bamm14
Aux in?
How do I run music through my pod go so it will come through my speaker? I’m not seeing an aux in anywhere?
  • Thanks 1
You'll need to connect the USB and run the audio through that as your soundcard. Then you'll get both the music and the sound of you playing guitar.
If you set Global Settings > Ins/Outs > Return Type to "Aux In" you can use the RETURN/AUX input as a stereo Aux In. It's even silkscreened that way.
On 5/29/2020 at 12:16 PM, silverhead said:
The different shading reflects different modeling technology. The darker colours indicate models based on the latest Helix technology and the lighter colours indicate older technology. So the 70's Chorus uses Helix modeling on the BOSS CE-1 while the Analog Chorus uses older technology to model the same BOSS pedal..
If you do it this way, I'm guessing you'd want to put your Send/Return at the end of your signal chain so it wouldn't have any effects applied to it, correct?
Nope, you don't have to worry about it at all. When Global Setting > Ins/Outs > Return Type is set to "Aux In," POD Go routes it post-processing for all presets. You can just ignore the FX Loop block at that point.
WOW that's neat! I will need an ⅛" to ¼" converter, but that's definitely not of any issue. I'm impressed the POD Go got us covered again!
Does it mean, that I can send backing track to this AUX IN and jam with it using headphones or external speaker (monitor)?
Yes
39 minutes ago, weitzhandler said:
Yes
Thats good news! I have Mooer GE200, not satisfied at all. Getting Pod Go stopped me by absent of drum machine, but looks like solution is there...)
