jamesnlcc1 Posted September 14, 2015 Share Posted September 14, 2015 Problem:While playing recently, my DT-25 suddenly dropped volume significantly and had a slight burning smell. I figured it was a tube(s) going out, so I bought some new ones and replaced them, but when I went to bias them, they were super low! Instead of the 25 (+/-3), they were around 7-8. I turned the bias, but then the weirdest thing happened - any turn up would start an unstoppable climb to 40-50, then it would suddenly kick down to 14 or less. It would stay that way until I turned the bias up again, and then the same thing every time. I checked the fuse, but it seems intact. Since power was going to the tubes, I figure it can't be that anyway. I may be wrong, but I suspected it may be kicking into Low-Volume mode as a safety feature. Any idea what's going on? How do I fix this? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 14, 2015 Share Posted September 14, 2015 What tubes are they? Brand, type, and all. Quote Link to comment Share on other sites More sharing options...
jamesnlcc1 Posted September 15, 2015 Author Share Posted September 15, 2015 EL-84's and a 12ax7. Originals when it began were installed by line6 -EH's. New ones are jj's. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 15, 2015 Share Posted September 15, 2015 Can't bias the JJ's to the same bias voltages. The transfer function curve and multiple topology gain structure of DT series amps is not good for JJ's, Mesa's and Groove tubes. I see too many DT series amps come across my bench because of other tubes being put in the amp and biased to the same bias volts as if they were EH tubes. These are not tube amps of the 1960's and '70's, you can't get away with the same kind of tube swapping like we used to do back then. These are hybrid amps with analog and digital stages, both solid state and tube. Can't get away with the same sort of things like we did back then. Please,... use the specified EH series. They've gone through a further sorting through. 1 Quote Link to comment Share on other sites More sharing options...
jamesnlcc1 Posted September 16, 2015 Author Share Posted September 16, 2015 Thank you, psarkissian, although the EH's were in the amp when the problem first occurred. Was it a blown tube that cause the slight burning smell and the sudden drop in volume? Also, and I know this is not the kind of question you were looking to elicit from you comments, but I'm curious what level bias you think JJ's should have. Cooler? Thanks, Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 16, 2015 Share Posted September 16, 2015 Depends on the smell. Whether it smelled like plastic, glass or metal. The bias specs for the EH's has already been worked out in the designed and test process, so it's a fixed spec. As far as biasing JJ's, we have no spec for that. I would have to O-scope it with a signal and dial it in to find where the bias point for the JJ's are. Rheinhold's tube amp circuitry is not forgiving of deviations from the spec, and matching our processing to it makes it even more hybrid and even less forgiving of mods or deviations from the spec. This isn't a tube amp from the 60's or 70's,... can't get away with the same kinds of tube swapping we used to do back then. Use the specified EH's,... it's the best bet. 1 Quote Link to comment Share on other sites More sharing options...
jamesnlcc1 Posted September 16, 2015 Author Share Posted September 16, 2015 I hear ya, but it was with EH's installed by Line-6 themselves that this problem first occurred. Not to mention this is the second time I've had an issue with the amp (and its tubes) and had to send it in to Line-6. Not a sterling performance record on the EH's, so I think you can see my incredulity of the "reliability" of them, even as I get what you're saying about how the amp is spec'd. The burning smell... I don't think it smelled especially metallic or or plastic. Thoughts? 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 16, 2015 Share Posted September 16, 2015 Usage will determine how long the tubes last. Gigging musicians should change them out every 12-18 months, bedroom, living room and weekend rock stars ought to change them out every 20-24 months. Over-biasing for more crunch, shortens the tube life. Making like John McGlaughlin or Al DiMeola is better for tubes than playing like a dark master shredder king with the amp turned up to eleven. I've seen fresh tubes (at other places I've worked) last two weeks in an amp, or as long as five years (in that same amp). 2 Quote Link to comment Share on other sites More sharing options...
mtreehugger Posted September 16, 2015 Share Posted September 16, 2015 Usage will determine how long the tubes last. Gigging musicians should change them out every 12-18 months, bedroom, living room and weekend rock stars ought to change them out every 20-24 months. Over-biasing for more crunch, shortens the tube life. Making like John McGlaughlin or Al DiMeola is better for tubes than playing like a dark master shredder king with the amp turned up to eleven. I've seen fresh tubes (at other places I've worked) last two weeks in an amp, or as long as five years (in that same amp). Does the master volume setting have any bearing on tube life? What about pentode/triode? i generally run in triode and always keep the master below 12:00. (btw, only one g in mclaughlin, but i won't tell) 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 16, 2015 Share Posted September 16, 2015 You'd think after being a Mahavishnu Orch fan for four decades that I wouldn't miss that one,... thanks. Master volume, maybe just a smidge. Your settings seem fine. Class-A Triode would run hotter than a Class-B Triode. And a Class-B Pentode runs even more efficient. If you gig regularly, the 12-18 months interval would be about right for you (unless one goes prematurely). And the power tubes have to be a matched pair. 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted September 17, 2015 Share Posted September 17, 2015 You'd think after being a Mahavishnu Orch fan for four decades that I wouldn't miss that one,... thanks. Master volume, maybe just a smidge. Your settings seem fine. Class-A Triode would run hotter than a Class-B Triode. And a Class-B Pentode runs even more efficient. If you gig regularly, the 12-18 months interval would be about right for you (unless one goes prematurely). And the power tubes have to be a matched pair. That's kind of interesting about Class-B Pentode being more efficient, just so happens I like that topology and exclusively use it. :) 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 17, 2015 Share Posted September 17, 2015 Class-B pentode is one I use a lot too. Quote Link to comment Share on other sites More sharing options...
jamesnlcc1 Posted September 23, 2015 Author Share Posted September 23, 2015 Update: So apparently my old EH tubes were not blown, and when i put them back in the same wonky stuff was happening, so something else was going on. Line 6 says there's no safety feature to kick it into quiet mode if the tubes get too hot, so i guess i gotta send it in :(. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted September 27, 2015 Share Posted September 27, 2015 Update: So apparently my old EH tubes were not blown, and when i put them back in the same wonky stuff was happening, so something else was going on. Line 6 says there's no safety feature to kick it into quiet mode if the tubes get too hot, so i guess i gotta send it in :(. Thanks for the update, I hope you get it fixed up. I'll be wondering how it's working out for you. Quote Link to comment Share on other sites More sharing options...
jamesnlcc1 Posted February 2, 2016 Author Share Posted February 2, 2016 Uuuuuuupdate! So I sent it in to a local guy who replaced the tubes with JJ's (sorry, psarkissian, don't hate me) and somehow did not encounter the runaway bias drift I had. Perhaps I was shorting something out with my cheap voltmeter? Perhaps cleaning out the tube jacks really IS a big deal (I didn't try)? All I know is that was an expensive NON-problem to fix :P. JJ's working great so far. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 2, 2016 Share Posted February 2, 2016 No, I don't hate you, I just worry about you guys. Been doing this four decades, so I know all the things that can go wrong. Be careful, the JJ curves don't always match well with the EH's. I love the Hard JJ's for certain application, but not for this. If it blows, it may take down the processor board as well. I hope the tech did the bias for the JJ's and not the normal bias used for the EH's. Quote Link to comment Share on other sites More sharing options...
jamesnlcc1 Posted February 2, 2016 Author Share Posted February 2, 2016 Thanks, I was being facetious, I could tell you care ;) . Fingers crossed, I guess, but so far so good. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 3, 2016 Share Posted February 3, 2016 Yeah, I care. But I also don't want to see gear come across my bench if it doesn't have to. Luck. 1 Quote Link to comment Share on other sites More sharing options...
ice9mike Posted February 3, 2016 Share Posted February 3, 2016 Thanks, I was being facetious, I could tell you care ;) . Fingers crossed, I guess, but so far so good. I had JJ's in my DT25 for about 6 months before they blew and took one of the fuses with them. They sound great, but I don't think they work reliably in these amps. My suggestion is to keep a set of EH's on hand just in case. Also, if you have a problem with the amp hopefully there is an authorized Line 6 service center near by. We have two in Portland, Or which are both excellent. Quote Link to comment Share on other sites More sharing options...
peteandrebop123 Posted June 21, 2019 Share Posted June 21, 2019 How about replacing the preamp tube. Can a Bugera 12AX7B be used instead of the CHINA 12AX7B that is originally used? Just curious because I bought a burgera not being able to find the "CHINA" brand. Thanks guys Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 21, 2019 Share Posted June 21, 2019 "They sound great, but I don't think they work reliably in these amps. "--- Correct. JJ's are good tubes, just not in these amps. They are not all analog tube amps, so you can't go tube swapping like we used to do back in the 1960's and 70's. I want to keep all your gear of of my repair bench. So use the specified tubes, please. Quote Link to comment Share on other sites More sharing options...
detlevski Posted July 28, 2019 Share Posted July 28, 2019 Last week i replaced all tubes for the first time. But before doing that I measured the current bias. On V3 I measured 31mv and on V2 i measured 26mv. The 12AX7 was indeed a Chinese generic one and the two EL84 were the (probably) original Electro Harmonix ones. I swapped them out for an Electro Harmonix 12AX7 en two (matched pair) Sovteks. I could not believe my eyes when I measured 23mv on V2 and V3. The original pair looked like the picture, one looked a bit "burned". Is this normal that there is such a difference? Quote Link to comment Share on other sites More sharing options...
Guitarmaniac64 Posted February 16, 2020 Share Posted February 16, 2020 On 9/15/2015 at 5:33 PM, psarkissian said: Can't bias the JJ's to the same bias voltages. The transfer function curve and multiple topology gain structure of DT series amps is not good for JJ's, Mesa's and Groove tubes. I see too many DT series amps come across my bench because of other tubes being put in the amp and biased to the same bias volts as if they were EH tubes. These are not tube amps of the 1960's and '70's, you can't get away with the same kind of tube swapping like we used to do back then. These are hybrid amps with analog and digital stages, both solid state and tube. Can't get away with the same sort of things like we did back then. Please,... use the specified EH series. They've gone through a further sorting through. Thanks but can those specified EH series be swapped without any biasing some new amps dont need any biasing when swapping tubes if you use the same as it was shipped with? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 18, 2020 Share Posted February 18, 2020 These amps power tubes be matched sets, and require biasing. Best to have a Line 6 authorized tech do it so that it's spot on. Quote Link to comment Share on other sites More sharing options...
Guitarmaniac64 Posted February 19, 2020 Share Posted February 19, 2020 17 hours ago, psarkissian said: These amps power tubes be matched sets, and require biasing. Best to have a Line 6 authorized tech do it so that it's spot on. There is no autorized tech in my country so i have to do it myself. Or sell it. I could send it to an amp repeair tech but they are located very long from my home it would take weeks to get it back and the and the cost for the job and shipping is the almost half of the price i payed for the amp. I open it up and atleast the amp has the right powertubes. But i guess they needs to be replaced so i gonna order a matched pair I skip the preamptube they rarely needs to be replaced Quote Link to comment Share on other sites More sharing options...
detlevski Posted February 19, 2020 Share Posted February 19, 2020 You are asking for how to replace tubes to the wrong person, this is a Line 6 support forum. Of course psarkissian has to tell you to bring it to an official repair tech. Line 6 could be sued if he told you you can easily do it yourself and you got hurt or even died. If you have some common sense and a good multimeter and know the procedure(!), which can be found on YouTube or even this forum, you can do it yourself. But that does not mean anybody can replace the tubes themselves, some people are clumsy or not informed well enough to do it themselves. I had to replaced tubes twice (in not even 1 year!) myself and biassing was a piece of cake. But I have some experience in working with electronics. After I did replace the tubes the last time I sold the DT25. I have never used a tube amp that needed new tubes that fast. Fenders and Marshalls. And yes I did use the right tubes, Sovteks EL84's and EHX 12AX7. I didn't find the DT25 reliable enough so I switched back to an all tube amp Marshall. Read for example Marshall and/or Fender forums, heavy users all replace and bias their gear themselves. Quote Link to comment Share on other sites More sharing options...
Guitarmaniac64 Posted February 19, 2020 Share Posted February 19, 2020 16 minutes ago, detlevski said: You are asking for how to replace tubes to the wrong person, this is a Line 6 support forum. Of course psarkissian has to tell you to bring it to an official repair tech. Line 6 could be sued if he told you you can easily do it yourself and you got hurt or even died. If you have some common sense and a good multimeter and know the procedure(!), which can be found on YouTube or even this forum, you can do it yourself. But that does not mean anybody can replace the tubes themselves, some people are clumsy or not informed well enough to do it themselves. I had to replaced tubes twice (in not even 1 year!) myself and biassing was a piece of cake. But I have some experience in working with electronics. After I did replace the tubes the last time I sold the DT25. I have never used a tube amp that needed new tubes that fast. Fenders and Marshalls. And yes I did use the right tubes, Sovteks EL84's and EHX 12AX7. I didn't find the DT25 reliable enough so I switched back to an all tube amp Marshall. Read for example Marshall and/or Fender forums, heavy users all replace and bias their gear themselves. I know how to do it i never done it on a hybrid amp though. And it was atleast 25 years since i did it i went all digital for long time and didnt touch my tube amp for a long time when i got my Helix i dusted it off again and then sold it and bought the DT Some newer amps dont need biasing thats why i asked. Quote Link to comment Share on other sites More sharing options...
detlevski Posted February 19, 2020 Share Posted February 19, 2020 You definitely need to bias even with matched pairs, it is important to let them cook for some time before biassing. I usually take one hour to do that and when I have used the amp intensively for a week I check the bias again. A service tech would not do that, you would have to come again to have him do that. There are plenty people I would recommend bringing it to an official tech. Only you can decide if you are capable enough. If it was my company I would also recommend not doing it yourself. Quote Link to comment Share on other sites More sharing options...
