mattsteeves Posted December 2, 2023 Share Posted December 2, 2023 I've successfully update my Helix Floor to the new firmware and have access to the new amps and effects, but the "Feedback" pedal under Dynamics is missing. I searched every other category for it. Has this happened to anyone else? 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 2, 2023 Share Posted December 2, 2023 On 12/2/2023 at 6:14 PM, mattsteeves said: but the "Feedback" pedal under Dynamics is missing. I searched every other category for it. Hi, It’s not missing - it’s right there where it should be. It’s a MONO effect. “† The Feedbacker model utilizes DSP-intensive polyphonic pitch shifting and, therefore, is mono.” Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 3, 2023 Share Posted December 3, 2023 On 12/3/2023 at 4:03 AM, MGW-Alberta said: DSP-intensive is right. Wow. Yeah, it sure is, but it was a much requested feature that comes at a cost. I guess some folks should be careful of what they wish for, although it seems to have pleased most of them. Still, there is the option to add a hardware version via the FX Loop - either with a genuine FreqOut pedal, a new HX One, or one of the other pseudo feedback pedals available. Quote Link to comment Share on other sites More sharing options...
craiganderton Posted December 4, 2023 Share Posted December 4, 2023 On 12/2/2023 at 10:03 PM, MGW-Alberta said: DSP-intensive is right. Yes, but there are workarounds. I've even done some presets where the Feedbacker is in parallel, going through its own amp. It's a cool sound! BUT, I do have to pay serious attention to the processing power of the modules in the presets. Sometimes it's worth dipping into Legacy World for effects that are more miserly about processing power. 1 Quote Link to comment Share on other sites More sharing options...
molul Posted December 6, 2023 Share Posted December 6, 2023 On 12/2/2023 at 7:14 PM, mattsteeves said: I've successfully update my Helix Floor to the new firmware and have access to the new amps and effects, but the "Feedback" pedal under Dynamics is missing. I searched every other category for it. Has this happened to anyone else? It has happened to me today. I followed all the steps (had the latest HX Edit version, backed up my helix, updated, factory reset and restore from backup), as usual. The feedbacker is not there. All other new additions are. I wonder what happened this time Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 6, 2023 Share Posted December 6, 2023 On 12/6/2023 at 1:40 PM, molul said: I wonder what happened this time What happened was - you didn’t read my reply posted above, which explains that it is a MONO effect! Look under Dynamics Models > MONO Quote Link to comment Share on other sites More sharing options...
molul Posted December 6, 2023 Share Posted December 6, 2023 On 12/6/2023 at 3:00 PM, datacommando said: What happened was - you didn’t read my reply posted above, which explains that it is a MONO effect! Look under Dynamics Models > MONO Nope. I knew it's a dynamics mono effect before I read your post. Actually, after dynamics mono, I checked ALL the categories just in case there was a mistake in the release notes. In dynamics>mono, I can see, in this order, deluxe comp, red squueze, kinky comp, ampeg octo comp, Rochester comp, la studio comp, 3-band comp, nose gate, hard gate, horizon gate and autoswell. Not any feedbacker. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted December 6, 2023 Share Posted December 6, 2023 The feedbacker will appear as last in the Dynamics->Mono list unless the patch doesn't provide enough DSP reserve for it. Normally unusable items are greyed out in a list - but seemingly not if they are the last item. I'd call it a bug because it is inconsistent visibility of items based on their position in a list. And because once you free DSP resources so that the Feedbacker shows up in the list - it then gets greyed out if you again exceed DSP resevere. 3 Quote Link to comment Share on other sites More sharing options...
molul Posted December 6, 2023 Share Posted December 6, 2023 On 12/6/2023 at 3:47 PM, Schmalle said: The feedbacker will appear as last in the Dynamics->Mono list unless the patch doesn't provide enough DSP reserve for it. Normally unusable items are greyed out in a list - but seemingly not if they are the last item. I'd call it a bug because it is inconsistent visibility of items based on their position in a list. And because once you free DSP resources so that the Feedbacker shows up in the list - it then gets greyed out if you again exceed DSP resevere. Aaah, there it is. Thanks! Wow, it is indeed DSP insensitive. I could only add one amp+cab block to the preset. Not sure if I'll use it :-/ and yeah, it should appear as grey, not disappear. That's totally a bug to me. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 6, 2023 Share Posted December 6, 2023 On 12/6/2023 at 2:25 PM, molul said: Nope. I knew it's a dynamics mono effect before I read your post. Actually, after dynamics mono, I checked ALL the categories just in case there was a mistake in the release notes. In dynamics>mono, I can see, in this order, deluxe comp, red squueze, kinky comp, ampeg octo comp, Rochester comp, la studio comp, 3-band comp, nose gate, hard gate, horizon gate and autoswell. Not any feedbacker. HX EDIT - showing Feedbacker not Selectable HELIX - showing Feedbacker not Selectable 1 Quote Link to comment Share on other sites More sharing options...
molul Posted December 6, 2023 Share Posted December 6, 2023 On 12/6/2023 at 7:20 PM, datacommando said: HX EDIT - showing Feedbacker not Selectable HELIX - showing Feedbacker not Selectable Yeah, that wasn't happening to me. Had a preset with a couple of amp+cab and some effects, and the feedbacker wouldn't appear, as explained above. Seems like a bug. 1 1 Quote Link to comment Share on other sites More sharing options...
ricstudioc Posted December 6, 2023 Share Posted December 6, 2023 On 12/6/2023 at 7:54 AM, molul said: Wow, it is indeed DSP insensitive Chuckle - well, I suppose that's a legit way of putting it. 1 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted December 6, 2023 Share Posted December 6, 2023 On 12/6/2023 at 7:20 PM, datacommando said: HX EDIT - showing Feedbacker not Selectable HELIX - showing Feedbacker not Selectable On the device it is a different story. It won't show up in the list until your patch has enough DSP resereve. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted December 6, 2023 Share Posted December 6, 2023 On 12/6/2023 at 9:57 PM, Schmalle said: On the device it is a different story. It won't show up in the list until your patch has enough DSP resereve. Hi, That second photo is my Helix showing the same preset as the one in the HX Edit image. The pictures show an example where I was attempting to add the “Feedbacker” block to a preset in which both the DSPs are almost maxed out. Both images show that the “Feedbacker” is NOT available to use in the signal chain. In the post from @molul the quote is:- “and yeah, it should appear as grey, not disappear.” Looks like it is visible in my pic. If you guys think that this is a bug then the best thing to do is report it by raising a ticket with Customer Support. The more reports, the faster there will be a fix, if it needs one. I cannot report it because I am not seeing that “bug” - see pics again. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
craiganderton Posted December 7, 2023 Share Posted December 7, 2023 On 12/6/2023 at 8:54 AM, molul said: I could only add one amp+cab block to the preset. Not sure if I'll use it :-/ You might want to give it another try, you can do quite a lot depending on what blocks you choose. The following all fit into HX Stomp. My current favorite preset is a parallel path: Heir Apparent > Brit 2203 Amp+Cab > Stereo Simple Delay Feedbacker > Studio Comp But I also like this parallel preset: Parametric EQ > Line 6 Voltage Amp+Cab > Stereo Simple Delay Feedbacker > Soup Pro Amp+Cab You can do weirdass creative things with Feedbacker, too. This preset generates ambient background music all by itself: 4 OSC Generator > Tremolo > Tremolo > Feedbacker > Low and High Cut EQ > Mandarin 80 Amp+Cab > Legacy Particle Verb I put it on in the background when I've had a rough day :) Quote Link to comment Share on other sites More sharing options...
molul Posted December 7, 2023 Share Posted December 7, 2023 I've tried to reproduce the "bug" but no luck. Since the feedbacker appeared as gray for the first time, now it always appears gray (instead of not appearing at all as before) when there's not enough DSP. Maybe it's a one time only thing. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted December 7, 2023 Share Posted December 7, 2023 On 12/7/2023 at 5:03 AM, molul said: I've tried to reproduce the "bug" but no luck. Since the feedbacker appeared as gray for the first time, now it always appears gray (instead of not appearing at all as before) when there's not enough DSP. Maybe it's a one time only thing. Try it on an empty preset. It will always show as greyed out if the preset you're using it on doesn't have enough available DSP for it. Quote Link to comment Share on other sites More sharing options...
jemenake Posted June 9 Share Posted June 9 Just to add a data point, I've had the same problem with the feedbacker not showing up in the list. It's really frustrating because I would suspect that I wasn't looking in the right place, and then I'd double-check with the interwebs that it was, indeed, supposed to be at the bottom of Dynamics->Mono, but my list would stop at Autoswell. In fact, I think I've only had the feedbacker show up once, and that might have been on a new, blank patch. I've tried adding it to my existing patches, and the feedbacker wasn't there... even when I deleted a lot of the DSP-heavy effects like amp/cab. The next thing I'm going to try is restoring one of my patches from backup to see if maybe patches carried over from before the upgrade have something about them which cause the new OS to glitch. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 10 Share Posted June 10 On 6/10/2024 at 1:54 AM, jemenake said: Just to add a data point, I've had the same problem with the feedbacker not showing up in the list. It's really frustrating because I would suspect that I wasn't looking in the right place, and then I'd double-check with the interwebs that it was, indeed, supposed to be at the bottom of Dynamics->Mono, but my list would stop at Autoswell. In fact, I think I've only had the feedbacker show up once, and that might have been on a new, blank patch. I've tried adding it to my existing patches, and the feedbacker wasn't there... even when I deleted a lot of the DSP-heavy effects like amp/cab. The next thing I'm going to try is restoring one of my patches from backup to see if maybe patches carried over from before the upgrade have something about them which cause the new OS to glitch. The feedbacker is DSP heavy; about 1/3 of the amp models use less. When you deleted stuff you just didn't delete enough. It shows up consistently once the patch has enough free DSP. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 10 Share Posted June 10 Just checking…. Make sure you are running HX Edit v3.70. The new models introduced with firmware v3.70 won’t appear in older versions of HX Edit. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 10 Share Posted June 10 On 6/10/2024 at 12:54 AM, jemenake said: I think I've only had the feedbacker show up once, and that might have been on a new, blank patch. Hi, As we are all aware of how much DSP this effect uses, then the solution would appear to be, if you are really going to want to use the Feedbacker in a preset - add it first into a signal path of a blank preset. Shows up last in the list of mono Dynamics every time, if nothing else is in the path. Hope this helps/makes sense Quote Link to comment Share on other sites More sharing options...
