Repeated custom tones.
elcosomalo
Hi Guys!, this is more like a little rant.  I´ve been wandering in the custom tone catalog for the HX Stomp and found that those 802 tones are not that real in numbers...
I see lots of repeated tones I mean, the same tone, same name, same authors; the exact same tone repeated a lot of times.
For example, I´ve been seeing this "Mayer'ishStomp"  from jaysadites repeated at least 1 time in every page for about 8 + pages.
I´m not saying the user is spamming, but we clearly need some maintenance on the database to remove duplicates.
Have you seen duplicates too?
Regards
i put some thing(s) in a long time ago and I seem to remember I wasn't sure at first and put at least one up that I didn't want to but there was NO way to delete it (them). That was awhile ago though. Maybe something like that happened.
Helix user, but the few times I've gone there I see multiple repeats in the first few panels and bail.  When I have downloaded presets of value from there it has come from YouTube videos with links usually.  I see it as more of a repository but not a good index of them.
12 hours ago, madmax49 said:
I followed your link to "Mayer'ishStomp and only see 2 from  user "jaysadites ". One was for the stomp and one for the Helix floor.
There was another "Mayer'ishStomp" but it was from a different user.
Try this: go to the custom tones, order by rating, browse from page 6 to 9. You will see that tone repeated. You will also see some "SLASH" tones repeated.
I tried this and I am not seeing what you're talking about. You can highlight the exact web page then copy and paste it here.
Try this: https://line6.com/customtone/browse/hx_stomp/6/?sort=rating&sort_dir=desc&search_term=
Take a look, you should see  "Mayer'ishStomp" in pages 6 to 9 (also in the first one).
Then using the same page as it is look for "SLASH" tone you will find it a couple of times (not in 6 to 9, you have to look for it in other pages)
Also "Every Breath" from user "jery1001"  is repeated in pages 26 to 34.
These are just examples, I´m sure the custom tones section is full of dups.
Line6 should run a duplicate clean in that database and I´m sure that we will be going from 802 tones to 302 tones.
4 hours ago, DunedinDragon said:
Well heck...by the time you've gone through researching how many  things were dup'd you could have easily built your own preset....
Actually took me 2 minutes by opening the webpage, browsing tones and seeing the same tones over and over again. No rocket science.
