clivea Posted June 6, 2020 Share Posted June 6, 2020 Re: POD HD PRO X I have my guitar, speakers/monitors volumes on full, therefore I would expect the guitar to be BLASTING out, but I'm only getting a really low output. The Pod Volume and Master settings are on full and the gain is on 48%. What could be causing this? I've had my Pod only 4 weeks and I can't seem to get it set up correctly - really frustrating! Quote Link to comment Share on other sites More sharing options...
hurghanico Posted June 6, 2020 Share Posted June 6, 2020 You posted your question in the wrong forum, there is another forum dedicated to the POD HD series.. However, back to your question, make sure the OUTPUT LEVEL switch (the one related to the outputs you are using) on the rear panel of your POD is set to LINE _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 6, 2020 Share Posted June 6, 2020 .... moved to proper forum..... Quote Link to comment Share on other sites More sharing options...
joel_brown Posted June 6, 2020 Share Posted June 6, 2020 I thought this was the forum dedicated to the PODHD series ? Quote Link to comment Share on other sites More sharing options...
clivea Posted June 6, 2020 Author Share Posted June 6, 2020 Me too! Quote Link to comment Share on other sites More sharing options...
clivea Posted June 6, 2020 Author Share Posted June 6, 2020 1 hour ago, hurghanico said: You posted your question in the wrong forum, there is another forum dedicated to the POD HD series.. However, back to your question, make sure the OUTPUT LEVEL switch (the one related to the outputs you are using) on the rear panel of your POD is set to LINE _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips It is set to 'LINE' Quote Link to comment Share on other sites More sharing options...
hurghanico Posted June 6, 2020 Share Posted June 6, 2020 1 hour ago, joel_brown said: I thought this was the forum dedicated to the PODHD series ? ..the previous silverhead post should be a clear sign that the OP was in a forum other than this, before being moved here.. give a look here: https://line6.com/support/forum/20-pod-20-pod-xt-pocket-pod-floorpods/ _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
hurghanico Posted June 6, 2020 Share Posted June 6, 2020 17 minutes ago, clivea said: It is set to 'LINE' If so, the problem is elsewhere... Does the headphones output work fine?..If yes, try to connect the headphones output to your monitors (the headphones output is a little hotter than the standard output). If you still get low volume, then it means that your monitors need some checking. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
stormstudios Posted June 6, 2020 Share Posted June 6, 2020 Is the volume level issue just the guitar output? What is the volume like for for USB output from the computer? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 6, 2020 Share Posted June 6, 2020 just to toss this out there... 6 hours ago, clivea said: The Pod Volume and Master settings are on full and the gain is on 48%. With the exception of the Master Volume, the knobs on the unit mean absolutely nothing. Quote Link to comment Share on other sites More sharing options...
clivea Posted June 7, 2020 Author Share Posted June 7, 2020 hurghanico - monitors ok 'cos it's the same with my PA stormstudios - the computer level is on max Quote Link to comment Share on other sites More sharing options...
hurghanico Posted June 7, 2020 Share Posted June 7, 2020 10 minutes ago, clivea said: hurghanico - monitors ok 'cos it's the same with my PA stormstudios - the computer level is on max If your unit is connected to the computer, open the Line6 audio driver and make sure the Hardware Monitor Level is full up. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
clivea Posted June 7, 2020 Author Share Posted June 7, 2020 Checked this and find that the levels are at maximum, as your image Quote Link to comment Share on other sites More sharing options...
daveny5 Posted June 7, 2020 Share Posted June 7, 2020 Are you using the Balanced or Unbalanced outputs? Use the Unbalanced output if you're using a standard guitar cable or the Balanced output if you have a TRS cable. You can tell the difference between the two because the Unbalanced cable has only one plastic ring on the tip of the plug and a Balanced will have two. You should not be using the S/PDIF outputs. If you're using the Line output setting, that means you're connecting it to a mixer or recorder. Set it to Amp if you are connecting it to an amplifier. Also, try switching the Line Input level switch from -10 to +4. Also, make sure you have a preamp included in your settings. The output of guitar pickups is very low, so you need a preamp in the chain to get the level up to line level which then feeds the amplifier. For future reference, it will really help if you tell us what equipment you have and how they're connected. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 7, 2020 Share Posted June 7, 2020 I believe we are getting no where fast. So, can we start all over. This time, with more specifics. Because simply saying "I turn on my device and it isn't loud enough" doesn't really tell us anything. Quote Link to comment Share on other sites More sharing options...
clivea Posted June 8, 2020 Author Share Posted June 8, 2020 Ok - so here's my chain .... guitar > line 6 Relay G50 wireless > Pod HD ProX, guitar input (front) > I am using an Alesis Quadraverb+, loaded with 'Echoes from the Past', linked up to the Pod by the 4 cable method > out of the Pod unbalanced outputs L+R > Behringer UMC 202HD interface, inputs 1/2 > into monitors or PA system .... usb into laptop for recording. Hope this helps Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 8, 2020 Share Posted June 8, 2020 OK, good. much easier now. Unplug everything from the Pod. Including the wireless. Plug your guitar into the pod. Plug Pod into a guitar amp. Play guitar. Change patches. Create patches. Change system settings. What happens. Quote Link to comment Share on other sites More sharing options...
clivea Posted June 9, 2020 Author Share Posted June 9, 2020 I'm afraid I don't have an amp Quote Link to comment Share on other sites More sharing options...
hurghanico Posted June 9, 2020 Share Posted June 9, 2020 4 hours ago, clivea said: I'm afraid I don't have an amp Do what pianoguyy said, but connect instead the POD (directly) to your monitor. Then report back what happens. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 9, 2020 Share Posted June 9, 2020 the reason I said a guitar amp is because it would be the easiest... a simple 1/4" jack. headphones, monitors, and usb all have 'this and that' but, yes, do what hurghanico said - connect it directly to your whatever. and then do what I said - play guitar: change patches, edit patches, change system settings Quote Link to comment Share on other sites More sharing options...
clivea Posted June 9, 2020 Author Share Posted June 9, 2020 I have done as you suggest, but the low guitar volume is the same Quote Link to comment Share on other sites More sharing options...
hurghanico Posted June 9, 2020 Share Posted June 9, 2020 23 minutes ago, clivea said: I have done as you suggest, but the low guitar volume is the same Which monitor do you have? Are there mic/line switches? _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted June 9, 2020 Share Posted June 9, 2020 5 hours ago, clivea said: I have done as you suggest, but the low guitar volume is the same take the unit back. it is either defective or too complicated for you Quote Link to comment Share on other sites More sharing options...
