perceived sound that you hear. Volume is one of them. The same thing should happen if you use the volume knob on your (external) amp. Another thing is - the placement of the pedal, as well as what the pedal is actually controlling. 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 23, 2015 Share Posted June 23, 2015 Hi guys! So far, I have no problems with my POD HD500X and I actually found my desired tone.. but I only noticed that as I lower the volume through my expression pedal, the gain seems to decrease too. Is that normal? I just don't find it hurting the tone especially when doing swells. Is there any way to fix it? I hope you could help, guys. TIA! It is if the VOLUME pedal is at the front of the chain before the amp. Exactly. Placing the VOL FX at the front of the signal chain is essentially the same as adjusting the Vol knob on the guitar. This can greatly affect the amount of gain in the tone. 1 Quote Link to comment Share on other sites More sharing options...
radatats Posted June 23, 2015 Share Posted June 23, 2015 So far, I have no problems with my POD HD500X and I actually found my desired tone.. but I only noticed that as I lower the volume through my expression pedal, the gain seems to decrease too. Is that normal? I just don't find it hurting the tone especially when doing swells. Is there any way to fix it? I hope you could help, guys. TIA! Put your volume pedal as the last thing in your chain. That way it is not changing the signal level hitting any FX or amp block after it. It will be a plain old volume pedal, gets louder or softer without affecting your tone at all. It may still SEEM like it is changing it due to the physics of sound and the Fletcher-Munson efffect... https://en.wikipedia.org/wiki/Fletcher%E2%80%93Munson_curves 1 Quote Link to comment Share on other sites More sharing options...
billlorentzen Posted June 23, 2015 Share Posted June 23, 2015 Exactly. Placing the VOL FX at the front of the signal chain is essentially the same as adjusting the Vol knob on the guitar. This can greatly affect the amount of gain in the tone. Not to nitpick, but that's not really accurate. Many guitars' electronics also attenuate highs as the volume knob is decreased. It's more like turning down the input on the amp. 1 Quote Link to comment Share on other sites More sharing options...
SirRis Posted June 25, 2015 Author Share Posted June 25, 2015 It is if the VOLUME pedal is at the front of the chain before the amp. Aaaaand you solved it. Thanks mate! Didn't know about that! Ha ha ha! Does it also work the same way when arranging analog effects in a pedalboard? Thanks again! however in this case, my favorite volume pedal FX position would be just after the amp model, and not at the end of the chain, in order to not affect abruptly also the following ambience FX (delay and reverb) trails when I turn it down to zero.. I also do like trails for swells so I did the same thing. Thanks btw! It may still SEEM like it is changing it due to the physics of sound and the Fletcher-Munson efffect... https://en.wikipedia.org/wiki/Fletcher%E2%80%93Munson_curves Thank you for a very informative answer. I wasn't into physics but that really enlightened my innocent mind. Lol! Cheers!! Quote Link to comment Share on other sites More sharing options...
