Helix LT Broken EXP pedal
justafewguitars
  • 2 weeks later...
Still no updates. Line 6/Yamaha Canada has my unit. A support ticket was opened and closed with Line 6 saying “Contact the store which you sent the unit for repair through.” That’s been zero help. I’m seriously rethinking my decision  about purchasing any further Line 6 or Yamaha product. Over a KNOWN and well documented problem. The store has no answers, Yamaha Canada has no answers…not sure where I should turn to.
  • Sad 1
You can give Line 6 a call.  I've done that in the past after a horrible experience with the authorized repair shop.  They opened a ticket for me over the phone, and I was able to add more detail to the ticket afterwards.  The whole issue was swiftly resolved for me.  So you may try that.
I don't know your financial situation, but I got a second Helix shortly after buying an LT, to use as a backup.  Every serious musician must always have a backup for such situations.  Good news is that the LT is pretty inexpensive nowadays...
In terms of reliability of an LT, in my experience the unit is quite solid.  I bought a used unit and the expression pedal is working fine after 6 years.  I do not stomp on it, however, meaning I do not use the footswitch to change between EXP 1/2.  That may explain why my pedal is still intact.  If it ever broke, I'd take the unit apart, remove the pedal and velcro a small expression pedal in its place....
In terms of the tap tempo button not working reliably, it's the tactile microswitch inside that gets gunked up. You need to have these microswitches cleaned with DeoxIT from time to time.
That is not my experience with Line 6 support at all.... just saying.
Try a new ticket... be stern by polite. Line 6 support is limited due to international agreements, but they can still swing a big hammer when needed.
My example(s): When I was searching for a Variax JTV battery Line 6 kindly pointed me to Yamaha Canada because they were not allowed to sell to me directly. Yamaha Canada was unresponsive so I went back to Line 6.... the next business day I had an invoice for a new battery from Yamaha Canada in my email and within a week it was in my hands.
In another instance back in 2018 Long & McQuade used to be the distributer/repair depot. I had a problem with an HX Effects and got the run around from L&M.... Line 6 support kicked their proverbial butt until I was taken care of.... and I was taken care of really well!
