alienux Posted April 23, 2015 Share Posted April 23, 2015 I've noticed that my patches with the new amp models have sounded pretty boomy, and that the bass end of the spectrum almost sounds like there's clipping, but only the lower ranges of the sound when I play chords. The mid and upper ranges sound OK to me. I'm at work and can't check this right now, but it just occurred to me that I haven't looked at the new Global EQ settings at all since upgrading to 2.60 and installing the model packs; I've only been creating new patches with the new models. So my question is in regards to the new Global EQ default settings. I can check this when I get home, but since that won't be for another 8 or 9 hours, I'm wondering if the default setting for the Global EQ after upgrading is on or off. If it's on by default, that could be what's causing the boomy-ness that I've been noticing in my new patches. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 23, 2015 Share Posted April 23, 2015 Default setting is ON. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted April 23, 2015 Share Posted April 23, 2015 +1 to the above. Quote Link to comment Share on other sites More sharing options...
Zhorell Posted April 25, 2015 Share Posted April 25, 2015 Dump question here, does the Global EQ affects all the patches and user? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted April 25, 2015 Share Posted April 25, 2015 Global = all patches. Yes. Quote Link to comment Share on other sites More sharing options...
designmachine2 Posted May 8, 2015 Share Posted May 8, 2015 Hi Can anyone tell me how do you get to the global eq on a pod pro hdX (updated yesterday) There was a note at the start of the upgrade which i only scanned, now i can't remember how to get to it! :) doh! Quote Link to comment Share on other sites More sharing options...
medievil1 Posted May 8, 2015 Share Posted May 8, 2015 someone did a spectral analysis.. global EQ when on and set to default make no change on the sound.. it is still flat response.. the graph was virtually identical... if anything... there was a very minor, sub sonic low and super sonic high cut, but even perfect hearing couldn't hear those frequencies... Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted May 8, 2015 Share Posted May 8, 2015 Hi Can anyone tell me how do you get to the global eq on a pod pro hdX (updated yesterday) There was a note at the start of the upgrade which i only scanned, now i can't remember how to get to it! :) doh! It is on SYSTEM SETUP screens 11 . It allows you to turn it ON and OFF and the 4 control knobs allow you to select and set each specific setting. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted May 8, 2015 Share Posted May 8, 2015 Yes, I made those measurements. You'll find them here. Medieval is right. Only the extreme high and low ends are affected with the Global EQ is ON or Off at the default settings. I doubt any one playing rock can hear the difference. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 8, 2015 Share Posted May 8, 2015 Yes, I made those measurements. You'll find them here. Medieval is right. Only the extreme high and low ends are affected with the Global EQ is ON or Off at the default settings. I doubt any one playing rock can hear the difference. I'm sorry, you'll have to speak up...can't hear a word you're saying. :P Quote Link to comment Share on other sites More sharing options...
