Acoustic IR's w/ Variax
specracer986
I thought Richie Castellano's video sounded quite good. Don't have a Variaxe so I didn't try his presets, but you might as well.
http://line6.com/support/topic/26009-richie-castellano-variaxe-acoustic-presets/
On that video he had a pre amp block, but no amp or cab or IR. So if I want to play acoustic on a verse then change to electric for chorus, I should have a snapshot for the verse / acoustic, with just a pre amp and no amp or cab of IR?
Correct, it's easy to set up an acoustic on any preset this way!
The Variax model itself is kind of like an IR in a way... It's taking the raw input from the piezo's and doing some sort of processing (probably a mixture of convolution and filters and other proprietary stuff) to make it sound like a miced acoustic. It's kind of like when people try to run a cab model or IR though a real cab.
These acoustic IRs are created by essentially taking the difference between the impulse response of the piezo pickup and the body of the guitar. When the piezo pickup is played through the acoustic IR, the contribution of the tone from the pickup is subtracted out, leaving only the contribution from the body of the instrument. This works reasonably well because a lot of piezo pickups sound pretty similar on a lot of different guitars.
If you put a different input into the same acoustic IR, it won't work because the signal from the Variax or an electric guitar pickup is not the same as a piezo pickup. So the result will be incorrect. You'll essentially get Input source - piezo + acoustic body. This is probably not going to sound good because Input source - piezo is not zero.
