SportzTawk Posted December 5, 2013 Share Posted December 5, 2013 I spent weeks and months finding the perfect tones for what I like to play. They sound AMAZING through my headphones, but are terrible through my amp or stereo, depending on what I have it plugged into. I have tried and failed to reproduce the sounds through my Line 6 Spider Jam and my stereo system, but I just can't get it to sound the same. Is there a simple way to get the sound from my headphones to translate to the outside world? I was mostly wondering if buying just a PA speaker or something... Something with no real internal settings, would give me what I am looking for. It's terribly frustrating when the sound you want can only be heard by you. Quote Link to comment Share on other sites More sharing options...
arislaf Posted December 5, 2013 Share Posted December 5, 2013 best thing to buy is the line 6 speakers, L3 or L2 depending on the output you want. Quote Link to comment Share on other sites More sharing options...
SportzTawk Posted December 5, 2013 Author Share Posted December 5, 2013 Having little experience in this kind of setup, would this give me the sound I get through my headphones? I'm assuming the reason it doesn't sound the same is because my headphones have no internal settings that alters the sound, whereas the stereo and Spider do. Am I correct in that assumption? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted December 5, 2013 Share Posted December 5, 2013 You certainly should get good sounds through your AMP or Stereo if you have the output mode set correctly. Quote Link to comment Share on other sites More sharing options...
Bushman2 Posted December 5, 2013 Share Posted December 5, 2013 I run my HD500 out the L-1/4" (mono) to a small PA set to flat eq. Since my usage is direct to a large PA at the gig, I tweak my patches using the same. My headphone out sounds quite different thru headphones. Probably due to the fact that headphones provide Stereo output and more bass proximity effect. Quote Link to comment Share on other sites More sharing options...
StephenSLR Posted December 5, 2013 Share Posted December 5, 2013 They sound AMAZING through my headphones, but are terrible through my amp or stereo, There are too many variables, you will get different tones from different speakers, the speakers in/on your ears are not the same as a speaker in a cabinet. You will have to do adjust your EQ and possibly amp, mic. and cab DEP settings. Time to do some reading: http://www.foobazaar.com/podhd/toneGuide/ s Quote Link to comment Share on other sites More sharing options...
aggravation Posted December 5, 2013 Share Posted December 5, 2013 Save your headphone presets for use with headphones and start from scratch to build presets for whatever device you want to hear them from. And build them at the volume level you plan to hear them at. Be sure to study up on output settings that are appropriate for what ever device you want to hear them with also. There is no reason you can't have presets for an amp or stereo that sound as good as the ones you have for headphones. But it is a much different listening experience too so keep that in mind. 2 Quote Link to comment Share on other sites More sharing options...
SiCantwell Posted December 6, 2013 Share Posted December 6, 2013 I try to get them as close to what I want as I can in my living room, then tweak on the fly during full-volume practice with the band, or occasionally during gigs. Sometimes a patch that sounds killer at home is weak, thin, too echoey, whatever with the band. Then it's back to the drawing board. But the number of good patches will grow over time. Good thing I like tinkering around with amps and effects. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted December 6, 2013 Share Posted December 6, 2013 ........... Sometimes a patch that sounds killer at home is weak, thin, too echoey, whatever with the band. Then it's back to the drawing board. ......... Interesting you should say this - I have the same problem - what do you adjust to get the "thin" sounds sounding correct at band performance level? Thanks. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted December 6, 2013 Share Posted December 6, 2013 Save your headphone presets for use with headphones and start from scratch to build presets for whatever device you want to hear them from. And build them at the volume level you plan to hear them at. Be sure to study up on output settings that are appropriate for what ever device you want to hear them with also. There is no reason you can't have presets for an amp or stereo that sound as good as the ones you have for headphones. But it is a much different listening experience too so keep that in mind. +1 - good advice Quote Link to comment Share on other sites More sharing options...
joel_brown Posted December 6, 2013 Share Posted December 6, 2013 Do you have the PODHD set to Studio/Direct for the output ? Quote Link to comment Share on other sites More sharing options...
bjnette Posted December 7, 2013 Share Posted December 7, 2013 One thing that catches me out still are those experimental patches where you try out different distortion of a combo of compressors, distortion etc before the amp. For this reason I am a firm on insisting if there ever was an update it should have a peakmeter on every page. If your tone sounds overly brittle, piercing, overbright, check your FX chain for too many gain stages on which might sound okay via monitors or headphones but an amp exacerbates. Recording has the advantage of seeing meter levels. I thought about this led meter kit here http://www.diyrecordingequipment.com/projects/paia-k89-stereo-led-vu-meter-kit/ But and there are plenty, it requires pretty good knowledge to hack into your HD. This is a kit for the headphone output.jack (scroll down to VU meter kit) http://www.jlmaudio.com/shop/index.php?_a=viewCat&catId=9 There is no doubt a meter calibrated correctly would keep you in the zone but I doubt it could be made to work without a whole lotta volume matching going on considering the master volume controls the analogue and h'phone outs. Quote Link to comment Share on other sites More sharing options...
SiCantwell Posted December 7, 2013 Share Posted December 7, 2013 Interesting you should say this - I have the same problem - what do you adjust to get the "thin" sounds sounding correct at band performance level? Thanks. Hard to say, but generally boosting the mids and backing off a tad on the drive helps some. Or maybe trash the whole patch and try again. I usually have some sound in mind, and there's more than one way to get there -- different FX, different amps, etc. I've been strugging with a "crunchy" patch forever -- somewhere between clean and Van Halen. I've settled on a Bogner with gain around 45%, bass and mid higher than the treble, and presence down around 35%. I'll see at practice tomorrow night whether I hit paydirt. Quote Link to comment Share on other sites More sharing options...
tomb68 Posted December 7, 2013 Share Posted December 7, 2013 Save your headphone presets for use with headphones and start from scratch to build presets for whatever device you want to hear them from. And build them at the volume level you plan to hear them at. Be sure to study up on output settings that are appropriate for what ever device you want to hear them with also. There is no reason you can't have presets for an amp or stereo that sound as good as the ones you have for headphones. But it is a much different listening experience too so keep that in mind. +2 This is a good approach and has worked well for me. Quote Link to comment Share on other sites More sharing options...
tomb68 Posted December 7, 2013 Share Posted December 7, 2013 I spent weeks and months finding the perfect tones for what I like to play. They sound AMAZING through my headphones, but are terrible through my amp or stereo, depending on what I have it plugged into. I have tried and failed to reproduce the sounds through my Line 6 Spider Jam and my stereo system, but I just can't get it to sound the same. Is there a simple way to get the sound from my headphones to translate to the outside world? I was mostly wondering if buying just a PA speaker or something... Something with no real internal settings, would give me what I am looking for. It's terribly frustrating when the sound you want can only be heard by you. What input on the Spider Jam are you using to connect your POD? I'm not terribly familiar with that amp, but an input that bypasses the preamp/eq etc. would be optimal. • Mini stereo MP3/CD input for playing along with your music • XLR mic input with a dedicated volume knob perfect for vocals • 1/4" aux input perfect for a second instrument including keyboard or bass You may want to start with the AUX and go from there, if you aren't already. Quote Link to comment Share on other sites More sharing options...
