Fulcrum Posted November 22, 2016 Share Posted November 22, 2016 If you are using a lot of IR's, then take screenshots of the IR panel in Helix Edit, otherwise your IR's will be put back in whatever order Helix decides! Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted November 22, 2016 Share Posted November 22, 2016 If you are using a lot of IR's, then take screenshots of the IR panel in Helix Edit, otherwise your IR's will be put back in whatever order Helix decides! I always prepend my IRs with the corresponding number of the IR slot it is in but screenshots is a good alternative. Quote Link to comment Share on other sites More sharing options...
Dshow Posted November 22, 2016 Share Posted November 22, 2016 If you are using a lot of IR's, then take screenshots of the IR panel in Helix Edit, otherwise your IR's will be put back in whatever order Helix decides! That's what I do every time before updating - it helps a lot Quote Link to comment Share on other sites More sharing options...
jroseberry Posted November 22, 2016 Share Posted November 22, 2016 I always prepend my IRs with the corresponding number of the IR slot it is in but screenshots is a good alternative. Exactly... Hopefully we'll get more IR slots and better management capabilities in the future. Quote Link to comment Share on other sites More sharing options...
willjrock Posted November 22, 2016 Share Posted November 22, 2016 Exactly... Hopefully we'll get more IR slots and better management capabilities in the future. Sheesh, IMO Thats one we shouldnt have to wait on. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted November 22, 2016 Share Posted November 22, 2016 Exactly... Hopefully we'll get more IR slots and better management capabilities in the future. Definitely hoping for better IR management. I also hope and assume I am not the first guy asking for stuff in the next firmware version on the day of the latest release. Things I would like to see happen first to improve IR implementation: Whatever mechanism L6 comes up with so that IRs can be restored with no fuss, no muss, and no renaming. Hopefully it will be using the IR name such that IRs can be restored to any slot without have to worry about your IR list's order, as long as a preset's IR is in the list somewhere. Longer name space that does not require renaming an IR so that it does not cut off critical information like 'cap', 'edge', distance from mic, etc.. Ability to handle IRs larger than 2048 (thinking this might be the most challenging one to implement by a country mile) Quote Link to comment Share on other sites More sharing options...
vrollin Posted November 23, 2016 Share Posted November 23, 2016 It would be nice if they could do a reset option that leaves the IR section alone... Quote Link to comment Share on other sites More sharing options...
spikey Posted November 23, 2016 Share Posted November 23, 2016 There just needs to be an IR mapped/saved location file, like the setlist file is handled. As long as the software can find the IR file it then maps it back to the slot. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted November 23, 2016 Share Posted November 23, 2016 There just needs to be an IR mapped/saved location file, like the setlist file is handled. As long as the software can find the IR file it then maps it back to the slot. You make a good point Spikey, I edited my post a bit because I don't care what mechanism Line6 comes up with as long as a preset is able to refer to the correct IR after an update with a minimum of hassle. I most like the suggestions that have been made that have the lookup in the preset using the name such that it does not matter which slot the IR is restored to as long as it is on the Helix. Quote Link to comment Share on other sites More sharing options...
