gnomus Posted April 4, 2021 Share Posted April 4, 2021 I’ve owned my Helix for a number of years and it has never given me any issues until I had the 3.01 update. I don’t know if the update is the cause of my problem - it could be entirely co-incidental. A couple of days after the update, I noticed that I was getting no sound out of the Helix. All my patches were there, I could connect to HX Edit and I could build new presets. But it seemed that there was no signal getting from my guitar into the Helix. I tried different leads (and different guitars) to no avail. I noted that when I put the unit into Tuner mode, that it was not receiving any signal either. I contacted Line 6 Support who suggested that I redo the firmware update using the updater software, rather than HX Edit. And lo and behold this worked. But, within a couple of days, it lost input again. Line 6 had already had me try different inputs like using a Return jack. But that didn’t work. I should also note that I did several resets. It seems that sometimes a reinstallation of firmware and a factory reset will bring it back online again, but this only lasts for a day or so. I’ve seen a couple of people report this problem before, but I don’t think I’ve seen it solved. One suggestion was that it might be a corrupted user preset. But, after the issue, I did not reload my old presets. I simply built a couple of new ones from scratch to test the unit. Line 6 eventually suggested that I sent the unit for servicing. I’m in the UK, so off it went to E&M in Milton Keynes. I had to pay a significant amount by way of an inspection fee. And, of course, it costs a chunk to send the unit. E&M had the unit for several days. I contacted them to check progress. I was told that they had done a factory reset and that the unit was functioning normally. I was a little sceptical since I had already performed a number of factory resets, but I was assured that the unit had been powered on and off several times and that no fault could be detected. I shipped the unit back. It worked for around 48 hours and now it is non-functional again, which is more than a little frustrating given that I am currently down the best part of £110. I assume that E&M will offer to take another look. But each return journey means £50 in shipping charges, so it won’t take too many trips for this to become uneconomic. So, before doing that, I thought I’d ask whether anyone here had any knowledge of this issue, or had any suggestions before I proceed. Thanks in anticipation of your assistance. Steve M Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 4, 2021 Share Posted April 4, 2021 3 hours ago, gnomus said: I’m in the UK, so off it went to E&M in Milton Keynes. I had to pay a significant amount by way of an inspection fee. Hi, This seems to be a very strange thing to be happening, and not something that I have encountered, but I have used E&M for a repair and found them to be very good. As I recall the “inspection fee” came off the total price of the repair. Not only that, I understand that any repair they make should be guaranteed for at least 3 months. The best recourse would be to contact E&M to explain and discuss the situation with them. As the repair only lasted for 48 hours, then possibly the fault was misdiagnosed. Should that not be resolved, then if absolutely necessary, you could contact your local Trading Standards Office for a professional opinion on how to proceed from there. Hope this help/makes sense. Quote Link to comment Share on other sites More sharing options...
gnomus Posted April 5, 2021 Author Share Posted April 5, 2021 Thanks datacommando. It is a very odd problem (but I'm not the only one to have had it - for example https://line6.com/support/topic/27282-no-input-on-helix-lt-loses-all-sound/). I've never used E&M before. They seemed helpful enough on the telephone. Furthermore, as you say, the inspection fee would have come off any repair cost, but all that they did was do a factory reset - something I had already done. Sometimes with these electronics guys, one does get the impression that they start from an assumption that the problem is one of user-error. And I did get a slight feel of that on the phone - but perhaps I was just being a bit over-sensitive that day. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 5, 2021 Share Posted April 5, 2021 1 hour ago, gnomus said: Thanks datacommando. It is a very odd problem (but I'm not the only one to have had it - for example https://line6.com/support/topic/27282-no-input-on-helix-lt-loses-all-sound/). I've never used E&M before. They seemed helpful enough on the telephone. Furthermore, as you say, the inspection fee would have come off any repair cost, but all that they did was do a factory reset - something I had already done. Sometimes with these electronics guys, one does get the impression that they start from an assumption that the problem is one of user-error. And I did get a slight feel of that on the phone - but perhaps I was just being a bit over-sensitive that day. Hi, Ah, that is an old thread, I don’t recall reading that, but it seems to be something related to a combination of hardware and the firmware causing the issue - very weird. Anyhow, the fact is that you sent your Helix to be repaired, paid forty odd quid for a diagnostic check, only to have them perform a factory reset which is something you had already done several times. Result - your unit still doesn’t work. That would indicated that the fault failed to be recognised during the “inspection”, which puts the ball firmly back in the court of E&M. Therefore you are paying for a service which you have not received. This sort of stuff can go down “rabbit holes” because you get situations where a computer or electrical fault will happen and then fail to manifest itself when a technician appears on the scene. First, I would be tempted to contact Line 6 Customer Support and explain the dilemma that you have followed their advice to send it for service, but there has been no improvement - simply a factory reset. Then maybe they could contact E&M and have them waive any charges and pay for shipping and have them perform a full range of diagnostic tests and then a repair. The downside with this is if the hardware requires extensive bench tests, you could be without your Helix for quite some time. Sorry, but there doesn’t appear to be a quick fix for this, and you still have a unit that doesn’t work properly. Let us know how it progresses - good luck. Quote Link to comment Share on other sites More sharing options...
gnomus Posted April 5, 2021 Author Share Posted April 5, 2021 Good idea datacommando. I've updated the original Line 6 Support ticket and will see what they have to say. 1 Quote Link to comment Share on other sites More sharing options...
gnomus Posted May 2, 2021 Author Share Posted May 2, 2021 I thought folks might be amused to hear an update. The unit has been back to E&M. They had the unit another 2 weeks during which time they fitted a new PCB and DSP and did more soak testing. They sent it back to me and the unit lasted a little over 24 hours before the fault recurred. I had powered on and off maybe 3 times over that period. It either will or will not work after a power up. And once it has failed it seems to remain in the failed state no matter how many more power recycles I carry out. Most folk seem to have units that are reliable, My unit used to be reliable. But perhaps these boxes just have limited shelf lives. Quote Link to comment Share on other sites More sharing options...
gnomus Posted May 2, 2021 Author Share Posted May 2, 2021 Another chap with a similar issue? https://line6.com/support/topic/50569-no-sound/ Quote Link to comment Share on other sites More sharing options...
PierM Posted May 2, 2021 Share Posted May 2, 2021 If this is happening again and again, it's clear they are either doing wrong, or missing the cause. Swapping a PCB downstream doesnt mean solving, if the cause is upstream. I would search for a better center for a complete and deeper diagnosis. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 2, 2021 Share Posted May 2, 2021 On 5/2/2021 at 7:50 AM, gnomus said: I thought folks might be amused to hear an update. The unit has been back to E&M. They had the unit another 2 weeks during which time they fitted a new PCB and DSP and did more soak testing. They sent it back to me and the unit lasted a little over 24 hours before the fault recurred. I had powered on and off maybe 3 times over that period. It either will or will not work after a power up. And once it has failed it seems to remain in the failed state no matter how many more power recycles I carry out. Most folk seem to have units that are reliable, My unit used to be reliable. But perhaps these boxes just have limited shelf lives. Hi, once more, Well, first up - I’m really not amused in the slightest to read your update. It’s outrageous! This situation is ridiculous, although, I did mention in my earlier post that this thing could go “down the rabbit hole” of working while in the presence of a technician and failing later. I imagine that you contacted the repair shop immediately, and informed them of what was happening with the Helix. If not, do it now. Also inform Line 6 Customer Support to let them know the situation has not been resolved. Furthermore, I would take this right to the top - contact Frank Ritchotte, (Senior Director of Operations, YGG, Line 6 Inc). fritchotte@line6.com Make him aware of your situation, that should get things moving. If this doesn’t get a result, because you’re in the U.K., you still have the option of contacting your local Trading Standards office and seeing if they can pursue this on your behalf. As for your comment - “But perhaps these boxes just have limited shelf lives.” I certainly hope that “planned obsolescence” is not an option here, I’ve had mine since late 2015. Hope this helps/makes sense 1 Quote Link to comment Share on other sites More sharing options...
gnomus Posted May 2, 2021 Author Share Posted May 2, 2021 Thanks guys. I’ve already contacted Line 6 support, but no reply as yet. Unfortunately, the unit failed on Saturday. Monday is a holiday here in the UK, so I’ll contact E&M on Tuesday. I’ll keep you informed. 1 1 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 4, 2021 Share Posted May 4, 2021 It's a disturbing thread.... I don't get discouraged by failing hardware - because that can happen with anything. I especially don't get discouraged by software glitches because those are easy to remedy with a factory reset... then possibly a little time weeding out a corrupt preset. What disturbs me is that this is not the only time I've read about this problem, and every one of the threads I've read remains unsolved and/or abandoned. Thankfully it doesn't happen often, but I certainly feel for those it happens to! 1 Quote Link to comment Share on other sites More sharing options...
rondesjardins Posted May 4, 2021 Share Posted May 4, 2021 So, I've had the same issue after the past two updates (with my HX Stomp). For some reason, when I switch to a patch, it was as if the guitar signal was not making it into the Stomp. I then went into the Input block (first block in the chain) to verify it said "Input Main L/R" (which it did), changed it to something else, and then changed it right back to "Input Main L/R", and then it starts working fine. However, if I don't immediately save that preset...and move to another preset, and back to the original...it has the same issue. Once I figured this out, I had to go through each/every patch and just change/reset the input block and then SAVE the patch...and then they work fine from that point on. Weird but it seemed to resolve it for me. 1 2 Quote Link to comment Share on other sites More sharing options...
codamedia Posted May 4, 2021 Share Posted May 4, 2021 1 hour ago, rondesjardins said: So, I've had the same issue after the past two updates (with my HX Stomp). For some reason, when I switch to a patch, it was as if the guitar signal was not making it into the Stomp. I then went into the Input block (first block in the chain) to verify it said "Input Main L/R" (which it did), changed it to something else, and then changed it right back to "Input Main L/R", and then it starts working fine. However, if I don't immediately save that preset...and move to another preset, and back to the original...it has the same issue. Once I figured this out, I had to go through each/every patch and just change/reset the input block and then SAVE the patch...and then they work fine from that point on. Weird but it seemed to resolve it for me. That is very interesting... and the type of "odd solution" I was hoping to see. It's not ideal, but at least something like that should be a bug that is fixable by Line 6 ..... providing they are aware of it. Thanks for sharing your experience.... it's the first time I've seen some sort of resolution. 1 2 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 4, 2021 Share Posted May 4, 2021 2 hours ago, rondesjardins said: So, I've had the same issue after the past two updates (with my HX Stomp). For some reason, when I switch to a patch, it was as if the guitar signal was not making it into the Stomp. I then went into the Input block (first block in the chain) to verify it said "Input Main L/R" (which it did), changed it to something else, and then changed it right back to "Input Main L/R", and then it starts working fine. However, if I don't immediately save that preset...and move to another preset, and back to the original...it has the same issue. Once I figured this out, I had to go through each/every patch and just change/reset the input block and then SAVE the patch...and then they work fine from that point on. Weird but it seemed to resolve it for me. Would be great to hear this workaround confirmed by some other users with this issue. 1 1 Quote Link to comment Share on other sites More sharing options...
gnomus Posted May 6, 2021 Author Share Posted May 6, 2021 On 5/4/2021 at 6:26 PM, rondesjardins said: So, I've had the same issue after the past two updates (with my HX Stomp). For some reason, when I switch to a patch, it was as if the guitar signal was not making it into the Stomp. I then went into the Input block (first block in the chain) to verify it said "Input Main L/R" (which it did), changed it to something else, and then changed it right back to "Input Main L/R", and then it starts working fine. However, if I don't immediately save that preset...and move to another preset, and back to the original...it has the same issue. Once I figured this out, I had to go through each/every patch and just change/reset the input block and then SAVE the patch...and then they work fine from that point on. Weird but it seemed to resolve it for me. Interesting. The unit is currently back with E&M, so I cannot try this potential fix. On both occasions E&M have had the unit they have got it working again. But they would not, of course, play around with presets. We’ll see what, if anything, they come up with this time. If I get it back and it does it again, I’ll try this. I think that the Helix default is ‘Multi Input’, but I could try a similar process. 1 Quote Link to comment Share on other sites More sharing options...
gnomus Posted June 6, 2021 Author Share Posted June 6, 2021 Sorry for the delay in updating. The unit came back from E&M around 2 weeks ago and seems to have been working since. People might remember that during its last trip out E&M replaced two boards within the device, but that it came back with the same fault (no input signal). On this trip I was told that one of the boards that had been replaced had failed - presumably with the identical problem. Anyhow a(nother) new board was fitted. And so far, it seems to have been working well. (I was told that the unit consists of just the two boards plus the footswitches.) I should say that I did find the Line 6 support people quite helpful, and they did liaise with E&M about my issue. I don't know what failed on the old board (or on its replacement). But I'm happy that the unit is working again. I just hope that I haven't tempted fate by posting an update here!!!! Thanks all for the advice. Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 6, 2021 Share Posted June 6, 2021 28 minutes ago, gnomus said: But I'm happy that the unit is working again. Good to know that you are back up and running. Strange to have an identical board failure, that’s not something that I have heard of other than your original situation. I seriously hope the repair bill was waived in your favour. Enjoy your “new” Helix. Quote Link to comment Share on other sites More sharing options...
gnomus Posted June 6, 2021 Author Share Posted June 6, 2021 Thank you. Yes the repair bill was substantially reduced as a result of all the issues I'd had. I'm happy with the outcome as far as that is concerned. I'm just left with this slight uncertainty as to whether or not the thing will be working when I switch it on. Hopefully that will fade over time. :-) 1 Quote Link to comment Share on other sites More sharing options...
Dany_Tassone Posted January 2, 2022 Share Posted January 2, 2022 Hey, I have the same problem. The input usually gets green when it receives the signal from the guitar. Now, the input signal doesn’t get green and I got no sound. I have troubleshooted by: 1. plugging my guitar directly to the speaker: my guitar works 2. changing the cable: cable works 3. booting the helix to factory settings: input signal still doesn’t work Is there a fix to this issue? Quote Link to comment Share on other sites More sharing options...
gama91 Posted August 26, 2022 Share Posted August 26, 2022 hello, unfortunately I have to re-upload this thread because my helix also suffers from the same problem. I've tried all kinds of inputs and even after sending it for repair here in milan, the problem recurs. The firmware version is 3.15, I tried factory restore but alas without luck. For those who have had this experience, how did you solve it? Is it possible for line6 to replace the pedalboard with a new one? Translated with www.DeepL.com/Translator (free version) Quote Link to comment Share on other sites More sharing options...
SinedLeCapybara Posted March 2, 2023 Share Posted March 2, 2023 Hi everyone, It seems that I'm part of the lucky ones, I was playing, it worked fine as usual. Took a break and turned it off, came back 2h later and no signal in any entry after multiple tests on cables and instruments and also updating the firmware 3.50... I'm desperate, I need that equipment for concerts and work and it can just blow a fuse like this ? at this price ? I have no idea what happened in between those two sessions, my helix is on a table and didn't move at all. Any advice ? Thanks Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 2, 2023 Share Posted March 2, 2023 On 3/2/2023 at 3:54 PM, SinedLeCapybara said: I'm desperate, I need that equipment for concerts and work and it can just blow a fuse like this ? at this price ? I have no idea what happened in between those two sessions, my helix is on a table and didn't move at all. Any advice ? Hi, You don't give us much to go on here with just a "Me Too" post. It's a big help to know what your HX unit is and your computer/OS. Also you have and to make sure that you actually have a full install of v3.50 and you followed the installation instructions to the letter. You say that you are getting no signal from any of the 1/4" inputs, but does it work via USB? Does the screen light up, and can you edit any of the presets. Have you tried a different connection to the main power. Too many unknowns here. I understand your frustration with the fact that you cannot get any sound from your device, although you say, - "I need that equipment for concerts and work and it can just blow a fuse like this ? at this price ?" - this can happen to any piece of equipment at any time. It's the nature of things and they usually happen at the worse possible times. If you were using a pedalboard and a tube amp you could still have something in the signal chain that fails in the middle of a gig. Rule one with anything like this is, Fail Safe - always have a back up! It's no-ones fault, at any price - sh!t happens. If you have tried a re-install of the firmware, followed all the reset procedures and you still have no signal, it probably indicates a hardware failure that is beyond the scope of anyone here. You should really should contact Customer Support. Hope this helps/makes sense. 1 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted March 2, 2023 Share Posted March 2, 2023 Ask ChatGPT. Joking, but seriously, no way we can give you any advice with that post. Shrug...:) 2 Quote Link to comment Share on other sites More sharing options...
SinedLeCapybara Posted March 3, 2023 Share Posted March 3, 2023 (edited) Yeah I was very fustrated, for sure, sorry :D Well here it goes for the context and details : I'm working on a pc with windows 11, with a komplete audio 6 audio interface and a push 2 as a controller on ableton. My Helix Floor is plugged on the back stereo input 3/4 channel of the komplete audio and I just had a microphone for voice on the input 1. The Komplete audio is plug directly to the pc and the push and helix are on a powered hub, and the Push as it's own power supply. I did a 2h session this morning, no problem. Turned the helix off, came back 2h later, turned on everything again, no input signal. The only difference is that in the first session the push2 was off, and I turned it on on the second session. All the interface of the helix is working just fine and i can control it by the software and by the knobs. The knobs are working fine, I did the hardware tests on the pedal (by holding 4&5 footswitches) Following that, I did a backup of my work on the helix to proceed. I did all the tests : changing the cables, changing the guitar, reboot multiple times, testing different input (guitar in/aux in), checking impedance level at the input, changing the input, checking for signal with the tuner (nothing) then proceeded to factory reset and test - nothing. Go back to an older firmware - nothing. Update again to the last one - nothing. I have no signal input in "guitar in" and "aux in" which is very odd for 2 hardware components to break at the same time. I"m more thinking of a driver conflict causing a softlock of the inputs because of the coincidence with the push 2 being on when it failed. Like, let's say, the Push wants to take control of the inputs as an audio device (as it is one) and it freezes the helix. Maybe I'm totally off but I can't shake off that hardware don't break at the same time like this often. I reinstalled the line 6 drivers but nothing changed. The pedal was not moved during all this time, it's sitting on a desk in a "controlled" environnement :) I finally made a ticket to customer support. UPDATE EDIT : So, after a good night sleep, I turned the helix on and... IT WORKS. The only thing I did was unplug it and let the switch "on" to "evacuate" any electricity from the circuit like you do when working on a computer. But to further test it, I reproduced the condition of the glitch with pc turned on then the hub, then the push, then rebooting the helix and so on. Everything seems to be ok... Edited March 3, 2023 by SinedLeCapybara update Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 3, 2023 Share Posted March 3, 2023 On 3/3/2023 at 12:49 AM, SinedLeCapybara said: Everything seems to be ok... Happy to know you have managed to get back up and running. This should not directly be part of the loss of audio signal in and out that you experienced, but something to consider, which I spotted in your reply - Helix connected to a hub. Line 6 recommends that their products are not connected via a USB hub. This has been a cause of many failed updates and numerous other bits of USB voodoo and it’s best avoided. Note: if connecting to USB on a PC, the ports on the front may also act as a type of hub connection, therefore it’s advisable to use one of the rear ports - these are probably mounted directly to the board. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
myrtlecato Posted April 27, 2025 Share Posted April 27, 2025 Hi - been a couple of years since anyone posted here. Hopefully, someone will see this. Had my helix floor - issue free since 2017. But, as of 3 days ago, I have silent guitar/return/aux inputs. Did everyone above get their helix issues resolved? I've done a factory reset, changed preset input blocks to multiple and back to guitar, changed leads and guitars and moved vol pedal. Now running the electric down with the power switch on but mains off. (Not hopeful). Usb and xlr work - helix plays sound from pc and mic. It all went wrong when I was using hx edit to create a preset using synth blocks. I didn't save the preset, just switched the helix off. Then, when switched on - nothing. I live in the UK and E. and M. electronics have stopped repairing line6 products. (Line 6 now uses a co. in Norwich and one in Southend). Anything else I can do? Can anyone recommend a repair company in the West or South west? Quote Link to comment Share on other sites More sharing options...
amsdenj Posted May 4, 2025 Share Posted May 4, 2025 Not likely the problem, but check your power. These modelers can do odd things if plugged into bad power. Quote Link to comment Share on other sites More sharing options...
