more than 6 effects ?
matcan67
Sorry for my english
I can create a preset with more than 6 effects and assign their position with signal flow, but how can i activate /desactivate  the blocs that are not assigned to the foot switch 1-6 ?
Thanks
You can use the same footswitch to control more than one effect to change them at the same time. But if you want control of more effects, you can use two expression pedals get control of up to 8 effects. I use one for Wah and another for UniVibe. That leaves 6 footswitches for other things.
You can assign a single footswitch to activate/deactivate multiple parameters the same way that you assigned your other effects. Or you can utilize the snapshot mode to just set what effects on each individual snapshot.
21 minutes ago, JerryWawak said:
Go to global settings and change it from 4snap/4stomp to 8 snap.  Then you hit the edit and toggle back and forth between 8 stomp and 8 snap
The OP is talking about the HX Effects. This doesn't apply.
yes in can only switch between 4 and 6 footswitch
It would be nice to be able to switch between 2 pages of effects 1>6 and 7>9
I 'm not able to activate or deactivate blocks (effects) that are not registered on switches 1-6 ... that's a shame when you use it as a stomp box...
Actually, you can change the bypass states of effects that aren't tied to footswitches. You can do it with snapshots, or you can do it by assigning the bypass for those blocks to EXP1 or EXP2. You can also assign bypass control of blocks to any MIDI CC you want.
I'm not suggesting that your problem isn't real, but I am suggesting that you may need to think outside the box. If you are used to a standard pedal board where everything is a one to one relationship it can take a different thought process to wrap your head around the possibilities with snapshots and "multi assigned switches". This new way of thinking eliminates a lot of tap dancing on stage once you get used to it. (in my opinion)
  • 2 weeks later...
Snapshots is definitely the way to go.  It's doubtful you'll use all 6 effect throughout 1 entire song so using snapshots you can turn on and off whatever you want in each snapshot.  For example....you can label the first snapshot "verse" with overdrive and a dotted 8th note delay and label snapshot 2 "chorus" and use a different overdrive and 1/4 note delay and then snapshot 3 could be labeled "bridge" and you have multiple overdrives with and 8th note delay and chorus effect.  Snapshots give you ultimate control of each effect in my opinion.
