SteveGordon Posted January 8, 2017 Share Posted January 8, 2017 I want a Mission Expression pedal for my floor model Helix. I see now Mission have a generic Line6 model and a specific Helix model. The Helix model however appears to be geared to the rack model with a toe switch for extra functionality that I believe doesn't work with the floor model. So which should I get. Or doesn't it matter. Thanks for advice. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted January 8, 2017 Share Posted January 8, 2017 There is one from Mission that is for the Floor unit with a foot switch. Connects to Helix Control (or directly to the rack) with two cables, one for the EXP and one for the foot switch. If you must have a foot switch, you get ONE of those. There isn't any option.Mission pedals are very nice, but my favorite EXP has been the Ernie Ball VP Jr., I think it's the 25K version (but I could be wrong... mine doesn't say what it is).I also like the little Zoom pedal, but you have to either reverse the polarity and deal with 100% at 50% travel on the pedal (which I prefer, actually, so that's what I do), or make a custom cable (VERY easy to do). Quote Link to comment Share on other sites More sharing options...
SteveGordon Posted January 9, 2017 Author Share Posted January 9, 2017 Thanks Peter. But I'm not sure that I haven't confused everyone about the Helix models. I have the standard floor version and not the Helix Control. I think the specific Mission Helix pedal is specific for the Helix control with the extra functionality of the switch, but I'm not certain. Just want to check which version is best suited to the standard floor version. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 9, 2017 Share Posted January 9, 2017 You want the EP1-L6... not the EP1-L6H. Quote Link to comment Share on other sites More sharing options...
SteveGordon Posted January 9, 2017 Author Share Posted January 9, 2017 Great. Thanks Phil Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted January 9, 2017 Share Posted January 9, 2017 Just a few notes on the Mision SP1-L6. It adds nothing for the floor model. And since the late update, which added the "auto engage" feature, the toe switch isn't really necessary for Helix rack either. Sweeping the pedal back and forth has an annoying click as it touches the toe (even when you're not pressing down for the switch). The biggest benefit it would offer would be tying multiple things to the toe switch (i.e. turning on delay and reverb and a level boost for leads as you engage the wah pedal). Mission makes great feeling pedals all around, but unless you need the tow switch specifically for something like i mentioned above, you're better off saving a few bucks and going with a model with no toe switch. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 9, 2017 Share Posted January 9, 2017 Just a few notes on the Mision SP1-L6. It adds nothing for the floor model. And since the late update, which added the "auto engage" feature, the toe switch isn't really necessary for Helix rack either. Sweeping the pedal back and forth has an annoying click as it touches the toe (even when you're not pressing down for the switch). The biggest benefit it would offer would be tying multiple things to the toe switch (i.e. turning on delay and reverb and a level boost for leads as you engage the wah pedal). Mission makes great feeling pedals all around, but unless you need the tow switch specifically for something like i mentioned above, you're better off saving a few bucks and going with a model with no toe switch. Just to clarify - the EP1-L6 is the one without the toe switch. The EP1-L6H has the toe switch. 1 Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted January 9, 2017 Share Posted January 9, 2017 Just to clarify - the EP1-L6 is the one without the toe switch. The EP1-L6H has the toe switch. Yep sorry, I just took at look at the pedal itself. It spells Helix out instead of just adding an H. My bad for any confusion. Quote Link to comment Share on other sites More sharing options...
shawnshack Posted November 7, 2017 Share Posted November 7, 2017 Just a few notes on the Mision SP1-L6. It adds nothing for the floor model. And since the late update, which added the "auto engage" feature, the toe switch isn't really necessary for Helix rack either. Sweeping the pedal back and forth has an annoying click as it touches the toe (even when you're not pressing down for the switch). The biggest benefit it would offer would be tying multiple things to the toe switch (i.e. turning on delay and reverb and a level boost for leads as you engage the wah pedal). Mission makes great feeling pedals all around, but unless you need the tow switch specifically for something like i mentioned above, you're better off saving a few bucks and going with a model with no toe switch. Ah, I have been looking for this feedback. I’m getting ready to grab a couple of mission pedals and was just going to grab them with the switch since it was the same price. But if the switch is annoying, then I’ll go sans switch. Thanks! Quote Link to comment Share on other sites More sharing options...
Thurston9 Posted November 7, 2017 Share Posted November 7, 2017 I have the floor model (ie no rack unit). I want a second expression pedal with toe switch. EP1-L6H? Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted November 7, 2017 Share Posted November 7, 2017 I have the floor model (ie no rack unit). I want a second expression pedal with toe switch. EP1-L6H? You can't use the toe switch on the external pedal with the floor model. In short, you can only have ONE toe switch. On the floor (or LT) it's built-in to the EXP, on the Rack, you can use the one you reference. Now that you can actually auto-engage the effect, you no longer need a toe switch to get one-stomp functionality, though. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 7, 2017 Share Posted November 7, 2017 So just to clarify....The misson pedal with the footswitch.....the footswitch does nothing for the Helix floor unit? The footswitch doesn't work with the floor unit? Quote Link to comment Share on other sites More sharing options...
Thurston9 Posted November 7, 2017 Share Posted November 7, 2017 So just to clarify....The misson pedal with the footswitch.....the footswitch does nothing for the Helix floor unit? The footswitch doesn't work with the floor unit? I'd like clarification too (but it sounds that way to me). Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted November 7, 2017 Share Posted November 7, 2017 I'd like clarification too (but it sounds that way to me). The only way for the foot switch to work is for you to connect the extra jack for "foot switch" on the pedal (there are two TS jacks, not one TS or TRS) to the "foot switch" jack on the unit. That jack only exists on Helix Rack. So... that pedal with the built-in foot switch for Helix only works with Helix Rack, and you can only use ONE with Helix Rack. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 7, 2017 Share Posted November 7, 2017 Thanks for the clarification. Just ordered the non footswitch one. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted November 7, 2017 Share Posted November 7, 2017 Thanks for the clarification. Just ordered the non footswitch one. I'm thrilled I could help. Remember with the new auto-engage feature, the foot switch is no longer needed and you can have all 3 EXPs activate different FX when they lift off zero if you want... Quote Link to comment Share on other sites More sharing options...
duncann Posted November 7, 2017 Share Posted November 7, 2017 Probably wouldn't work too well, but you could possibly use the toe switch by plugging it into EXP3 on Helix Floor, which might allow for a clumsy, extra min-max switch. Quote Link to comment Share on other sites More sharing options...
Thurston9 Posted November 7, 2017 Share Posted November 7, 2017 I'm thrilled I could help. Remember with the new auto-engage feature, the foot switch is no longer needed and you can have all 3 EXPs activate different FX when they lift off zero if you want... I order the footswitch one yesterday but it was the same price as the non-footswitch thanks to the other thread with the link to the Line 6 deal (69.99!). Guess I don't need the footswitchable one but shouldn't hurt. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted November 7, 2017 Share Posted November 7, 2017 I order the footswitch one yesterday but it was the same price as the non-footswitch thanks to the other thread with the link to the Line 6 deal (69.99!). Guess I don't need the footswitchable one but shouldn't hurt. Right, you just ignore that jack. I wouldn't sweat it if it is the same price. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 9, 2017 Share Posted November 9, 2017 Check this out. It's a hack to be able to use that footswitch with your Helix. http://line6.com/support/topic/26725-toe-switching-with-an-external-exp-pedal/ Quote Link to comment Share on other sites More sharing options...
Thurston9 Posted November 9, 2017 Share Posted November 9, 2017 Just saw that trick in another post. I wonder if the mission helix exp pedal needs modification for that to work? Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 9, 2017 Share Posted November 9, 2017 Just saw that trick in another post. I wonder if the mission helix exp pedal needs modification for that to work? Yes it does. Although I'm guessing the electronic work that would need to be done would be slightly different. Quote Link to comment Share on other sites More sharing options...
jesuscares Posted September 13, 2021 Share Posted September 13, 2021 On 11/7/2017 at 11:59 AM, PeterHamm said: Right, you just ignore that jack. I wouldn't sweat it if it is the same price. I have the Sp1 with the toe switch .Hope i can use it with the Helix LT even though i may not need to use the toe switch.Hope it would work as a regular exp pedal. Quote Link to comment Share on other sites More sharing options...
