thetragichippy Posted May 25, 2020 Share Posted May 25, 2020 Anyone use volume pedal on GO POD and notice it works, volume gets softer until all the way back and It goes back to normal. Any fix to this, I would like to silent my guitar by using volume pedal Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 26, 2020 Share Posted May 26, 2020 Are you talking about the on-board expression pedal or an external pedal? Quote Link to comment Share on other sites More sharing options...
thetragichippy Posted May 26, 2020 Author Share Posted May 26, 2020 35 minutes ago, phil_m said: Are you talking about the on-board expression pedal or an external pedal? The internal (one that come with the POD GO. When I back all the way off, it come back on to normal volume. Quote Link to comment Share on other sites More sharing options...
thetragichippy Posted May 26, 2020 Author Share Posted May 26, 2020 I FIGURED IT OUT.....I had the dang thing off and not on EXP toe..... Quote Link to comment Share on other sites More sharing options...
Dimaension_X Posted May 29, 2020 Share Posted May 29, 2020 I have noticed that the last few Factory Presets (the ones with the spacey reverb and delay sounds - I don't have my POD Go on right now, so I don't remember the names of the presets) have an issue with the volume pedal, where it does not seem to affect the presets at all. Anyone else noticed that? I'm guessing it might be due to the DSP not having enough RAM to include the Volume pedal in the preset? I could be wrong. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 29, 2020 Share Posted May 29, 2020 2 hours ago, Dimaension_X said: I have noticed that the last few Factory Presets (the ones with the spacey reverb and delay sounds - I don't have my POD Go on right now, so I don't remember the names of the presets) have an issue with the volume pedal, where it does not seem to affect the presets at all. Anyone else noticed that? I'm guessing it might be due to the DSP not having enough RAM to include the Volume pedal in the preset? I could be wrong. I've checked on my POD Go and I don't see this behaviour. The VOL pedal works on the later factory presets unless you manually turn it off. I do notice that these presets are very heavily effected, as you say. This causes the change in VOL pedal position to be less noticeable and somewhat delayed, but it's working for me. Press the pedal to full heel position and wait a few seconds; the sound disappears. A VOL pedal consumes very little DSP - that's not an issue. Quote Link to comment Share on other sites More sharing options...
Dimaension_X Posted June 1, 2020 Share Posted June 1, 2020 @ silverhead OK - I'll check it out - thanks! Quote Link to comment Share on other sites More sharing options...
miami_vice Posted June 2, 2020 Share Posted June 2, 2020 I don't find that I'm getting a smooth volume sweep through the motion of the pedal. I feel like I'm getting full volume, full volume, pretty much full volume, and nothing as I go from top to bottom. Any settings to try? Quote Link to comment Share on other sites More sharing options...
malhavok Posted June 3, 2020 Share Posted June 3, 2020 @miami_vice try moving the volume pedal later in the chain. Especially after drives or after the amp. Put it on logarithmic sweep instead of linear. Quote Link to comment Share on other sites More sharing options...
oldscratch13 Posted June 5, 2020 Share Posted June 5, 2020 Good morning- I recently got a Pod Go- I love it. However, when the wah is switched ON, all the lights blink and the sound cuts out for a second about 1/3 through a pedal rock. Also, Is there a way to switch the wah off when in volume pedal mode? Please assist Thanks so much Quote Link to comment Share on other sites More sharing options...
darrendowler Posted October 10, 2021 Share Posted October 10, 2021 I am having a volume pedal issue. I just got the unit and I've tried EVERYTHING but no matter what I do the volume pedal only goes from 97% to 100%. I've changed the range, restored to factory, done preset restore, everything. I've put it on position, turned it on and off. I cannot get the volume pedal working. I'm wondering if my unit might be faulty. There are no vids I can find on just adjusting the volume pedal. ANYBODY? IDEAS? THANKS IN ADVANCE. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted October 11, 2021 Share Posted October 11, 2021 On 10/10/2021 at 1:48 AM, darrendowler said: I am having a volume pedal issue. I just got the unit and I've tried EVERYTHING but no matter what I do the volume pedal only goes from 97% to 100%. I've changed the range, restored to factory, done preset restore, everything. I've put it on position, turned it on and off. I cannot get the volume pedal working. I'm wondering if my unit might be faulty. There are no vids I can find on just adjusting the volume pedal. ANYBODY? IDEAS? THANKS IN ADVANCE. What firmware version are you on? If not on v1.30, I recommend you update. If you are, suggest you log a ticket with Line 6 Customer Service & send them a full backup to see if they can identify/replicate & fix the problem. Quote Link to comment Share on other sites More sharing options...
