brend Posted August 10, 2013 Share Posted August 10, 2013 ЗдравÑтвуйте. Извините, Ñ Ð½Ðµ знаю английÑкого Ñзыка. ÐадеюÑÑŒ, не ÑÐ¼Ð¾Ñ‚Ñ€Ñ Ð½Ð° Ñто Ð’Ñ‹ мне поможете.За поÑледние три Ð´Ð½Ñ Ð´Ð²Ð° раза Ñлетела flash memory. С помощью Monkey в первый раз Ñ Ð²Ð¾ÑÑтанновил, Ñделав огромное колличеÑтво попыток. Ðо во второй раз уже два Ð´Ð½Ñ Ð½ÐµÑ‚ результата. Я уже неÑколько раз переуÑтанавливал драйвера и Ñаму Monkey, пробовал вÑе порты usb, ÑброÑил вÑе Ñвои преÑеты, patch's, до заводÑких наÑтроек, пробовал через safe mode на X3.....но вÑе тщетно, поÑтоÑнно показывает code 80007211. ПожалуйÑта, помогите, POD X3 Ñто единÑÑ‚Ð²ÐµÐ½Ð½Ð°Ñ Ð²Ð¾Ð·Ð¼Ð¾Ð¶Ð½Ð¾ÑÑ‚ÑŒ ÑÐµÐ¹Ñ‡Ð°Ñ Ð¸Ð³Ñ€Ð°Ñ‚ÑŒ. Quote Link to comment Share on other sites More sharing options...
brend Posted August 11, 2013 Author Share Posted August 11, 2013 Hello. Sorry, I don't know any English, tried to transfer via Googl translator. I hope, in spite of that you will help me.Over the past three days, twice fell off flash memory. With the help of the Monkey for the first time I restored by making a surprising number of attempts. But for the second time already two days no result. I have already deleted several times and again installed drivers and the Monkey, have tried all usb ports, dumped all its presets, patch's, to the factory settings, tried it through safe mode on X 3 ...but all in vain, constantly shows code 80007211. You are welcome help, POD X 3 is the only opportunity to play now. Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 12, 2013 Share Posted August 12, 2013 Try different USB ports and cables. Quote Link to comment Share on other sites More sharing options...
brend Posted August 12, 2013 Author Share Posted August 12, 2013 Try different USB ports and cables. I tried different ports usb, I tried different cables, I tried on another computer Quote Link to comment Share on other sites More sharing options...
Digitedge2002 Posted September 17, 2013 Share Posted September 17, 2013 I have the same problem with my hd500x. could you fix it? FPG Quote Link to comment Share on other sites More sharing options...
maxoz Posted September 21, 2013 Share Posted September 21, 2013 I have the same problem. I keep getting the flash memory code 80007211. The monkey said that the flash was updated but the x3 display shows "Updating flash window for over an hour now. Any suggestions? Quote Link to comment Share on other sites More sharing options...
scoot13 Posted September 27, 2013 Share Posted September 27, 2013 I have the same problem. I keep getting the flash memory code 80007211. The monkey said that the flash was updated but the x3 display shows "Updating flash window for over an hour now. Any suggestions? +1 same issue here... unable to update flash memory on my new HD500X Quote Link to comment Share on other sites More sharing options...
TheDistant Posted October 13, 2013 Share Posted October 13, 2013 Flash memory (2.0,2.01) pod x3 live update file not working on osx...I've downloaded the file, but it's not recognizing it as a file that any application can open. Can anyone help??? Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 13, 2013 Share Posted October 13, 2013 The file isn't anything that an application could open, really. You need to use Line 6's utility program, Line 6 Monkey to send the update to the X3L. Once you download and install that, hook up your X3L with a USB cable, start the Monkey program, and it will guide you through the process of what to do. It's pretty painless, really. Quote Link to comment Share on other sites More sharing options...
