Hey_Joe Posted May 12, 2015 Share Posted May 12, 2015 Has anyone else noticed a, (not really a bug but something is different) with HD500 Edit since the update? When I open Edit, I always get the Son of Plexi patch sounding no matter what the 500 was left on when Edit was shut down. If I'm on any set list, any patch loaded gets over ridden with Son of Plexi while Edit loads and after it hits 100% it reverts to the patch loaded. I never had this happen before on any version of Edit - pre and post HD or JTV. Before - as Edit loaded I would hear a "New Tone" sound and after Edit finished loading I would hear the patch currently loaded. I thought maybe my install of Edit was corrupt but I removed it and reinstalled it but get the same thing. I'm using a Windows7 PC and the HD 500(not X). I don't consider this a problem per se, but unusual behavior from previous versions and I am just wondering if anyone has experienced this. Anyone else get this? Quote Link to comment Share on other sites More sharing options...
samsgs Posted May 12, 2015 Share Posted May 12, 2015 I have a 500X and it generally loads whatever was last played. Firmware updates installed but no model pack yet. I have had other issues mostly with HD Edit shutting down while plugged into my Mac and playing through the 500X, 2 DT25's and 1 L3t. Have also had instances where amps somehow got switched off in HD Edit. Quote Link to comment Share on other sites More sharing options...
line-6-user Posted May 12, 2015 Share Posted May 12, 2015 I have not noticed this with mine. Have you tried to run the program with Administrative access? You can right-click on the icon and click run as Administrator... (or something in that line. Sorry, I do not have the PC ON at the moment). Hope that helps. Quote Link to comment Share on other sites More sharing options...
duncann Posted May 13, 2015 Share Posted May 13, 2015 Haven't noticed this on mine (500X). Did you do the global reset when you did the update? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted May 13, 2015 Share Posted May 13, 2015 Mine still loads the last patch that I had selected. I have had the new FW on it since it came out. Quote Link to comment Share on other sites More sharing options...
moogary Posted May 13, 2015 Share Posted May 13, 2015 Happened only once (just after I restored my patches after update). I hope it stays that way! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 13, 2015 Share Posted May 13, 2015 have you disconnected everything and rebooted your devices? That always seems to the one thing people forget. No, I have never seen/heard it. But, admittedly, I never tried. Knowing that it takes time to sync, I hook up and do other stuff. Quote Link to comment Share on other sites More sharing options...
Hey_Joe Posted May 13, 2015 Author Share Posted May 13, 2015 Yes I did a global update with the pedal calibration after updating and yes I have rebooted all devices. Just curios if this happens to anyone else. So far it does nothing else different or wrong and seems to not be any actual problem, just different behavior than last version of Edit. Thanks for the responses and suggestions. Quote Link to comment Share on other sites More sharing options...
