Jimmy_vid Posted January 12, 2019 Share Posted January 12, 2019 Hi ! I've discovered a Digitech pedal, that could be really intersting to add into Helix. The FreqOut creates natural feedback, and I really miss this on the Helix... am I the only one ?? Do you know if it's possible to create this kind of fx ? Or Line6 friends... why not to add on the Helix on next update ?? Regards !! Jimmy 3 Quote Link to comment Share on other sites More sharing options...
BAmartin Posted January 18, 2019 Share Posted January 18, 2019 Thumbs up for the Digitech Freqout... from what I`ve seen in the videos... it`ll allow me to get Steve Vai infinite sustain plus other options... and play efortless legatto once my forearms muscles start to faint... Hahaha. 3 Quote Link to comment Share on other sites More sharing options...
Jimmy_vid Posted January 23, 2019 Author Share Posted January 23, 2019 Hi @Thark !! I think I'll do the same... But why do you use Helix loop ?? Is not the same connect the guitar to FreqOut, and then to the Helix ?? Yes @BAmartin really love it !! I need it into the Helix !! ;) Quote Link to comment Share on other sites More sharing options...
Thark Posted January 23, 2019 Share Posted January 23, 2019 Hi Jimmy. My understanding of how the Freqout works is that it samples the harmonics in the signal presented to it and then decides which one to use based on how it is set up. My feeling is that if it is used the effect chain after a distortion or boost pedal the harmonic content is richer and you get a more realistic effect. Haven’t tried it prior to the boost pedal though, so I could be wrong. Anyway, assuming I’m right it would have to come after a Helix distortion via a send/return block. I’ll try a pre and post pedal setup and let you know how it goes. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted January 23, 2019 Share Posted January 23, 2019 if I have a Variax guitar, and have the preset set to tune the guitar down to D (standard guitar E string resonance)....will using the FreqOut still work for adding pleasant feedback? This has been the one reason I have not jumped on a Variax/Digitech Drop scenario is that I have a few songs where holding that note til it sustains/feedsback is just part of the song...and you just can't get there with just the pitch shift alone Quote Link to comment Share on other sites More sharing options...
Thark Posted January 24, 2019 Share Posted January 24, 2019 It isn't really feedback that the pedal is doing but rather picking up on one of the harmonics in the signal and boosting it way up. Even though there is a gain control on the pedal the 'feedback' will only last as long as there is a signal coming in to it from the guitar which means that it will die out, depending on how well the guitar string sustains. I suppose you could turn up your amp and move up close to it to induce some extra sustain but that kind of defeats the purpose of the pedal. However, I don't see any reason why it wouldn't work as it was designed for any tuning that you choose. Edit: I think I might have been wrong about the boost statement. The Freqout has a dsp in it that picks up on harmonics that it finds and synthesizes them. Quote Link to comment Share on other sites More sharing options...
TLF2007 Posted January 24, 2019 Share Posted January 24, 2019 I have a freqout and made a feedback patch in Helix that I actually gig with. Less is more. I uploaded it as "Simple Feedback". The expression pedal will control either the Wah or the feedback effect or both at the same time. 1 Quote Link to comment Share on other sites More sharing options...
themetallikid Posted January 24, 2019 Share Posted January 24, 2019 So, if I put the FreqOut in a loop, and the Digitech Drop/Variax going into the input of the Helix....I should be able to simulate an Eb/Drop C# or D/Drop C guitar feeding back, though my guitar is tuned in E Standard or Drop D. Hmm...I could also see where you'd want it controllable via expression pedal to sort of sweep it in volume/mix wise like feedback would naturally occur. Quote Link to comment Share on other sites More sharing options...
specracer986 Posted January 25, 2019 Share Posted January 25, 2019 I've considered getting a FreqOut. I haven't because I have no trouble getting feedback with my Variax / Helix / PC+ rig. I guess I play loud but all I need to do is twist a little toward the PC+ and I can control it by twisting back and forth. Quote Link to comment Share on other sites More sharing options...
codamedia Posted January 25, 2019 Share Posted January 25, 2019 Although not limited to this...the FrequOut as well as the Boss Feedbacker are both handy for guitar players that play really quiet on stage, or use in ear monitors and have zero stage volume. I'd love to see one of these two added to the effects list in the Helix. Quote Link to comment Share on other sites More sharing options...
TLF2007 Posted January 25, 2019 Share Posted January 25, 2019 The "Simple Feedback" tone I uploaded actually does this. ( Without requiring a FreqOut) but uses the expression pedal to bring the effect in and out instead of a Momentary switch. I'd like to see the community try to improve on it. 1 Quote Link to comment Share on other sites More sharing options...
halzark Posted January 26, 2019 Share Posted January 26, 2019 On 1/24/2019 at 2:48 PM, TLF2007 said: I have a freqout and made a feedback patch in Helix that I actually gig with. Less is more. I uploaded it as "Simple Feedback". The expression pedal will control either the Wah or the feedback effect or both at the same time. Where is this "uploaded" to.... I have been trying to figure out where the patches are . Sorry for newbie questions. Quote Link to comment Share on other sites More sharing options...
TLF2007 Posted January 26, 2019 Share Posted January 26, 2019 Under “customtone” 1 Quote Link to comment Share on other sites More sharing options...
Thark Posted January 26, 2019 Share Posted January 26, 2019 Cool preset, TLF2007! I'll give it a try at the next rehearsal. 1 Quote Link to comment Share on other sites More sharing options...
