willyjacksonjs22 Posted March 18, 2021 Share Posted March 18, 2021 With plugins it’s easy but with The hx stomp I can’t edit while listening to a recorded guitar track. Quote Link to comment Share on other sites More sharing options...
tjbassoon Posted March 18, 2021 Share Posted March 18, 2021 What you're probably looking to do is called "reamp" You essentially run your guitar clean into the DAW, then run the track in and out through the hardware you want to reamp. You have to let the track play through the effects pedal in real time and usually you do this to make new track with the effects baked in. 2 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 18, 2021 Share Posted March 18, 2021 What, exactly, are you trying to do? In what DAW? Quote Link to comment Share on other sites More sharing options...
willyjacksonjs22 Posted March 19, 2021 Author Share Posted March 19, 2021 4 hours ago, rd2rk said: What, exactly, are you trying to do? In what DAW? On reaper when I record a guitar riff with Amplitube or Native I can edit the amp settings while listening to it so I can adjust somethings I don’t like in real time but on the hx stomp I can’t do that. Well I’m able to do it if monitoring on is selected but the tone is thin. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 19, 2021 Share Posted March 19, 2021 As @tjbassoon said, you need to record a DI track along with your processed track, then play it back through the HXS and adjust to your heart's content! When you get the sound you want, record it to a new track. You'll then have the original processed track and the edited track to compare. It's called "re-amping". See page 56 of the 3.0 manual for the How-To. Or, if you bought your HXS new (or the previous owner didn't exercise the option), you can get NATIVE for $99 and do it ITB. 3 Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 19, 2021 Share Posted March 19, 2021 8 hours ago, willyjacksonjs22 said: On reaper when I record a guitar riff with Amplitube or Native I can edit the amp settings while listening to it so I can adjust somethings I don’t like in real time but on the hx stomp I can’t do that. Well I’m able to do it if monitoring on is selected but the tone is thin. As with the previous replies above, but this is additional insight - Hope it helps! 1 Quote Link to comment Share on other sites More sharing options...
TRENDKILLCFH333 Posted March 21, 2021 Share Posted March 21, 2021 Look into Native. You should be able to do what you're describing and then save the setting into your HX Stomp for live use. Quote Link to comment Share on other sites More sharing options...
soundog Posted March 22, 2021 Share Posted March 22, 2021 BONUS! Native is 30% off until the end of the month. So if you're eligible for the $99 deal (via hardware purchase), you can grab it for $70. 1 Quote Link to comment Share on other sites More sharing options...
