LewisBrunton Posted September 29, 2018 Share Posted September 29, 2018 My basic setup is to have a patch with 3 snapshots (clean / rythem / lead). I then switch individual pedals in an out of each snapshot using stomp mode. Ok here goes trying to describe the problem - I run two synth blocks on a separate path from everything else as I then run the output of that path to the PA, but I need to silence the path when I turn the either synth off as I don’t want my guitar sound going to the PA. My solution was to put a gain block at the end of the path and bypass it when I turn on a synth block, then turn it on with the gain dropped to nothing when I want to block the guitar sound - but I can’t work out whether it is possible to control the same gain block from two switches. E.g. 1 all synth sounds off, no guitar can be heard through pa as gain block is set to drop volume 2 turn on 1st synth sound, gain block is bypassed 3 turn on 2nd synth sound, gain block is bypassed is what I am trying to do possible? Quote Link to comment Share on other sites More sharing options...
themetallikid Posted September 29, 2018 Share Posted September 29, 2018 I'm not sure I quite understand where the issue is coming in.... 1 - synths off (via snapshot controls), gain on (via snapshot controls) 2 - synth 1 on (via snapshot control, synth 2 remains off), gain off (via snapshot control) 3 - synth 2 on (via snapshot control, synth 1 remains off), gain off (via snapshot control) You cannot control the same effect block using two control, that I've found so far. I do the same thing where I need I need multiple instances of an effect on/off, but I end up just duplicating the block (copy/paste) and assigning each version of the block to a different bypass controller. Quote Link to comment Share on other sites More sharing options...
LewisBrunton Posted September 29, 2018 Author Share Posted September 29, 2018 The synths are not controlled as snapshots, only as stomps within snapshots (I like to have the option to turn them on with any snapshot) i did did think about duplicating the gain block but as both synth blocks are on the same path two gain blocks would block each other. Quote Link to comment Share on other sites More sharing options...
JLondon Posted September 29, 2018 Share Posted September 29, 2018 Not sure if this works without trying it but ... Put Helix into Global Stomp/Snapshot mode. Put your Synth in your chain where desired but don't include the synth in any snapshot. Then assign the synth to a stomp switch that you can turn on and off while in any snapshot (I think). Only problems with this would be that you have to remember to turn synth back off when switching to another snapshots (unless you want it to stay on) and also you would have to assign a different synth to a different stomp switch for every difference in synth setting you want to use. (I think) Quote Link to comment Share on other sites More sharing options...
LewisBrunton Posted September 29, 2018 Author Share Posted September 29, 2018 That’s what I am currently doing, that tricky bit is blocking the output of that path when both synth blocks are bypassed. Ideally when either synth is selected it would open the output. Quote Link to comment Share on other sites More sharing options...
PiFromBRC Posted September 29, 2018 Share Posted September 29, 2018 Why not just duplicate three more snapshots with the synths in an A or B state? Would seem to save a lot of DSP and still allow you to go in to stomp mode as needed. Quote Link to comment Share on other sites More sharing options...
LewisBrunton Posted September 29, 2018 Author Share Posted September 29, 2018 Because with clean / rhythm / lead snapshots allready, if I wanted to use either of the synth sounds with the existing snapshots I would need 9 snapshots in total. That is (no synth / synth 1 / synth 2) for each of the existing snapshots i would like to avoid that Quote Link to comment Share on other sites More sharing options...
patdixon Posted October 9, 2018 Share Posted October 9, 2018 On 9/29/2018 at 11:43 AM, LewisBrunton said: 1 all synth sounds off, no guitar can be heard through pa as gain block is set to drop volume 2 turn on 1st synth sound, gain block is bypassed 3 turn on 2nd synth sound, gain block is bypassed I assume this can be done with the floor unit- it can be with the LT: 1. Save the preset in this state 2. Assign synth block to one fs; gain block bypass assigned to the same fs 3. copy both blocks above, assign to a different fs but with different settings (synth 2) I do this where I have, say a drive turning on / a mod effect turning off with the same fs. It can be a little daunting but extremely effective in doing what you want to do. Hope this helps... Quote Link to comment Share on other sites More sharing options...
LewisBrunton Posted October 11, 2018 Author Share Posted October 11, 2018 Unfortunately that leaves me with the problem I was trying to avoid, a duplicate gain block, where the first gain block blocks the second. Lewis Quote Link to comment Share on other sites More sharing options...
