Wireless HELIX
MAN_from_IBM
Like from the amp's effects send or a line out to an input on the Helix? Yes, you could do that, although you may need to be careful about the level you're sending it. The G10 will work with a broad range of signals, but a true line level signal might cause clipping - I'm not sure. If you're talking about using more than one G10's at the same time, you just need to start with them both docked, and then un-dock the first one, let it select a channel, and then un-dock the second one.
Do you mean to connect from Helix the 1/4 in Jack output to the G10 transmitter, and then put the receiver by your amp?
There's no reason why it should not work.  It's just carrying a guitar signal - just make sure your Helix 1/4 in outs are set to Instrument level.
It works great!
Use the G10 Transmitter with Helix's 1/4" L/Mono Main Out, or, one of Helix's 1/4" FX Sends. Configure the Helix Global I/O and, Bypass, Enable, or Remove Helix's Amp and Cab Blocks according to where you plan to connect the G10's Receiver.
The G10 Receiver works into an Amp's Main Instrument In, an Amp's FX Return, or into an Amp's Aux In (with appropriate adapter).
It works great!
We think alike.
My brother from another mother. lol lol
