rwinking Posted July 24, 2019 Share Posted July 24, 2019 HAS ANYONE EXPERIENCED ANY LATENCY ISSUES WITH NATIVE 1.8? I HAVE. I'M USING PROTOOLS AND SINCE UPDATING TO 1.8 THERE IS A MAJOR LATENCY PROBLEM. I GO INTO PROTOOLS AND CHANGE THE BUFFER SIZE DOWN TO 32 SAMPLES AND STILL GET LATENCY. IT STARTED RIGHT AFTER THE UPDATE. THANKS Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 24, 2019 Share Posted July 24, 2019 No problems in Reaper. Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 26, 2019 Share Posted July 26, 2019 On 7/23/2019 at 8:08 PM, rwinking said: IT STARTED RIGHT AFTER THE UPDATE. Troubleshooting 101.... roll it back and see if the problem goes away, then bring it back to 1.8 to see if it returns. I'm not suggesting your problem doesn't exist... I'm just suggesting you run a couple more tests to make sure :) Quote Link to comment Share on other sites More sharing options...
zolko60 Posted July 26, 2019 Share Posted July 26, 2019 What latency HxN 1.8 is reporting in PT? What makes you think changing buffer size affects the latency caused by plugins? Helix Native 1.71 AAX version reports 16 samples of latency (checked at 48kHz) and PT 12.5 Windows on ASIO drivers set this value for latency compensation. Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 26, 2019 Share Posted July 26, 2019 NO NEED TO SHOUT! What interface are you using? 1 Quote Link to comment Share on other sites More sharing options...
rwinking Posted July 27, 2019 Author Share Posted July 27, 2019 I’m using Antelope Zen. Sorry for yelling. I play rock and roll and my ears are bad....... 2 Quote Link to comment Share on other sites More sharing options...
zolko60 Posted July 27, 2019 Share Posted July 27, 2019 18 hours ago, phil_m said: What interface are you using? 4 hours ago, rwinking said: I’m using Antelope Zen. What makes you think guys an interface is relevant? Antelope Zen Tour RTL is 2,5ms Thunderbold and 5ms USB (@44kHz 32 smpl buffer) and 12/15ms at 256 buffer. What is Hx Native 1.8 latency? Quote Link to comment Share on other sites More sharing options...
