DeathDealer Posted July 30, 2015 Share Posted July 30, 2015 anyone else having problems with sound on Win10?? I have the latest drivers installed which are supposed to work, Windows even says the device is working properly in Device Manager, but I get no sound. If i go into sound properties to test the device it gives out an error "Failed to play sound test" there's nothing wrong with my PC or speakers, audio works fine with the onboard sound card, I also tried disabling the onboard sound card in case it was causing a conflict but still same results, no audio. 6 Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 30, 2015 Share Posted July 30, 2015 Are you using a Line 6 device? If so, which one? Quote Link to comment Share on other sites More sharing options...
Brazzy Posted July 30, 2015 Share Posted July 30, 2015 The only issue I have so far is SoundCloud won't playback on my KB37 Studio through Edge or Mozilla. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted July 30, 2015 Share Posted July 30, 2015 After using the Win 10 Home PC for a little more I've noticed that YouTube videos won't playback through my KB37 Studio even though it is the default sound card. The videos do however playback through the PC's speakers which are not set to be the default. I've even taken the steps to uninstall/reinstall the KB37 drivers to see if that will fix it. I can record my guitar with the KB37 and it will playback through it but so far it looks like the browsers aren't cooperating. Hopefully a fix will surface soon. Quote Link to comment Share on other sites More sharing options...
AlanFall Posted July 30, 2015 Share Posted July 30, 2015 I have the same issue, last night I Installed windows 10 and my podxt doesn't work. I get "Failed to play sound test" too. BUT when I go to cubase everything works ok within the program but when I exit there's no sound on windows. Any thoughts? Quote Link to comment Share on other sites More sharing options...
AlanFall Posted July 30, 2015 Share Posted July 30, 2015 Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the options, the one that worked for me was 16 bit 48000 dvd quality! 23 1 Quote Link to comment Share on other sites More sharing options...
Calek Posted July 30, 2015 Share Posted July 30, 2015 Just upgraded to Windows 10 as well. No sound through my Toneport UX2 with latest drivers. Tried installing through monkey and after that through manual download. It worked fine in Windows 8.1. Quote Link to comment Share on other sites More sharing options...
DeathDealer Posted July 30, 2015 Author Share Posted July 30, 2015 Are you using a Line 6 device? If so, which one? i have a Toneport Ux1...i tried uninstalling/reinstalling the drivers too, no dice 1 Quote Link to comment Share on other sites More sharing options...
mrsarun Posted July 30, 2015 Share Posted July 30, 2015 Same here, using a Toneport UX2.I get sound in my DAW, but not on sites (YT, Soundcloud, Bandcamp etc).When I activate my HDMI-sound I get sound from the tv though. Edit: Hey, I think I solved this!Go in to sound-settings -> playback. 1. Rightclick on another device (usually you have a device on the motherboard)2. Pick the option "Make default communication device (Not sure thats what it sais, not English windows here, but pick the one with "Communication")I got sound after that3. Now you can rightclick the soundcard and make it the default on both sound and communicationHope this helps!Please let us know if not :)Edit2: Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the one that worked for me was 16 bit 48000 dvd quality! It actually has to be 16bit 48000.I tried the 16bit 44000, with my "solution" but it did not work.Allthough when I had 16bit 48000 I had to do the "solution" I suggested to get sound anyway. (Guess it has something to do with multiple audiodevices) 3 Quote Link to comment Share on other sites More sharing options...
Pirranha Posted July 30, 2015 Share Posted July 30, 2015 Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the one that worked for me was 16 bit 48000 dvd quality! WOW!!! I thought, no way.... But THANK YOU!!! This Worked for me using my Toneport KB37. Thanks again!!! 2 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted July 30, 2015 Share Posted July 30, 2015 Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the one that worked for me was 16 bit 48000 dvd quality! Very Good solution!! Thanks Man. I get playback through my KB37 from SoundCloud now. I set it 16 bit 48000 dvd quality also. I would imagine YouTube and others will work now also. 1 Quote Link to comment Share on other sites More sharing options...
Flunschi Posted July 30, 2015 Share Posted July 30, 2015 Hey, I think I solved this! Go in to sound-settings -> playback. 1. Rightclick on another device (usually you have a device on the motherboard) 2. Pick the option "Make default communication device (Not sure thats what it sais, not English windows here, but pick the one with "Communication") I got sound after that 3. Now you can rightclick the soundcard and make it the default on both sound and communication Hope this helps! Please let us know if not :) Edit2: AlanFall, on 30 Jul 2015 - 10:08 AM, said: Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the one that worked for me was 16 bit 48000 dvd quality! I had the same sound problems with an UX1, but this works fine for me!! Thanks you ;) 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted July 30, 2015 Share Posted July 30, 2015 I had trouble with sound on one of the preview versions also. Sound through the video card's hdmi to my monitor worked fine, but nothing through an add-in pci-e soundcard, even though nothing indicated that anything was wrong. In fact, the little meter in playback devices was showing a signal! If I remember right, what fixed it was going into device manager, under 'Sound, video and game controllers' select the device that produces no sound, right click on it and disable it. Then enable it. This might be better if it works for you because you don't have to mess around with playback quality, which should work regardless of the setting. Quote Link to comment Share on other sites More sharing options...
Monkeyzak Posted July 30, 2015 Share Posted July 30, 2015 Will Line 6 be realeasing a new patch to fix this? I upgraded Windows 10 today and my UX2 has stopped working Quote Link to comment Share on other sites More sharing options...
mrsarun Posted July 30, 2015 Share Posted July 30, 2015 I had trouble with sound on one of the preview versions also. Sound through the video card's hdmi to my monitor worked fine, but nothing through an add-in pci-e soundcard, even though nothing indicated that anything was wrong. In fact, the little meter in playback devices was showing a signal! If I remember right, what fixed it was going into device manager, under 'Sound, video and game controllers' select the device that produces no sound, right click on it and disable it. Then enable it. This might be better if it works for you because you don't have to mess around with playback quality, which should work regardless of the setting. I did try that, did not work. Quote Link to comment Share on other sites More sharing options...
DeathDealer Posted July 30, 2015 Author Share Posted July 30, 2015 yup, setting it to "16bit 48000" works, but all other options do not, & 24bit is no longer even optional, gives an error saying the device doesn't support it...i was able to use 24bit before. i had opened a support ticket for this, hope they answer back soon so i can show them this thread if they don't know about it already & get a fix out here soon Quote Link to comment Share on other sites More sharing options...
Brazzy Posted July 30, 2015 Share Posted July 30, 2015 I hope they support Win 10. I'm having some other issues like slaving Reason Adapted & Ableton Live 8 with RiffWorks at the same time. I'm trying things out still to see what I run into as I try using compatibility modes too, lol. Quote Link to comment Share on other sites More sharing options...
ydhdwnh Posted July 31, 2015 Share Posted July 31, 2015 16 bit 48000 worked for me too. Just one added extra (which I might have missed 'cause I'm old :)) ​. After I changed the setting and so on, I had to unplug my device and plug it back in. I'm back in the game. Overall, thanks to you guys this was not a bad experience! Quote Link to comment Share on other sites More sharing options...
FunknSoul Posted July 31, 2015 Share Posted July 31, 2015 ive read through and tried the fixes, i have a pod hd desk,and worked fine with windows 8.1,ive upgraded to 10 and should just prob be patient for a fix or patch,new driver, from what i read, most o the ppl who have had success fixing this were running the audio back into their unit, i want the audio on the computer soundcard, i will note,line 6 monkey says up to date,the computer recognizes my device,im able to change settings,still no audio but in my case, I notice no input levels for device,this being the ain concern, the laptop is a gateway with realtech audio drivers, which i disabled the mic, anyone who had no input levels but fixed,let me know otherwise ill prob have to wait for fix ,and mentioning my soundcard made me realize i prob should check there too,audio wise,everything online or on comp has audio and i can hear, this seems like an input thing,using an usb,pod edit does load,but seems to me also to not have input,some ppl mentioned their daws had input audio mine does not,and ive gone through all the steps i usual go through, also tried the 4800hz dvd thing,lots of words ,i apologize ive been working on this for 5 hours, just wanted to detail as much as i could, Quote Link to comment Share on other sites More sharing options...
ozzmcom Posted July 31, 2015 Share Posted July 31, 2015 Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the options, the one that worked for me was 16 bit 48000 dvd quality! this works! thank you Quote Link to comment Share on other sites More sharing options...
illogiceyedea Posted July 31, 2015 Share Posted July 31, 2015 could you elaborate on this fix? what settings are you talking about? Quote Link to comment Share on other sites More sharing options...
DeathDealer Posted August 1, 2015 Author Share Posted August 1, 2015 could you elaborate on this fix? what settings are you talking about? your audio settings, you can access it by right clicking the speaker icon on the lower right hand corner of your desktop & choosing "playback devices" or go to your control panel & click on sound, right click your audio device go into properties & then advanced Quote Link to comment Share on other sites More sharing options...
bartoteck Posted August 1, 2015 Share Posted August 1, 2015 I did have the same problem as you (no sound with Toneport UX1) Had to change the settings to 48000hz 16-bit like you all did (but figured out myself, took about 3 hours to fix this lol). Unfortunatly like deathdealer said my device always been supporting 24-bit before and now its not even trying to work.. You guys can except another random problem on DAWs or any other software trying to use 24bit raw audio. Even audacity is failing on me, giving random audio port error. Everything works perfectly when my pod is unplugged. But once plugged audacity doesnt even want. The problem is already reported to them but the problem is obv on the line 6 drivers which needs to be updated. Please fix this soon guys im in love with my toneport, I cant live without it. I'm happy this is already reported hehe. 2 Quote Link to comment Share on other sites More sharing options...
FunknSoul Posted August 4, 2015 Share Posted August 4, 2015 no sound is still an issue,but on my audio settings recording tab,i have a level meter which usual shows input level,i have no signal registering now with upgrade to windows 10, i expect a patch eventually,but would reinstalling drivers using the properties compatibility settings to a previous windows version solve the no input,that is on the driver install for line 6 pod hd desk,the drivers for line 6 seem to be universal,and support most pedals, Quote Link to comment Share on other sites More sharing options...
Reeen Posted August 4, 2015 Share Posted August 4, 2015 Thanks dude. Also the DVD Settings helped a lot. Now it works fine. :-)​ Quote Link to comment Share on other sites More sharing options...
DeathDealer Posted August 5, 2015 Author Share Posted August 5, 2015 would reinstalling drivers using the properties compatibility settings to a previous windows version solve the no input that's a good question, why don't you try it out? Quote Link to comment Share on other sites More sharing options...
mlipping Posted August 5, 2015 Share Posted August 5, 2015 Thanks AF! Worked for me too. Thankfully as I was going a bit nuts! So is it a L6 or Win issue? Either way, I hope a patch or driver update takes care of it. Thanks again AF! M 1 Quote Link to comment Share on other sites More sharing options...
inbalance99 Posted August 6, 2015 Share Posted August 6, 2015 Worked for me, thanks. Couldn't download the windows 10 licence manager. Quote Link to comment Share on other sites More sharing options...
docguitarman Posted August 7, 2015 Share Posted August 7, 2015 I just installed windows 10 yesterday. Tried my UX1 today. -- no sound, from anything. reinstalled drivers. when I tried windows sound test I get a "failed to play test tone" Quote Link to comment Share on other sites More sharing options...
betty66653 Posted August 8, 2015 Share Posted August 8, 2015 found the solution on ux2 to get back sound go to playback devices, go to recording and right click to go to properties.then go to listen and enable listen to the device and apply; Then sound is back on windows 10 with ux2 device.Have to look for it because there was not a single refference to get sound on it. greetz elisabeth 1 Quote Link to comment Share on other sites More sharing options...
docguitarman Posted August 8, 2015 Share Posted August 8, 2015 Still can't hear audio through my ux1 interface. I can hear pod farm stand alone and plug in and record and playback in ableton. No sound from ordinary windows audio. for example no you tube audio or audio for windows sounds etc. Quote Link to comment Share on other sites More sharing options...
omahabluz Posted August 10, 2015 Share Posted August 10, 2015 I just loaded windows 10. I have UX2. I get sound ok from my guitar, however, the playback does work for my saved tracks. Any suggestions? Quote Link to comment Share on other sites More sharing options...
OmeRoon Posted August 11, 2015 Share Posted August 11, 2015 Thanks AlanFall, working here too now (PodXT)! :) 1 Quote Link to comment Share on other sites More sharing options...
murphbr00tal Posted August 12, 2015 Share Posted August 12, 2015 Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the options, the one that worked for me was 16 bit 48000 dvd quality! Thank you so much man! That worked for me:) 1 Quote Link to comment Share on other sites More sharing options...
omershimon Posted August 13, 2015 Share Posted August 13, 2015 Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the options, the one that worked for me was 16 bit 48000 dvd quality! wow. actually worked for me too. couldn't believe but works fine for me too. Thank you:) 1 Quote Link to comment Share on other sites More sharing options...
catawompus Posted August 15, 2015 Share Posted August 15, 2015 Here's my story. I have an HD 400, upgraded from Windows 8.1 to 10 and nothing worked anymore. The Pod appeared in device manager as an unknown device, trying to reinstall the driver and Pod Edit didn't help, Windows told me that the program was not migrated to the newer version. In short, my Pod didn't connect to the computer at all. Then I remember that there is a compatibility mode to run programs with lower versions of Windows, tried that, set the version to Windows 8. Result: Pod got connected immediately and works just like in Windows 7 or 8. Maybe this helps somebody else facing problems with Windows 10. Quote Link to comment Share on other sites More sharing options...
wildchild7 Posted August 18, 2015 Share Posted August 18, 2015 Found a solution! Just go to the playback devices and properties. Go the advanced tab and play with the one that worked for me was 16 bit 48000 dvd quality! Works for me with UX1 thank you 1 Quote Link to comment Share on other sites More sharing options...
mirodri2 Posted August 19, 2015 Share Posted August 19, 2015 Yup, the 16 bit 48000 DVD quality setting worked for me as well! Thanks OP!!!! 2 Quote Link to comment Share on other sites More sharing options...
JN99 Posted August 20, 2015 Share Posted August 20, 2015 None of this is working for me, I can play test tones fine but no playback of audio files or audio tracks on video. Has essentially rendered my music PC a doorstop. Any other ideas? Quote Link to comment Share on other sites More sharing options...
Duffman3012 Posted August 20, 2015 Share Posted August 20, 2015 i still cant get line 6 ux-1 to work as standalone app or vst in reaper, or monitor ux-1 via its analogue outs. headphones work though. everything is up to date. bizarre im not on windows 10 either Quote Link to comment Share on other sites More sharing options...
