tylerhen Posted August 13, 2015 Share Posted August 13, 2015 Is there a way to fade in your distortion? For example when moving from a clean verse to a heavy chorus? If you can't do that with the hd500x, what is the best way to do it with post production? Thanks! Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted August 13, 2015 Share Posted August 13, 2015 Is there a way to fade in your distortion? For example when moving from a clean verse to a heavy chorus? If you can't do that with the hd500x, what is the best way to do it with post production? Thanks! Set up a dual-amp patch. One clean amp, and one dirty. Then assign the channel volume for each amp to the expression pedal so that one fades out as the other fades in. I have several patches set up this way...it's great. Seamless transition from one to the other. If you want to do it in post, that generally means recording each part separately, and fading in and out each track as necessary. 1 Quote Link to comment Share on other sites More sharing options...
tylerhen Posted August 13, 2015 Author Share Posted August 13, 2015 Cool I will give that a try! I assume I lose most of the cool stereo effect of having two amps though? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 13, 2015 Share Posted August 13, 2015 not just dual amps. use the exp pedal to control the distortion. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted August 13, 2015 Share Posted August 13, 2015 +1 piano guy. You can use just a single amp and use the EXP to control the gain. You will also need the EXP to adjust the channel volume so the gain/no gain levels are the way you want. You may also need to use the EXP adjust your EQ to get sculpt the gain/no gain sound the way you like. By moving the EXP heel to toe all the parameters will gracefully move from one setting to the other simultaneously. Works quite well for me. 1 Quote Link to comment Share on other sites More sharing options...
radatats Posted August 13, 2015 Share Posted August 13, 2015 remember you can assign up to 50 parameters to the expression pedal at the same time. That means you can change amp gain, tone stack, channel volume, compressor level, distortion /overdrive pedal parameters, delay parameters, reverb mix plus lots more all with one expression pedal to smoothly transition from rhythm to lead for example. If you have a Variax you can also use your volume and tone knobs as expression pedals to do the same thing adding further tone changing options. You are only limited by DSP and your own creativity. Benefit is all these changes remain within the same patch so no audible delays and trails remain... Quote Link to comment Share on other sites More sharing options...
tylerhen Posted August 14, 2015 Author Share Posted August 14, 2015 Ok so how do I do it if I want to raise and lower the screamer? By the way I'm doing this in Line6 Edit. I've added a pedal to my setup. I've put it on volume instead of pan. However in the controller tab when I assign it to screamer and set it to control drive and output, it's still just controlling overall volume. I can't tell it's doing anything to the screamer. thanks for any help Quote Link to comment Share on other sites More sharing options...
radatats Posted August 14, 2015 Share Posted August 14, 2015 if you only have one exp pedal and you are already using it as exp1 to control the panner, go into the controller tab, choose the Screamer MODEL, the Drive PARAMETER, set FS ASSIGN to Exp Toe Switch, set CONTROLLER to Exp 2. Now set your MINIMUM and MAXIMUM using the mouse. DO NOT TOUCH THE PEDAL! Press SAVE on the POD to save your settings. If you are still having trouble with the controller settings try resetting (NOT REFLASHING) your POD and recalibrating the pedal. 1 Quote Link to comment Share on other sites More sharing options...
tylerhen Posted August 14, 2015 Author Share Posted August 14, 2015 I only have one expression pedal in my setup. It's set to volume, not pan. In the controllers tab I have: Model: Screamer FX Assign: ESP Toe Switch Parameter: Drive Controller: EXP1 Min: 33 Max: 66 I hit save twice on the physical device, however EXp1 still just makes volume go from 0 to 100. I then tried doing it to EXP2 but it does nothing. I'll try and recalibrate. Never done that either lol Quote Link to comment Share on other sites More sharing options...
tylerhen Posted August 14, 2015 Author Share Posted August 14, 2015 Recalibrated pedal. Same thing. Does it matter where in the chain I have the pedal? Do I have to disable the volume on the pedal in the controllers tab or something like that? Quote Link to comment Share on other sites More sharing options...
tylerhen Posted August 14, 2015 Author Share Posted August 14, 2015 Ok I guess 33% and 66% wasn't a big enough difference in my setup to tell much of a difference. Quote Link to comment Share on other sites More sharing options...
tylerhen Posted August 14, 2015 Author Share Posted August 14, 2015 Not able to get the channel volume to fade in and out on two amp setup though. I just reverse the min and max for each amp right? Quote Link to comment Share on other sites More sharing options...
radatats Posted August 14, 2015 Share Posted August 14, 2015 yep. have them both assigned to the same pedal with min and max reversed 1 Quote Link to comment Share on other sites More sharing options...
