Helix Floor - Internal PSU blown - Replacement help [SOLVED]
stephenashworth
Hi There,
I wonder is anyone can help? My Helix floor's internal switching power supply (psu) has blown. Specifically the switching diode on the psu module has fried and having removed the module from the chassis, there is a rather unsettling rattle on the board I can't quite locate.
Fortunately, the psu is an open open frame module by CUI (VOF-65-12), unfortunately, this module has been discontinued and is no longer available. Presumably line 6 are no longer using this module in new Helix's, so does anyone know what module they are using now so I can track down an "approved" replacement?
Fwiw, my Helix is one of the early ones and I use it daily, it is switched on for about 16 hours a day as I mainly use it as a DAW.
Many thanks
Dont know if it's being used in the Helix, but a direct substitute for the VOF6512 is the ECS65US12. Id contact support for a confirmation, even if they share exactly the same specs.
https://www.xppower.com/portals/0/pdfs/SF_ECS65-130.pdf
https://www.newark.com/xp-power/ecs65us12/power-supply-ac-dc-medical-12v/dp/67R9479
Thanks PierM, I also settled on this as a potential replacement but like the vof6512, availability is very low or a year lead time. I also found this...
https://uk.rs-online.com/web/p/switching-power-supplies/2216388
which is available and seems ok but the power connecter is offset. I think it would be fine but I would rather get a line 6 approved replacement. I'll contact support as you advice, hopefully they will be happy to share the Information I need to get my gear back up and running.
Check out Farnell - This is available - according to the website they have 181 in stock.
https://uk.farnell.com/xp-power/ecs65us12/power-supply-ac-dc-medical-12v/dp/1821421?pf_custSiteRedirect=true
Hope this helps/makes sense.
Note: Your link to Radio Spares states they have 13 in stock for next day delivery.
On 3/26/2023 at 12:43 PM, datacommando said:
Hi datacommando,
Thanks for that, I checked RS and CPC and totally forgot about Farnell.
Unless support advises otherwise, my fix is in the bag!
Thanks again.
  • Upvote 2
Ok, for anybody else who faces this problem. The news is good, the ECS65US12 works perfectly. The holes of psu circuit board are a little tight for the supporting pillars but it went on with a little effort.
Everything is now working fine. Thanks to PierM and Datacommando for their support!!!!
I hope this helps someone else if they have this issue. Although this is a relatively easy repair I would recommend this fix only if you have some experience with replacing boards and components. If you have built or maintain your own PC, this fix would be a piece of cake.
  • Like 2
  • Thanks 2
  • Upvote 2
Glad to know you got this sorted out.
It may be helpful to others if you could go back into the thread title and add (SOLVED) to the end of the text!
Have fun.
  • stephenashworth changed the title to Helix Floor - Internal PSU blown - Replacement help [SOLVED]
  • 1 year later...
154 B · 7 downloads
Glad I found this! Came home today and im like you have my Helix turned on a lot of hours as I use it for my soundcard and also sometimes forget to turn it off overnight.
Mine is also and early version bought early in 2016 and is in daily use. Came home today and house was all black, main fuse had been flipped. After a while I go to my PC and turn on the Helix (its connected to a remote outlet so the outlet hadnt been turned on after i flipped the fuse on again) turned it oin and only the small lcds flickered on the unit, smelled a bit burnt electronics in my room. After a while the small lcds displyes the labels, big lcd is black so i fired up HX edit and it finds the helix like usual but small lcds are flickering, starting a backup and halfway through the helix makes a popping sound from the power side and house turns black again. Opened it up and it's the same with mine, diode is burnt etc so im guessing power supply failure, i mean it happens with PC's as well etc. Its now all dead and black so im ordering the PSU you wrote and see if it helps, its 8 years old so warranty is out anyways. To bad tho the price on these things have risen 1/3 since i bought mine haha.
  • Thanks 2
  • 2 months later...
Hi Ron, I can help you. I bought my PSU from Farnell. Below is a link and all the spec sheets are there. For me it worked flawlessly and I haven't had a problem since.
All the best with your repair, I know my heart was in my mouth until I made the change, switched it on and all was good.
Best of luck!
https://uk.farnell.com/xp-power/ecs65us12/power-supply-ac-dc-medical-12v/dp/1821421?CMP=e-email-sys-orderack-GLB
  • Upvote 2
