syngen1790 Posted June 19, 2016 Share Posted June 19, 2016 Hi all, Just wondering if anyone has experienced this issue. On a couple of patches I have included a pitch wham at the beginning of the signal chain in order to change the pitch up an octave when pressing the expression pedal (like a whammy funnily enough!) but my issue is that I can still here the 'dry', unchanged guitar sound as well as the octave higher. Is this something common, or would you need more detail of the patches? It also occurs when I use the pitch shift to have an 'Eb' setting (dropping each note by a semi tone) like on some of the Glenn DeLaune patches. I have the mix set to 100%, heel to zero, toe to 12 and the level to -0.5db. I'm currently running a Gibson Les Paul in and outputting to a Matrix FR12. I'm sure this is something simple. I can give full details of the patches it affects, but happens in most of them. Thanks all Mark Quote Link to comment Share on other sites More sharing options...
tagmusenmagnus1 Posted June 19, 2016 Share Posted June 19, 2016 Could you post a pic? You probably have signal passing through another path og something similar.. Maybe you have set the input block on path 2 by a mistake... Quote Link to comment Share on other sites More sharing options...
duncann Posted June 19, 2016 Share Posted June 19, 2016 There is currently a bug with the tuner. If you have recently unmuted it, try putting it back to muted to see if the dry signal goes away. If that's not it, a screenshot might provide some insight as tagmusenmagnus1 suggested. Quote Link to comment Share on other sites More sharing options...
lokimoto Posted June 20, 2016 Share Posted June 20, 2016 Maybe the mix in the effect block? Quote Link to comment Share on other sites More sharing options...
syngen1790 Posted June 21, 2016 Author Share Posted June 21, 2016 Hi all, Can someone please tell me how to attach a picture to this thread? I'm that new to this I can't even work that out!! Thanks Quote Link to comment Share on other sites More sharing options...
duncann Posted June 21, 2016 Share Posted June 21, 2016 Hi all, Can someone please tell me how to attach a picture to this thread? I'm that new to this I can't even work that out!! Thanks Hit the 'more reply options' button below the box where you type in text to respond to a message, then all should become clear. Another way is to upload the image to an image hosting site (I don't use them so I couldn't tell you of a specific one) and then use the image button above the text box to paste the url from the image hosting site. Quote Link to comment Share on other sites More sharing options...
Tcamponovo Posted June 21, 2016 Share Posted June 21, 2016 could be the way you have the mix set. Make sure the dry mix is all the way down. Also make sure the toe and heel position is set correctly. Other than that, the unit may just need to be updated. This will often fix little bugs like that. Quote Link to comment Share on other sites More sharing options...
syngen1790 Posted June 22, 2016 Author Share Posted June 22, 2016 Hope this works, picture attached of an affected patch. I think the Helix is up to date and the mix is set to 100% on the whammy pedal. Quote Link to comment Share on other sites More sharing options...
DarthHollis Posted June 22, 2016 Share Posted June 22, 2016 Hope this works, picture attached of an affected patch. I think the Helix is up to date and the mix is set to 100% on the whammy pedal. Your bottom input needs to be set to "X None". Right now you have a second guitar signal going into that input and that is causing the other "dry" signal to be heard. 1 Quote Link to comment Share on other sites More sharing options...
syngen1790 Posted June 22, 2016 Author Share Posted June 22, 2016 Thought it might be something simple. I take it when it's set to 'X' the signal 1 path will still go through signal 2? Quote Link to comment Share on other sites More sharing options...
DarthHollis Posted June 22, 2016 Share Posted June 22, 2016 Thought it might be something simple. I take it when it's set to 'X' the signal 1 path will still go through signal 2? Yes, As long as the top path is set to "Output path 2A". Good luck! Quote Link to comment Share on other sites More sharing options...
syngen1790 Posted June 22, 2016 Author Share Posted June 22, 2016 Just tried that and it's sorted. Thank everyone for the assist!!! It was driving me nuts!! 1 Quote Link to comment Share on other sites More sharing options...
aepoc Posted June 22, 2016 Share Posted June 22, 2016 Awesome replies here. Could help a lot of people. Glad it was sorted out. Quote Link to comment Share on other sites More sharing options...
rwinking Posted September 10, 2018 Share Posted September 10, 2018 I was having the same issue with the Whammy pedal....one dry guitar signal staying firm and the other effected by the whammy. It is a kind of cool effect but I wanted one guitar with the whammy effect and no dry sound. I did all of the above: top path set to output path 2A and then bottom set to X "none." I still get the second guitar signal. Then I noticed something weird.... I turned my volume on the Helix down all the way and there is still a guitar signal coming through which makes sense in why I have the whammy issue. Any ideas on how to get rid of that dry signal coming through when the volume is all of the way down? I am pretty sure that this will clean up the whammy issue. Quote Link to comment Share on other sites More sharing options...
DarthHollis Posted September 10, 2018 Share Posted September 10, 2018 It sounds to me like your mix is set at 50% in the whammy but having the volume down on the Helix and still hearing the guitar is strange. I would try putting a distortion in front of and behind the whammy as well as other places in the signal path. You will be able to find where the issue is because you can hear how the distortion is effect dry vs. wet signal. Can you share a screen shot? That might help. Or post the preset. Quote Link to comment Share on other sites More sharing options...
rwinking Posted September 11, 2018 Share Posted September 11, 2018 Long story short...I worked it out and am not sure how. I think it has something to do with the loop as I do 4CM and have a tube pre amp in the loop. It still has the signal coming through with the Helix volume all the way down which I don't get. But at least with the whammy on I don' have the stble note and the whammy-ed note going at the same time. thanks for your help. Quote Link to comment Share on other sites More sharing options...
