MaxTravelor Posted December 18, 2016 Share Posted December 18, 2016 Hello Gurus, Have a new JTV-89F connected to my HD 500X - I am getting snap crackles and pops - Signal Path: 1. 89F 2. VDI Cable - Line 6 3. Guitar to HD 500X 4. XLR Output through XLR to Roland Octa-Capture (home studio) or Church PA Mixing Board (direct) Snaps disappear as soon as I disconnect the VDI cable - I've blown out the VDI ports on my Guitar and 500X I've blown out the connections on the VDI Cable Any suggestions - Also attaching a file with an example of the issue. Thanks in advance for your help.. Merry Christmas!! Trav... SnapCrack-Pop2.mp3 Quote Link to comment Share on other sites More sharing options...
jandrio Posted December 19, 2016 Share Posted December 19, 2016 try connecting the jtv with 1/4 cable. if snaps disappear, then buy a new vdi cable. 1 Quote Link to comment Share on other sites More sharing options...
arislaf Posted December 19, 2016 Share Posted December 19, 2016 ..And if it still happens you can always sent the guitar for replacement. 1 Quote Link to comment Share on other sites More sharing options...
jandrio Posted December 19, 2016 Share Posted December 19, 2016 nico, we r ...lost in studio work, composing+recording+producing a dozen of new songs, cover lives have been postponed 4 a while :) here is a small unreleaded beta-sample (with non-english lyrics) 1 Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 19, 2016 Author Share Posted December 19, 2016 try connecting the jtv with 1/4 cable. if snaps disappear, then buy a new vdi cable. I connected my Variax to the 1/4 and the sounds go away - Problem is, the 1/4 doesn't work reliably.. I plug it in and get nothing - I'll twist all the way up and get no sound, then out of nowhere the sound will appear - I posted a separate topic on that issue - Waiting to hear from Line6 Support Ticket. :( So at least part of the issue is my VDI cable . Now if only my guitar actually worked.. I haven't been able to use it for the last 2 weekend gigs.. :( First the snapping showed up out of nowhere during the first gig, had to swap guitars, then the 1/4 stopped working or turns on and off with no rhyme as to why.. Hard to believe I paid so much for this guitar.. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted December 19, 2016 Share Posted December 19, 2016 I connected my Variax to the 1/4 and the sounds go away - Problem is, the 1/4 doesn't work reliably.. I plug it in and get nothing - I'll twist all the way up and get no sound, then out of nowhere the sound will appear - I posted a separate topic on that issue - Waiting to hear from Line6 Support Ticket. :( So at least part of the issue is my VDI cable . Now if only my guitar actually worked.. I haven't been able to use it for the last 2 weekend gigs.. :( First the snapping showed up out of nowhere during the first gig, had to swap guitars, then the 1/4 stopped working or turns on and off with no rhyme as to why.. Hard to believe I paid so much for this guitar.. "Refurbished" is Latin for "buy something else". You got a lemon. Return it if you can...it's gonna be an albatross. 1 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 19, 2016 Share Posted December 19, 2016 The ground hum at the beginning of the sound clip and the way the pops and clicks occur, I need the whole set-up on my bench,... the guitar, the VDI cable, the 500X, et al. Log a Support ticket. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 19, 2016 Share Posted December 19, 2016 The reason for using a VDI is for the connectors, as they lock snug. Standard CAT5 can jiggle causing intermittencies and transients on the supply line. CAT5e, CAT6,CAT7 are for a different and of data rate/frequencies, bringing you outside the optimum data rate for Line 6 devices. Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 20, 2016 Author Share Posted December 20, 2016 The ground hum at the beginning of the sound clip and the way the pops and clicks occur, I need the whole set-up on my bench,... the guitar, the VDI cable, the 500X, et al. Log a Support ticket. I've logged 2 tickets on this issue - Because the issue also extends to the 1/4 connector and the volume pot. Are you in Calabasas? I am in SoCal and would be happy to get my guitar fixed. Are you located in Calabasas? I've logged tickets: 291053 and 291057 - I've attached my receipt to one as request by wvolkmann - He is going to assign the ticket to the service. department.. He was responding to 291053 - 291057 hasn't been opened yet. I do appreciate you help... Trav... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 20, 2016 Share Posted December 20, 2016 "Are you in Calabasas?"--- Yes. We've seen the tickets. Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 20, 2016 Author Share Posted December 20, 2016 "Are you in Calabasas?"--- Yes. We've seen the tickets. I'm trying to get the rma. Will I be able to bring the guitar to you ? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 20, 2016 Share Posted December 20, 2016 I should get the whole set-up, so that I can isolate the problem. I can be the guitar, VDI cable, 500X or a combination of them. The whole set-up will all come to my bench. Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 20, 2016 Author Share Posted December 20, 2016 I should get the whole set-up, so that I can isolate the problem. I can be the guitar, VDI cable, 500X or a combination of them. The whole set-up will all come to my bench. My 500x is just over 1y/o. I got it 12/15/15. Will this cost extra? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 20, 2016 Share Posted December 20, 2016 I don't know that. I fix the gear. The person you've been on the ticket with will set that up. That would be worked out with him. I've made him aware that I want the whole set-up from to the 500X. I know what's wrong from listening to the audio clip,... I just have to isolate which device in the signal chain. Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 20, 2016 Author Share Posted December 20, 2016 I don't know that. I fix the gear. The person you've been on the ticket with will set that up. That would be worked out with him. I've made him aware that I want the whole set-up from to the 500X. I know what's wrong from listening to the audio clip,... I just have to isolate which device in the signal chain. You do know there's an issue with the volume pot and 1/4 output as well? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 20, 2016 Share Posted December 20, 2016 Yes. It will all get checked out and fine tooth combed through. Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 20, 2016 Author Share Posted December 20, 2016 Yes. It will all get checked out and fine tooth combed through. Got the RMA. will your shop be open 12/26? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 20, 2016 Share Posted December 20, 2016 Tuesday the 27th. Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 20, 2016 Author Share Posted December 20, 2016 Tuesday the 27th. Well I guess I'll have to figure out a way to ship it- Which is going to cost way too much.. Sheesh... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 20, 2016 Share Posted December 20, 2016 See what you can work out with the support person in the ticket. He's across the hall form me. Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 21, 2016 Author Share Posted December 21, 2016 See what you can work out with the support person in the ticket. He's across the hall form me. Part of the problem is shipping multiple boxes.. :( I asked about covering the cost of shipping.. We'll see what is next.. Either way I try to go, I'm out money, if I return it, I'm likely to get charged a 20% restocking fee.. Or spend another 20% just to get a product working that should have been working in the first place.. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted December 21, 2016 Share Posted December 21, 2016 Part of the problem is shipping multiple boxes.. :( I asked about covering the cost of shipping.. We'll see what is next.. Either way I try to go, I'm out money, if I return it, I'm likely to get charged a 20% restocking fee.. Or spend another 20% just to get a product working that should have been working in the first place.. Re-stocking fee? Merry xmas... "Refurbished" or not, it's a new purchase that you're returning because it's defective, not because you just decided you don't want it anymore. Charging a re-stocking fee under those circumstances is absurd... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 21, 2016 Share Posted December 21, 2016 Re-stock is usually with dealers. I don't know that we would have that on the L6 store. The guitar would come back to me in any case, since I'm the JTV guy here. Quote Link to comment Share on other sites More sharing options...
MaxTravelor Posted December 21, 2016 Author Share Posted December 21, 2016 Re-stock is usually with dealers. I don't know that we would have that on the L6 store. The guitar would come back to me in any case, since I'm the JTV guy here. Re-stocking fee? Merry xmas... "Refurbished" or not, it's a new purchase that you're returning because it's defective, not because you just decided you don't want it anymore. Charging a re-stocking fee under those circumstances is absurd... I purchased from L6 store and the item was shipped from GA - The Policy is that returned for defect is no restock fee - However I would have to cover the cost of shipping the guitar back to GA - Then wait for them to verify that there is a defect and then wait for them to credit my bank account. I'm taking a chance on PSarkissian and doing an RMA repair - L6 is covering the shipping and repairs and hopefully it won't take as long as it would to get a refund. Maybe I'm being too trusting of L6?? Don't know, but I do like the guitar and really would like to be able to have one to call my own.. Quote Link to comment Share on other sites More sharing options...
