Disabling Tap Tempo on Helix Floor
MatthewMcGhee
On 2/2/2023 at 1:55 PM, MatthewMcGhee said:
… Every time I try and hold for tuning it changes the tempo. ..
The tempo only changes if the Helix detects multiple consecutive taps. If you don’t tap the switch but just hold it until the tuner appears the tempo won’t change. Then when you tap to turn the tuner off, just tap once. Again, no tempo change.
  • Upvote 2
Depends how clean are the FS... :)
When the switch got a bit oxidated, or old, it start misfiring and throwing switch bouncing noise. (which means tap tempo being set randomly).
I had this on both Helix floor and Helix control...
4-C67-BE5-A-A386-446-B-AF25-DE6-B2-B84-A
  • Upvote 2
  • 3 years later...
On 6/10/2026 at 4:42 PM, GrauerVlad said:
Under the “Display Tap Tempo” setting, it's off. And I've had the Helix for 3 hours.
WARNING! ZOMBIE THREAD!
BUT...FWIW - That only affects the blinking of the LED. Tapping to set the actual tempo is still active. Always.
Having your Helix for 3 hours is relevant, how?
  • Upvote 2
